BB386Evo to 41mm (BB86) reducer?
Bikes: Spcialized RockHopper (free) 1992 Trek T100 Tandem ($220) 2006 Quintana Roo Seduza ($350) 2016 Giant Fastroad ($1100)
Quoted: 46 Post(s)
Hello,
I got a Cipollini frameset from a friend and tried to build it up. The bottom bracket type is BB386Evo. It came with two plastic cups to reduce 46mm shell (386Evo) to 41mm diameter (BB86/92), so that Shimano SM-BB92-41B bottom bracket can be installed for Shimano crankset.
The plastic cups were cracked when my friend tried to removed crankset. Thus, I need to find replacements, however, the cups don't have any brand/model info. I tried to google but nothing came up. Searches only showed adapters to support different crank types, but nothing for different bottom brackets.
Please, let me know where I can find such reducers/adapters. Thanks in advance for your helps.
How about contacting your local dealer for Cipollini?
https://www.mcipollini.com/en/distri..._mobile#mapgeo
Quoted: 46 Post(s)
Thank you very much... I didn't think of that. Luckily there is a distributor in my town. I'll give him a visit tomorrow.
CHeers....
Bikes: BH G6
When I bought my BH G6 with same bracket, at the shop they told me about the possibility of putting adapters so I could use my SRAM Red GXP crankset. Finally, after reading about it and talking with some other mechanics I decided to buy a FSA SLK crankset suitable for my BB386Evo and avoid using adapters.
I've worked in the past as a mechanic as well, and adapters are not the most recommendable solution for anything. If possible, try to avoid them on your bike.
Bikes: 89 Paramount OS 84 Fuji Touring Series III New! 2013 Focus Izalco Ergoride
Quoted: 285 Post(s)
Liked 74 Times
Wheels Manufacturing is supposed to be releasing this 386EVO to SRAM GXP screw-together BB: 386EVO Angular Contact BB for 24/22mm (SRAM) Cranks - Black.
scott s.
scott s.
