usb and rechargeable heating elements
Bikes: Specialized tarmac sl2 giant tcx zero
Quoted: 319 Post(s)
does anyone know of a solid product thats usb and or rechargeable , i have seen some of the offers by zippo, maybe a bit too bulk for shoe inserts , and no i don't want disposable hot hand bull crap they last like 3 minutes no thanks .
im looking at some like this but i would have to get some sort of battery system hacked together to make it work , but on the positive side they are cheap , and easy to replace , unlike those 100 plus dollar heated insoles or the unproven heated socks ..????
https://www.amazon.com/Electric-Heat.../dp/B07B2DB8WG
SE Wis
Quoted: 2746 Post(s)
Liked 3,390 Times
These work for me deer hunting and ice fishing.
https://www.walmart.com/ip/HotHands-...RoCS-wQAvD_BwE
Clark W. Griswold
Quoted: 4352 Post(s)
Liked 3,989 Times
I have had some of those "hot hand" type things that lasted well over 12 hours. If yours are only lasting three minutes you might be doing it wrong or just don't have any sort of winter gear at all and the shorts and a t-shirt with one of those just ain't cutting it.
Lover of Old Chrome Moly
Quoted: 143 Post(s)
Liked 23 Times
One problem that can happen with Hot Hands or similar products is that they need a certain amount of air to remain activated. If your shoes are waterproof/windproof and snug fit, there is a chance they are not receiving enough air. I use Hot Hands inside my Bar Mitts for winter riding and they stay warm for 3+ hours.
Quoted: 319 Post(s)
I have no interest in HOTHANDS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!...................................!!!!!!!!!!!!!!!!!!!!
Quoted: 1074 Post(s)
Liked 295 Times
I’ve given up on heaters that stretch past the bend zone. They fail under the pad of the foot rather soon. And generally it’s enough to keep the toes warm. Look for heating elements about 50x50 mm(2x2”).
There are several on alibaba.com
Article number PI102833-00 from https://www.backercalesco.com/ works fine with a 3.6V battery.
Liked 2,968 Times
Use the batteries that are rechargable with the 3.6v stuff. Make sure you carry two sets of the batteries. Usb stuff is going to be 100+ dollars and the ones I've tried dont get hot enough.
-Oh Hey!
-Oh Hey!
Quoted: 642 Post(s)
Liked 1,526 Times
Anything electric is going to be impractical due to battery capability. Calculate how many watts are required to keep warm and figure out the size of the battery you need in order to keep them powered for any length of time. I guess if you were willing to cart around a heavy battery you might be able to make it work but otherwise your better off looking at better quality clothing.
Unlisted member
Bikes: Specialized Hardrock
Quoted: 1376 Post(s)
Liked 432 Times
I used an electric vest on my motorcycle when I rode years ago. I kept me toasty warm, but needed a lot of power and would only work with a good battery. They must have had a lot of improvements to use heated clothes on a bicycle.
Liked 295 Times
I run my soles off 18650 cells, one for each foot.
0.8A gives me just shy of 3W for about 4 hours as a theoretical limit.
IRL, I begin to feel the fade after about 2 hours.
Now, "any length of time" may obviously mean different things to different people. But 2 hours full function and one hour more of acceptable function is enough to be useful IMO.
For my part, unless it's really bitterly cold, I don't need to run the heaters continuously. I probably use a duty cycle of 1/3 or thereabouts, which stretches use time considerably.
Quoted: 642 Post(s)
Liked 1,526 Times
Depends on what you are talking about. Heated soles and gloves work OK. A heated vest would be more challenging, but they do exist.
If you figure a similar watt density for gloves the wattage will likely need to at least double and for a vest you'll need an awful lot of watts even just to warm your chest. Starts adding up to a whole bunch of those little 45 gram batteries or a much larger battery.
It's not completely useless but I think you can get a lot more benefit/weight from high quality clothing than you can from heated gear that has wattage that is low enough to run off a battery.
Gravel Rocks
I use Hotronics insoles, they work very very well keeping your feet warm. Not cheap, but this is a case where you get what you pay for. I've used them below zero F and my feet were very comfortable.
Quoted: 18411 Post(s)
Liked 15,531 Times
Liked 2,968 Times
Gravel Rocks
They last about 4 hours on high setting, comfy the whole time.
On Edit - I haven't ridden below zero for 4 hours , but they will last 4 hours and I have ridden several hours with them in the upper teens.
Liked 2,968 Times
Cool that you are able to get fours hours when its teens. I suspect a couple of hours when below zero?
-Oh Hey!
-Oh Hey!
Clark W. Griswold
Liked 3,989 Times
Gravel Rocks
I would guess they are going to last a couple hours at least below zero - it likely depends on where you have the batteries. If they are uncovered, yeah a couple hours, maybe a bit more. Covered probably longer. There are 3 or 4 different heat settings, so life depends on where you put those too. Once a person get's moving and warmed up turning them down to a setting lower than 100% would extend battery life obviously.
