Shimano RSX upgrade questions 2
Hey, My question is: is it possible to convert an old square taper RSX bottom bracket to the new Outboard 105 style. I just want to know if it can be converted.
Thanks
Thanks
Occam's Rotor
Quoted: 2366 Post(s)
Liked 2,331 Times
You have to get a different bottom-bracket, but the bottom-bracket shell (the part on your bike frame) is almost certainly compatible with the modern external ones, including what is used now with 105 cranks.
Quoted: 5888 Post(s)
Liked 3,471 Times
Why? The square taper is a good design and shimano square taper bottom brackets are readily available.
That's awesome, thanks. I'm planning to replace the entire system so a new bottom bracket won't be a problem.
Occam's Rotor
Liked 2,331 Times
I changed one with square taper to external BB, and one with external BB to square taper.
Sunshine
Quoted: 10963 Post(s)
Liked 7,490 Times
2- you mention that you are fine converting everything, but a question like this causes me to guess that this will be a first for you. Thats awesome to see as its a fun hobby(building up old frames), but you really need to make sure you are aware of any possible limitations/issues ahead of time. Just read up on Sheldon's website and watch some videos if needed. Tools to maintain a full RSX bike will be in part different from tools to maintain a full modern 105 group.
3- change the brake calipers as new calipers are designed to pull with current 105 levers.
4- post here or in the C&V forum if you have questions, but there is no need to start multiple threads to ask basically the same question. Heck, just keep 1 thread going and ask any questions you have in it. the C&V posters are more than happy to share info and help. https://www.bikeforums.net/classic-vintage/
partialresponse
Bicycle Mechanics
3
04-02-16 10:49 PM
cboyne
2
05-26-14 08:32 PM
