What is the brand of this bike with 35" wheels
Bikes: Colnago C50
Quoted: 25 Post(s)
Liked 7 Times
I thought maybe someone here might know the brand name of this bike that was imported into the U.S. about 12-15 years ago.
(Sorry, no pictures, just a fading memory)
It was a single speed euro-commuter style bike with fenders.
The distinguishing thing about it was it had really big wheels. My guess is about 35". It was definitely not a 29er. No joke.
The bike was heavy and low tech but of good basic quality, the wheels may have even been steel.
I think it only came in red and am almost sure it was imported from northern Europe.
Anyone remember this?
Thanks, Dan
Thanks, Dan
PanGalacticGargleBlaster
Bikes: Upright and Recumbent....too many to list, mostly Vintage.
Quoted: 19 Post(s)
Liked 6 Times
I think it was made by Coker, or at least Branded with the Coker name. You could still buy them new in certain corners of the internets even last summer...The bike was sort of a promo for the tire size.
IIRC beleive Coker produced the tires for Mountain Unicycling, then stuck them on some 2 wheeled machines..presumably to find a way to sell more of em.
**edit**
it was a 36" tire.
**edit**
it was a 36" tire.
--Don't Panic.
--Don't Panic.
Quoted: 19 Post(s)
Liked 6 Times
Yep thats the one. I can't find anyone online who still has em in stock. They had em last summer though.
--Don't Panic.
--Don't Panic.
Bikes: Nothing special, but it works.
Somebody out there is still making giant-wheel bikes, although I can't imagine who is buying them.
Check here: big wheels
www.theheadbadge.com
Quoted: 2422 Post(s)
Liked 4,396 Times
-Kurt
Uber Goober
Coker actually started with the penny-farthing, and made the tire just for that (Coker is a tire company, not a bike company.) From there, they made the Monster Cruiser and the unicycles. The bikes languished, the unicycles took off, and now two or three other tire companies make that size tire.
I understand Coker is actually making some of their unicycle frames now, but I think the monster cycle was built for them. I've also seen a european unicycle manufacturer that had them listed.
I suppose if you were so inclined, you could have a custom one made up
Membership Not Required
Bikes: Giant Excursion, Raleigh Sports, Raleigh R.S.W. Compact, Motobecane? and about 20 more! OMG
Quoted: 70 Post(s)
Liked 15 Times
There are couple of those Coker monster bikes near where I live. One guy rides the crap out of his, typically having to get a new tire for the rear every 6 months or so. I have seen it at my LBS several times being tuned up or having a new tire installed. In fact they keep a couple of tires in stock because they know he will be coming in for one sooner, rather than later.
Aaron
Aaron
Webshots is bailing out, if you find any of my posts with corrupt picture files and want to see them corrected please let me know. :(
ISO: A late 1980's Giant Iguana MTB frameset (or complete bike) 23" Red with yellow graphics.
"Cycling should be a way of life, not a hobby.
RIDE, YOU FOOL, RIDE!"_Nicodemus
"Steel: nearly a thousand years of metallurgical development
Aluminum: barely a hundred
Which one would you rather have under your butt at 30mph?"_krazygluon
Señor Member
Quoted: 1492 Post(s)
Liked 1,096 Times
Think of the gear inches he's got on that though.
If the diameter (including tires) is 38 inches, a 1:1 crank to rear cog ratio would give 119+ gear inches.
Bicycle Repair Man !!!
At a glance I am guessing that this bike has a gear range in the mid to high fifties... getting it up top speed would take a little work but once rolling I can imagine this bike rolling over everything.
The 28's on my roadster are like that.
Uber Goober
I think for cosmetics, they should have used larger front and rear sprockets.
Señor Member
Liked 1,096 Times
A 1:1 crank to cog ratio (based on a 38 inch wheel diameter) is 40 gear inches... 119 gear inches would need a 3:1 ratio.
Zorro -
Rough calculation...
Crank teeth * wheel diameter / # cog teeth = gear inches.
Señor Member
Liked 1,096 Times
That sounds a bit flawed actually. The circumference (not diameter) of the wheel is what determines how far your travel in one crank revolution.
It's MY mountain
Bikes: Klein, Merckx, Trek
Quoted: 4338 Post(s)
Liked 2,982 Times
Not flawed. Gear inches is a way of relating bikes with tires and gears of different sizes, not of measuring travel distance per crank revolution... although that's an easy extra calc.
Guest
Posts: n/a
Quoted: Post(s)
Gear Inches refer to the diameter of the front wheel of a penny farthing.
A 56 inch gear would be a penny Farthing with a 56" DIAMETER front wheel,
a 119" gear is a large a** front wheel!
dangerous with tools
Bikes: fat, long, single & fast
Señor Member
Liked 1,096 Times
ok - point remains - the small crank on the 35" wheeled bike yields a bigger result than what it would on a 27" wheel.
I'm embarrassingly rusty on the math. You'd never know I had a 770 on my math SAT back in 1977 from reading this thread.
Here's a pic of a 36er mtb. This guy is a custom frame builder. I have seen maybe half a dozen similar mtb builds on 36ers. He has a write up on how it rides and handles on trails too.
https://4.bp.blogspot.com/_5ZOmYbeW-E...010526.med.JPG
Ride report.
https://waltworks.blogspot.com/2009/04/36-36-36.html
I bet he could build you a 36er roadie.
Ride report.
Señor Member
Liked 1,096 Times
Interesting idea, but I'd feel really silly riding that.
