aluminum foil works! De-rusting spots on chrome!!
Building a better Strida
Bikes: bianchi brava 1988. fuji track 2007, 2006 Bianchi Pista, 1987 Miele and a strida knock off
Hey just a heads up that removing rust on chrome is a super easy and cheap task with some 1. aluminum foil and 2. water.
then polish up with some metal polish for that high gloss.
No pictures at the moment, but my Miele looks brand new.
even removed the rust spots from the headset, easiest clean up job I had ever done!
Fat Guy on a Little Bike
Bikes: Two wheeled ones
Quoted: 1254 Post(s)
Liked 345 Times
I've tried the aluminum foil method and have not had good results...maybe I'm doing something wrong.
was it chromed steel?
from what i gather, aluminum is softer than chromo,, hence why it removes the rusty surface spots.
crushed foil is pretty abrasive, so i had my reservations, but i figured if its a fork and as real as steel, i didn't have much to lose.
if its a painted chromed aluminum fork, i can see problems....... what happeneD?
Liked 345 Times
I just haven't had it remove rust. Maybe the rust was too deep, or maybe I needed to apply more force, but the foil did absolutely nothing.
Bikes: Nothing special, but it works.
I've used aluminum foil and lemon juice on chromed steel with excellent results. I picked up the tip here. I wish I could remember who posted it -- it was a big help.
I used it on light rust with great success... I did have to use more elbow grease with heavier spots, and it's not perfect for that but I like how it doesn't do any damage. I was skeptical about it but it worked pretty well.
Bike Junkie
Location: South of Raleigh, North of New Hill, East of Harris Lake, NC
Bikes: Specialized Tarmac, Specialized Roubaix, Giant OCR-C, Specialized Stumpjumper FSR, Stumpjumper Comp, 88 & 92Nishiki Ariel, 87 Centurion Ironman, 92 Paramount, 84 Nishiki Medalist
Quoted: 68 Post(s)
Liked 37 Times
Please don't laugh,
Which side of the foil do you use? I've read threads that stated both shiny and dull, and both insisted that's the only way to go. So which one was successful, shiny or dull?
Roccobike BF Official Thread Terminator
too much thought.
i just scrunched it into a ball and further scrunched it by rubbing it on the fork.
Crumpled foil works great with a little lubricant. I usually use wd40 or nevrdull or something like that. Heavier rust takes some patience, but foil can also be used in combination with a brass brush and that speeds it up. Careful when using it to keep changing to fresh areas of the foil and change foil often (it's cheap, use a lot and get the heavy duty stuff) because harder rust/metal particles can get embedded into the foil and cause scratches.
Gotta try the lemon juice thing!
low end rider
Bikes: 80's. hoarder.
Quoted: 56 Post(s)
Liked 43 Times
https://www.bikeforums.net/showthread.php?t=505786
And you thought I was kidding.. take the foil out of the oven after cooking a trout and you have a pre-lubed chrome deruster..
Ride heavy metal.
Bikes: '74 Raleigh LTD-3, '76 Motobecane Grand Jubile, '83 Fuji TSIII (customized commuter), '10 Mercier Kilo WT (fixed obsession), '83 Bianchi Alloro, '92 Bridgestone MB-1 (project), '83 Specialized Expedition (project), '79 Peugeot UO-8 (sold)
That was before I knew of Oxalic Acid. Nowadays if I have a severely rusted frame, I think I'll go for the Oxalic. For surface rust and smaller jobs, Lemon juice and foil has done wonders for me.
yes, i haven't tried this OA stuff, but as long as the rust looks to be on the surface and not some severely scratched piece that has scratched off the chrome and started to rust into the bare metal, the foil made it a 15 min job.
there are a few swirling scratches, similar to swirling on the surface of the paint on a car, but i think any metal polish will get that out.
i used alum foil and lemon juice as suggested on the fork and headset parts shown here
https://www.bikeforums.net/showthread...=#post10644063
and it worked great, took all the rust off except for a couple really deep spots. nevrdull is next. still have to go at the few chromed pieces on the frame......
tronnyjenkins
Classic & Vintage
17
04-23-16 02:53 PM
Soma Roark
Classic & Vintage
5
08-23-11 08:35 PM
Chombi
Classic & Vintage
19
05-04-10 12:44 PM
