How do you react to wet leaves on tarmac?
Bikes: 2019 Giant Escape 1 Disc
I live in an area where a canopy of leafy deciduous trees covers the streets, and consequently, as fall approaches, we get a LOT of leaves on the street, often wet leaves. I try to steer around them, but I know that one of these days, I'm going to hit a patch of them and need to go across them. I could use some advice.
Assuming all other variables -- tire tread, skill level, amount of leaves -- being equal (and I realize that's purely hypothetical in itself), do you have any advice on how best to make it across this hazard without taking a spill? I know it might sound trite or improbable, but there really are a tonne of these leaves where I live, and when I've stepped on them, I sometimes almost go flying. Thank you!
Bikes: ...a few.
Quoted: 2012 Post(s)
Liked 409 Times
Are you afraid of slipping on them or hitting something that's been concealed by them? If the former, going in a straight line you should be fine. Slow right down if you have to turn. Come to think of it, slow down going straight is a good idea too. If the latter, hmm, not sure what can done about that.
Very carefully!
Very carefully!
Quoted: 2952 Post(s)
Liked 3,106 Times
Quoted: 7652 Post(s)
Liked 3,479 Times
I skid and fall down.
next question.
next question.
Bikes: 2016 Novara Mazama
Quoted: 3640 Post(s)
Liked 81 Times
Either correctly, or in a kissing the ground fashion.
Rule #1 for low grip surfaces? Smooth and gradual input in as few directions as possible.
Quoted: 5999 Post(s)
Liked 956 Times
Watch out for negative cant especially, and go easy on the front brake if you're already turning or have to brake hard.
Quoted: 551 Post(s)
Liked 277 Times
I make sure that my body protects the bike.
Quoted: 643 Post(s)
Liked 1,526 Times
I don't mind em so much as long as it's just going straight. It's turning and hard braking that gets hairy.
Really hated em when riding a motorcycle.
Bikes: Surly Long Haul Trucker, Gary Fisher Hoo Koo E Koo, Dahon Mu P 24 , Ritchey Breakaway Cross, Rodriguez Tandem, Wheeler MTB
Quoted: 32 Post(s)
Slowly , with care .
Quoted: 659 Post(s)
Liked 7 Times
Main thing is to not do any braking or turning while on them - just coast across in a smooth straight line. If you can slow down well in advance that's fine, but get off the brakes completely before your tire hits the leaves.
Straightline it's not an issue, just fly thru them.
In corners, that's a different story! Treat them like sand. Basically prepare to go down if you're going faster than 10 mph.
Bikes: Nashbar Road
Quoted: 2934 Post(s)
Liked 341 Times
Keep in mind that the leaves are much worse after a day or two, when they get slimy in between layers of leaves. So you might fly over them one day, feel like it was no big deal, and become incautious the next.
Straight up, relax, straight forward as much as possible, no leaning at all.
Liked 2,979 Times
I leaf the ones with the worst puns alone, but often still fall autumatically for those less greener types.
-Oh Hey!
-Oh Hey!
Clark W. Griswold
Quoted: 4359 Post(s)
Liked 3,999 Times
I don't do no fussin' over leaves or anything like that. I might slow a little and not make any turns on them but no real adjustments. If I can avoid running over that stuff I usually do but it is part of my normal riding.
Callipygian Connoisseur
Quoted: 564 Post(s)
Liked 350 Times
SEMI THREADJACK WARNING:
Don’t you just hate it when the leaves get all stuck to your tires and you gotta listen to the fwip-fwip-fwip-fwip-fwip with the tire rotations? I had to peel a handful off my front tire this morning before rolling through the entrance because they wouldn’t fall off after a block and a half.
-Kedosto
*first world problems*
-Kedosto
