Deore SL-MT60 Shifters Question
Bikes: '86 Trek Cirrus 520, '85 Trek 620, '84 Trek 610
Quoted: 24 Post(s)
Liked 7 Times
Can these be disassembled for cleaning or do you just have to flush out the best you can? If they can be disassembled, does anyone know of a diagram?
(photo from Velobase)
Quoted: 4560 Post(s)
Liked 2,802 Times
Check Shimano's tech document site. It's pretty thorough and has PDFs for those shifters.
Also, check RJ the Bike Guy on YouTube. Tons of videos for DIY repairs. Usually he suggests flooding balky shifters with WD-40 or something similar to work out the congealed old grease. Worked on my older Dura Ace brifters. The tricky bit is re-lubing without disassembly. I'm gonna try some fancy PTFE lube and see if it's a suitable substitute for grease.
Quoted: 24 Post(s)
Liked 7 Times
Liked 2,802 Times
Yeah, in other tech documents for SIS shifters, Shimano recommends against disassembling those indexing modules.
Quoted: 2363 Post(s)
Liked 1,749 Times
Are they stiff or sticky? A quick shot of light lubricant is all you should need with thumbies. There are no pawls or ratchets that can fail to engage.
Bikes: Raleigh Classic 15, 84; Miyata 912, 85; Miyata Ridge Runner SE, 85; Miyata 610, 86; Miyata 100M, 86; Miyata Valley Runner, 88; Miyata Triple Cross, 89; GT Karakoram, 90; Miyata Elevation 300, 91; Marinoni Touring, 95; Long Haul Trucker, 2013
Quoted: 159 Post(s)
Liked 133 Times
The pdf says:
"Lower body unit—never attempt to disassemble." !
Hoards Thumbshifters
Bikes: '23 Black Mtn MC, '87 Bruce Gordon Chinook, '08 Jamis Aurora, '86 Trek 560, '97 Mongoose Rockadile, & '91 Trek 750
Quoted: 246 Post(s)
Liked 338 Times
Do not use wd-40, do not use wd-40
Use a ptfe based lube like Triflow, but if you want to clear out the gunk use electrical cleaner and hose it down, then lube with a ptfe based lube. On thumbshifters I wouldn't necessarily worry about disassembly unless very bad. Those are great shifters.
Quoted: 24 Post(s)
Liked 7 Times
Thanks to all for the replies. I have one that is really stiff and doesn't want to shift all the gears. I'll flush and lube as suggested.
