Good set of hubs/spokes for racing?
Quarq shill
Bikes: 08 Felt F4, 05 Fuji Team SL, 08 Planet X Stealth, 10 Kona Jake the Snake, 03 Giant OCR flat bar.
Good set of hubs/spokes for racing build?
I'm toying with a new wheel build for racing. Did some research last year and forgot all of it by now. I'm looking for a set of 28/28h hubs and strong/stiff spokes. For hubs, I was looking for $250-300, the 7800 DA hubs caught my eye. Anything in that price range better?
As for spokes, I remember reading(I think) that the Sapim Xrays were pretty flimsy. I'm a big guy with big absolute power(and does nothing with it), so I'm looking for some straight gauge stiff spokes.
Thanks for any advice.
CX-rays feel pretty stiff in the wheels I have that are built with them. But it may be the rims more than the spokes. I like the CX-rays but they are expensive.
7800 hubs are nice but use a 10 speed freehub instead of the more common 9 speed splines. So only 10sp Shimano cassettes fit. Sram 10sp cassettes use 9sp splines.
slow up hills
Bikes: Giant TCR, Redline CX, Ritchey Breakaway, Spec S-works epic
uh....how 'bout you just buy some ardennes? if you build wheels, when will you ride your others?
The short of it - I wouldn't worry too much about hubs, and 2.0 db spoke will be nice.
I'm a "selective" equipment freak. I look for things that I feel will give me the function and durability I want, at the lowest price, and skip the stuff that doesn't matter as much. Brake calipers? Who cares? The highest calipers I bought independently were take off Ultegras. They work just as well as Record Skeletons (which came on the bike - I'd never buy them separately). Ceramic bearings? Blah.
I'm jaded when it comes to equipment but I'll pore over rims, crank/BB theories, using Campy levers with Shimano/SRAM derailleurs, and chain guard type things (chain watcher stuff).
In this vein I don't research hubs at all. I've raced on everything from RX100 to DA/Record. I would stay at or above loose bearing Ultegras (RX100 and 105 have oval bearing races), for sealed bearings quality doesn't mean much functionally since the bearings are so similar. I rank Hubs as "if they work, they're fine". This is especially true for a front hub. If it has sealed bearings, if the hub shell is true, then one is no better than another. 10 gram difference? No big deal.
However, I hate steel spacers on axles and such, so I'll go to the level where they get rid of them.
You must be going to a tall profile rim if you're going 28/28 and worried about stiffness? If so, you can consider going 24/28, unless the hole count reduces choices for hubs. I'd personally go for a cheaper, "lower quality" hub with the spoke drilling I want than a higher quality, higher spoke count hub.
If you're looking for ultimate stiffness (track?) then the 28/28 would work great.
For spokes you can use 2.0 db or 2.0 straight. Again, once you hit a 2.0 straight spoke, they all work fine. A 2.0 db spoke (DT Revolution etc) will cut a lot of weight. I've relaced 2.0 straight spoked wheels to "add" 2.0 db. Properly tensioned it didn't make a difference in stiffness.
On the other hand I'll go away from aero spokes on pre-built wheels. When I popped a spoke on a DV46, I relaced with round spokes. I prefer the round spokes because they handle a bit differently in max, out of saddle efforts. After relacing a rear DV46 I realized that this difference really exists just in the front wheel.
cdr
cdr
**** that
Quoted: 1099 Post(s)
Liked 104 Times
My impression is that Psi's wheels are a great price, great quality, but slow turnaround.... otherwise I'd be all over that.. (when I get a jobby-job that is)
Bikes: Something Canadian, something Italian, something American, and something German
Quoted: 64 Post(s)
Liked 16 Times
Well it seems like you both can't do things immediately then.
**** that
Liked 104 Times
Indeed - but when I had a job, I had the $$$, just not the patience..
If I pay $$ for something I usually want it now, and I'll pay to get it quicker.
Quoted: 64 Post(s)
Liked 16 Times
Yup. I can save $30 and wait 3 weeks for an edge 500, or pay the extra and have it immediately. So tempted.
Quarq shill
Thanks for the opinions.
I'm looking to build a set of the 88mm Gigantex carbon tubulars. Either 24/28 or 28/28, depending on what hubs I can get for a decent price. They will be both crit and TT wheels for now.
20f and 24 or 28r. CX-Rays or Aerolites. DA 7900 rear hub >> than 7800. White Industries would be good, but maybe out of your price range.
With such tall rims you can go lower spoke counts. A 90 mm rim with 24 spokes has spokes spaced about as far apart as a box section 32. I'm being lazy and not measuring my wheels. 24H = pretty good spoke density.
Quarq shill
Okay, looking at this right now.
88mm carbon tubulars 24/24 hole
American Classic Micro 58 front hub
American Classic RD 205 rear hub
brass nipples
Sapim Race or Sapim Strong spokes, looking at a single or double butted spoke. 2x rear
Should be under $800 built.
Anyone have any major issues with a build like this?
brass nipples
Quoted: 31 Post(s)
https://stores.justridingalong.biz/-s...set/Detail.bok
this guy does all my bike maintenance stuff. call and ask for travis. you can thank me when you get them.
i'm on velocity aeroheads, sapim cx-ray spokes, white industries h2/h3 hubs, they're fantastic all purpose wheels.
pm me with ?
pm me with ?
I eat carbide.
Bikes: Lots. Van Dessel and Squid Dealer
Quoted: 1325 Post(s)
Liked 1,306 Times
I've pumped out close to 300 wheels in the last 12 months. I don't spec anything and I don't build 2 that are the same. Anyone who does is building a wheel for someone else - not you.
PSIMET Wheels, PSIMET Racing, PSIMET Neutral Race Support, and 11 Jackson Coffee
Podcast - YouTube Channel
Video about PSIMET Wheels
Quarq shill
I'm pretty big so super low spoke counts scare me, I've read pretty good reviews on the AC hubs, and I've always been told that if you're going to ride in wet or nasty conditions to skip aluminum nipples. :shrug: Guess not?
Aero spokes I'll buy, but I can't imagine it makes that much of a difference. What are we talking, well under a watt a wheel I would think?
Quarq shill
And while we're getting technical, what makes a "good" hub, i.e. King, White Ind, Alchemy, Tune, better than say an Ultegra, Velocity, AC hub?
I like building/working on brass nipples, riding aluminum ones. Brass is more durable for sure. Use alum front or non drive side. Brass drive side, debatable in the front. The non drive side will have the lowest tension spokes.
AC hubs - hubs are hubs. I don't know them from anything else, but I'd look for the widest flanges for lateral rigidity. Meaning flanges which are wide apart, not large flange hubs (although that helps too). I think that folks like Zipp etc have their hubs made by other companies - no issues there. I know HED makes a lot of stuff in Taiwan, basically "house brand", but they're fine for normal, regular use.
cdr
Aero spokes - I think they're lighter usually. Go 2.0 db, like DT revolutions, that's my "best bang for buck" choice. Super durable too.
cdr
If aero spokes don't matter, then neither do the carbon rims... it is in the same ballpark.
You can see my thoughts on some of the higher-end hubs here: https://fairwheelbikes.com/forum/view...dc81c45b8c36ed
Bikes: Custom Custom Custom
Chris,
Read this
https://fairwheelbikes.com/forum/view...hp?f=65&t=6940
My offer we talked about on Sunday is still on the table if you decide that route
Read this
Bikes: Specialized Allez (2007)
Use DT revolution, they are excellent spokes and save a lot of weight. But use DT Competition or even straight gauge on the drive side- that way the tension is nearly the same on each side, you get a stronger wheel and it stays true really well.
