technique - help me out
all
I recently started to realize I am terrible at this sport. So help me get a little better
How to do you all get up those really short punchy climbs from a near stop? ie the down a 10ft long 9 ft drop hill(steep - 180 degree hard turn and then right back up? I cant seem to generate enough power after the turn to get enough momentum to even dream of clearing it.
I see lots of guys riding it and just as many running it in my class.
Would be great to save that 20 seconds a lap.
any suggestions?
-thanks!
any suggestions?
-thanks!
Team Beer
Bikes: Too Many
Quoted: 114 Post(s)
Liked 159 Times
We had one of those in my race yesterday (Sugar Mill Race form SacCX Series). What I did was to preshift to the lowest gear before the decent and just use my rear brake to slide (over steer) through the 90 so I was in position to crank it up the hill. It was a tough section and it separated the MTB guys from the roadies.
From a power perspective you may need lower gearing and go out and do some strength building sprints.
I'm not one for fawning over bicycles, but I do believe that our bikes communicate with us, and what this bike is saying is, "You're an idiot." BikeSnobNYC
Bikes: Yes
Quoted: 3230 Post(s)
Liked 3,868 Times
I have the same problem, and in fact posted the same question in the CX racing sub-forum just a couple of weeks ago. I've been doing a weekly race series that has the situation you describe in the course every week. Just when I thought I was getting the hang of it, they changed the approach angle just a little and made it steeper (that or I relapsed in my technique).
With the understanding that anything I say could be entirely wrong, it seems to me that this situation is about three things: (1) power, (2) traction and (3) weight transfer. I have a mind boggling lack of power, and there's not a lot I can do about that in the short term. Traction is generally limited by the conditions and your tires, though the weight transfer has a huge effect. So really, it's all about weight transfer.
What was (sort of) working for me was this:
At the advice of someone here, I gave my second lowest gear a try and I think that helped. The whole thing is over quickly, so using a higher gear for just a second to get even a little speed into the hill is worth sacrificing a little in the gear you're in on the hill. Ideally, I think you'd down shift as soon as you hit the hill, but that's probably too much of a risk mechanically even if you could pull it off.
Next, as I hit the hill I tried to push down on the pedals and pull up on the bars. I read somewhere that it's kind of like jumping -- you want to start out crouched and time it so that you reach a full standing position just as you crest the hill. I have no idea if I did this right, am describing it right or even if it really applies in this situation.
Finally, front-to-back weight distribution is critical throughout this process. You need enough weight on the back tire to keep traction, but you need enough weight on the front tire to keep it from lifting off the ground (but no more). I don't know if there's a trick to this. As far as I can tell, you just need to develop a feel for it.
In the end, I think the absolute slowest thing you can do in this situation is try to ride the hill, fail and end up doing an awkward dismount halfway up. If you know you can't pull it off, it probably isn't a lot slower to dismount at the bottom and run it -- unless of course there's something immediately afterward that requires a quick clip-in.
My Bikes
My Bikes
or tarckeemoon, depending
Bikes: Davidson Impulse, Merckx Titanium AX, Bruce Gordon Rock & Road, Cross Check custom build, On-One Il Pomino, Shawver Cycles cross, Zion 737, Mercian Vincitore, Brompton S1L, Charge Juicer
Obeast
General Cycling Discussion
19
05-09-19 07:46 PM
Kris Flatlander
"The 33"-Road Bike Racing
31
01-18-11 05:30 PM
