Clincher/Tubular combo
Quoted: 7 Post(s)
Is there any annoyances of running a front clincher and a back tubular wheel? People often tend to say how tubular feels different than clincher and that got me thinking if this difference would impact on the ride.
I'm currently running with a pair of Mavic's Ellipse and I'm thinking about buying a back FFWD disc for race events.
Sqrl
You're overthinking it.
Elitist
Quoted: 1386 Post(s)
Liked 92 Times
+1
8Bits,
If you want more aero benefits, buy an aero FRONT wheel before the disc. The front wheel provides much more aero benefit than the rear. This is why you'll often see elite racers use their aero fronts during warmup jumps to get max speed but not have bother installing their disc yet as well as saving wear on the nice tires:
So, to put it plainly, a Disc + Ellipse front won't make you faster. It will help with standing starts if you are strong enough to twist the Ellipse rear spokes, though.
I would suggest that you buy something like:
- Zipp 404 front
- Zipp 808 front
- ...or similar quality wheels from other manufacturers
Of all of the aero equipment that you choose to use (skinsuit, aero helmet, aero mass start helmet, shoe booties, aero front wheel, rear disc, aero frame, aero bike fitting, etc...), the disc has the lowest bang-for-your-buck in terms of performance. Get the disc to fine-tune things after you've invested in everything else.
8Bits,
- Zipp 404 front
- Zipp 808 front
Elitist
Liked 92 Times
FFWD makes some good wheels. They have 5 spoke and 808 type track front wheels, too.
If you can borrow an aero front wheel for a few laps and maybe a high-speed effort, you'll feel the difference immediately.
If you are a lighter rider, then 808 type rim depth (80mm) might be too much as you will fight the wind a lot. 404 (40mm) is fine. 100mm is waaaaay too much.
Elitist
Liked 92 Times
Also, regarding tires:
There exist some clincher tires called "open tubular" which have better casings and feel like tubular tires. Basically they cut a tubular and give it a bead to fit in a rim. They cost more, but feel really good and can be pumped to higher pressures like tubular.
Anybody know what the OEM wheels for this year's Giant Omnium are rated to? I'm guessing I'm going to have to contact Giant to figure it out.
Resident Alien
Quoted: 349 Post(s)
Liked 10 Times
I'm not sure where you came up with this, but holy smokes is it wrong.
Rider position is the biggest factor.
You can go backwards with the wrong skin suit or "aero" helmet. There are only a couple of booties out there that provide any advantage at all, and that's provided they fit right. Even then it's pretty tiny. "Aero" frame vs. rear disc depends on the frame, the disc, and the yaw angle of the wind. And what you're using as a baseline.
You are correct in that the front wheel has a bigger impact than the rear. Also correct on the clincher vs. tubular thing, as far as feel it's a complete non issue on a velodrome. Personally I wouldn't ride clinchers on anything beyond a soft banked 333, but's that mostly because a tubular tends not to blow out as dramatically as a clincher, and they provide a bit more margin of safety at higher pressures. For whatever reasons most of the bang/crash events I've seen on 250's have been clinchers.
Just an FYI I've got probably 60+ hours at various tunnels and aero testing facilities, along with access to a lot of unpublished data from the same, and a ton of field testing hours. And more than a few pursuit/TT records and titles, both my own and from people I coach and have helped set up. There are a few things that are pretty inarguable when it comes to aero stuff, and a lot of things where the answer is "maybe, you need to test". See above.
Elitist
Liked 92 Times
The Ellipse rear is already faster than standard spoked wheels with 20 bladed spokes.
Resident Alien
Quoted: 349 Post(s)
Liked 10 Times
Pretty much any disc will produce less drag both from an aerodynamic standpoint and from a watts to drive standpoint in all conditions compared to the Ellipse, which is not even close to the fastest spoked wheel out there.
Depending on the yaw angle of the wind and the disc, you can actually produce negative drag with a disc. Never see that with a spoked wheel.
Spoked wheels produce a lot of turbulence (which produces drag), all other things being equal (shape, diameter, hub, tire) the less spokes, the taller the rim the less turbulence, the less drag. They also require watts to overcome the drag of the spokes. Less spokes, better shaped spokes, less "mechanical" watts required. A disc requires zero watts to overcome spoke drag, and is essentially a spokeless super tall rim.
That's pretty much the "Intro" primer.
I'm not sure where you're getting your information, but it's way wrong, which is surprising because normally your info is pretty good.
Elitist
Liked 92 Times
I have no idea what a "standard" spoked wheel is. I'm sure the Ellipse is better than some wheels and worse than others.
I've owned just about every popular track wheel combination available (except for Specialized Trispokes), including Ellipse 20 flat spokes front/rear, 404 front/rear, 808 front/rear, 1080 front/rear (borrowed), 900 disc, Io/Comete, 32 (round) spoke front/rear, 36 (round) spoke front/rear, Campy Vento front (same as Shamal but with road hub), etc... but I've never been in a wind tunnel.
The Mavic Ellipse are faster than you would think. I think they are, by far, the fastest training wheelset available. In terms of rim depth and spoke type, the Ellipse is very similar to the Campagnolo Shamal 16 bladed spoke front wheel which actually tested as fast as the Zipp 404.
I do agree that the disc will be somewhat faster, but I should clarify that my point is that it will not be significantly faster, and certainly not worth the $1,000+ (MSRP) expense when the other items listed are not in play yet. That money would be better spent on a front wheel where gains will be more significant.
Elitist
Liked 92 Times
Resident Alien
Quoted: 349 Post(s)
Liked 10 Times
You didn't, which would indicate that you don't know what the actual numbers are. So now define "somewhat"
Define significantly. Actually define it in a watts @30 MPH per dollar number, then we can discuss where his best value would be. What if he could get an older Zipp tubular disc for $300-400? What would be the "worth"? Would it be better than spending money on a $300 aero helmet that didn't work?
I figured this (somewhat/significantly/worth) would be the next comment...because these things always devolve into subjective vs. objective measurement when folks put out bad info and are corrected. I'm not trying to bust your balls but there's no such thing as "somewhat" and "significantly" on any of the test data I've produce or my athletes have produced. There's a drag at a wind speed at a yaw angle under "X" conditions (say, mounted in a P3).
Owning a lot of different wheelsets gives you a lot of subjective opinion and some objective data all of which has value. Along with the opportunity to do comparative testing. If you haven't done that testing (and done it correctly) you really have no idea how something performs aerodynamically unless you've got quality data from someone else's testing.
As I said, I'm really not trying to bust your balls but I am trying to correct some bad info and assumptions.
I've worked with Ketchell, Cobb, Giraud, and some other pretty big brains. As I noted above, they'd agree there are a few things that you can say with certainty when it comes to this stuff. Other stuff will surprise you. You want an example? Which of these four wheels would be fastest in the tunnel at 0/2/4/6 degrees yaw? Now tell me the order from highest to lowest CdA on the track:
My wheels, run at the A & M tunnel and at the aEro facility at HDC.
Resident Alien
Quoted: 349 Post(s)
Liked 10 Times
Seriously? Where's my flippin trophy girl then?
Actually you win because I'm handing out info that cost me and my athletes a lot of time and money. It can save you a lot of time and money and make you go faster.
You really ought to take a shot at the wheel test. You'd learn something of value. The results are pretty interesting.
Resident Alien
Quoted: 349 Post(s)
Liked 10 Times
Here's where it got interesting (little of this I would have predicted BTW).
In the tunnel from 0-4 deg yaw it went Stinger 9, Corima Disc, Hed 3, Zipp Disc. At 6 degrees the Corima and S9 were tied, then H3, then Zipp disc. Max spread was around 11w. The Stinger pretty much kicked ass.
The Corima and Zipp discs were identical in dimension, slight difference in hub but not much. Both ran 23c tubulars. But different tires. 11w difference. That's a big training block for most folks.
At the track, where everything is measured (mech watts, friction, aero resistance, Crr) to come up with CdA the Corima kicked ass, then the Zipp, then the H3. The Stinger? DFL.
18 spokes vs. 3 spokes vs. no spokes. Same tire pressures, all the barometric corrections, Etc
Changing the tire to match the disc thickness of the Corima made the differentiation even greater. Same tire on the Zipp and Corima and any differential was noise.
You were spot on when you said the front wheel>rear wheel. But the rear wheel sees a lot of dirty air and a disc does a much better job of smoothing that out than a spoked wheel. Both need to be spun and spokes mean more drag (longer spokes mean even more drag). And where it sees clean air it's nothing but good stuff. It's going to change from frame to frame but the dollars to watts ratio for an old tubular Zipp is pretty darn good.
There's a really small reference base out there; most people read the few pieces that are out there and take it as gospel. We tested x helmet against y helmet and x won sort of thing. There you go.
But try testing x helmet against y helmet and it gets flipped. Have the test person drop their head and things change again.
Which is why if you can get a slam dunk improvement you take it. Rear disc is one of those. Deeper, lower spoke count front (or H3) > Mavic. In your face!
The right tire...big. How and what events you ride matter too. The difference between a rear disc and that Mavic wheel is going to spread out as you speed up.
There's a bunch of other stuff that comes into play...wind, maneuverability, stiffness...it's why I wake up in the middle of the night and have a 1000 Ebay transactions.
The more you know,the less you know. Until you know.
Elitist
Liked 92 Times
Half a cigar. Actually a quarter because you didn't say which disc
lean88
Track Cycling: Velodrome Racing and Training Area
13
02-12-17 12:31 PM
Flash
"The 33"-Road Bike Racing
3
02-23-11 11:00 AM
