Man I hate this!!! Black lightening fork.......
Quoted: 29 Post(s)
I'll try not to start anymore threads about this bike, but this is about a specific problem. The stem and fork are one. I inverted the frame and plugged the hole for the stem bolt and filled the entire fork tube with PB Blaster. Waited 24 hrs and twisted the stem as hard as I dared. I had a 2x4 in the fork legs as close to the top of the fork as possible. I am afraid that I'll distort or even destroy the fork. Is this fork anything special because its on a black lightening? I definitely do not want to damage the frame either. It makes me sick..........
Keener splendor
Did you try Sheldon Brown's ammonia trick? He uses it for stuck seat posts, but it should work for stems:
14 Ways to Unstick a Seatpost
See #8
See #8
Bikes: 1986 Alan Record Carbonio, 1985 Vitus Plus Carbone 7, 1984 Peugeot PSV, 1972 Line Seeker, 1986(est.) Medici Aerodynamic (Project), 1985(est.) Peugeot PY10FC
Quoted: 150 Post(s)
Liked 34 Times
You need to break the corrosion between the stem and steered tube. Many had been successful using "Freeze-Off". Do a search and you can find out how to best use it. A couple of years ago, I was able to release a really badly stuck stem on one of my bikes by using Freeze-Off. Discovered the stuff after using all sorts of other penetrants, including PB Blaster for about a month of soaking, and careful twisting and pounding without success, till I used the Freeze-Off...and the stem came off only ten minutes after I used it!
Quoted: 140 Post(s)
Liked 163 Times
Still learning
Did you try tapping the stem down?
I have tried all the above chemicals and solvents on a seatpost, ended up cutting it out with a sawzall.
Bikes: Treks (USA), Schwinn Paramount, Schwinn letour,Raleigh Team Professional, Gazelle GoldLine Racing, 2 Super Mondias, Carlton Professional.
Quoted: 78 Post(s)
Liked 30 Times
I use this to hold the steer tubes, a 1" Tube holding block, I get mine from Paragon Machine. DO NOT USE A 2X4 WEDGED BETWEEN THE BLADES.
www.paragonmachineworks.com - FT4008TubeBlock1Bore134x2
The last Stuck stem I removed, I used heat. I held the steer tube with the blocks held in a vise. Then applied heat with a small propane torch to the stem only, then shocked it with cold water. I did that a few times, then let it cool. Came right out.
Note: I did cut the stem enough to be able to remove the fork from the frame.
Thumpic, Patience! A leather mallet can shock a stem or seat post loose, just no John Henry power levels.
Brad
Brad
aka: Dr. Cannondale
Quoted: 2155 Post(s)
Liked 3,406 Times
Also, make sure you have the bottom wedge out of the stem body. Loosen the bolt, then strike it HARD with a steel hammer and punch. Some of the stems with the circular wedge (e.g. Modolo) can get stuck up in there...
Semper Fi
Quoted: 1172 Post(s)
Liked 358 Times
Bill
Semper Fi, USMC, 1975-1977
Bianchi Goddess
Quoted: 2935 Post(s)
Liked 2,930 Times
The fork was just regular Cannondale spec fork just black w/ gold decals.
Sugar "Kane" Kowalczyk
I had luck with my paconi with sodium hydroxide. Tried all mechanical methods including freezing as people have suggested. This is a LAST RESORT METHOD that is 100% certain to work. only use if you are understanding of the dangers of strong chemicals. Use it last. Oh and i love riding the paconi to this day. 531C with perfect geo for my build and shimano 600.
Quoted: 659 Post(s)
Liked 595 Times
Quoted: 41 Post(s)
Liked 51 Times
I have an alloy MODOLO stem thats been stuck in my 1989 Cannondale head tube since I bought it. I've tried everything to get it out. It was placed in almost all the way, and if I could just move it up about and inch and a half it would be perfect.
BTW...a MODOLO stem is also on a 1988 Centurion Ironman Master I bought a couple of years ago. Same thing, but this is one is black, not just the exposed alloy like on the Cannondale.
Is this a MODOLO issue**********????
Still learning
Bikes: 1982 Torker BMX, 1990 Cannondale Black Lightning, 1996 Cannondale F400
Have you tried a can opener? Just teasing. And for what its worth, I've had good results using Kroil, patience, and a bit of force.
Spin Forest! Spin!
Bikes: I used to have many. And I Will again.
Quoted: 7 Post(s)
Liked 11 Times
No, Modolo stems have a different reputation. That's a 'death stem' that you have on the Centurion.
The Professional and Ex-tenos (sp?) had the bad habit of snapping from cracks around the binder bolt. There was a recall on these models back in the 80s.
The lesser models weren't recalled!
The fact both of yours are stuck is probably a coincidence. A lot of alloy stem/steel steerer seizure issues in old bikes were caused by lack of grease during installation.
Those in damp climates have a higher occurrence.
Quoted: 1609 Post(s)
Liked 2,216 Times
I use to hate Bianchi Celeste. Then I woke up and started looking for a frame when the Moto died. Found one I was willing to purchase. Noticed the dents in the inside front and back of the fork blades. Must have had a stuck stem!
Quoted: 41 Post(s)
Liked 51 Times
Spin Forest! Spin!
Quoted: 7 Post(s)
Liked 11 Times
The Professional was on the list of recalled models.
I was stressing how could they have left off the less expensive models, based on finish? As you have shown, even the matte bead blasted finish model cracked.
I had a new old stock silver rough finish model. I think it was called 'Speedy'. I never dared to use it on a build.
No longer active
Quoted: 89 Post(s)
Liked 6 Times
See #8
See #8
Quoted: 90 Post(s)
Liked 137 Times
I have a Nishiki that had a nice SR stem stuck in the fork, I had to cut the stem to remove the fork from the frame. I then got a tall glass jar and filled it with Oxalic acid and put the stem & fork upside down in it, it took 2 1/2 weeks with me pouring OA down the steerer tube every other day before I was able to break it loose.
Glenn
Glenn
