A frame type power loss experiment
Old 02-07-24, 02:31 AM
  #101
HTupolev
Quoted: 1979 Post(s)
Liked 1,298 Times in 630 Posts
Originally Posted by choddo
You divided by 3 there, not 1/3, which is actually correct if the alu is 1/3 as stiff
You're right, I worded my explanation wrong. But my arithmetic does not make that mistake.
I just edited my post to correct the mistake.
HTupolev is offline
Likes For HTupolev:
Old 02-07-24, 12:17 PM
  #102
terrymorse
climber has-been
terrymorse's Avatar
Quoted: 3432 Post(s)
Liked 3,567 Times in 1,793 Posts
Originally Posted by HTupolev
Could you show the math?
Yeah, well, it looks like my back-of-envelope calc was a bit too hasty.
Here's my spreadsheet showing bending stiffness ratio of aluminum to steel. As you can see, aluminum is slightly less stiff, but the difference is less with larger diameter tubing:
Numbers used:
  • Young's modulus (Gpa): Steel 7.85, Aluminum 69
  • Density (g/cm^3): Steel 200, Aluminum 69
  • Wall thickness (in): Steel 0.04, Aluminum 0.116
If you make the wall thinner, the difference is less. This is for steel 0.02", aluminum 0.058:
Ride, Rest, Repeat. ROUVY: terrymorse
terrymorse is offline
lytleric
2
05-18-20 11:15 PM
CanadianBiker32
Training & Nutrition
3
05-16-17 05:24 PM
HawkeyeCubs34
10
12-15-16 01:07 PM
MichaelJH
Road Cycling
9
03-14-16 07:24 PM
mcafiero
Track Cycling: Velodrome Racing and Training Area
4
10-16-11 11:38 PM
