New Trek "Madonda"?
#51
Advocatus Diaboli
Quoted: 4739 Post(s)
Liked 1,533 Times
At what progressive gear increase did cross chaining come into existence, was it the 8, 9, or 10-speed cassette where the cassette became just that bit too wide?
#52
Quoted: 3241 Post(s)
Liked 2,512 Times
It could be when multiple chainrings came to the front. If it's a 1X, it can't be cross chaining, correct?
#54
Liked 2,512 Times
Probably at 9. If you still have 5, 6, 7 or 8 speed like I do, you buy the same chain for all. 9 speed chains are different according to the chain mfgrs.
#55
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2587 Post(s)
Liked 5,649 Times
#56
Bikes: SL8 Pro, TCR beater
Quoted: 989 Post(s)
Liked 586 Times
IMO, when you look at it from above, it's clearly crossed when on the big ring and one of the two easiest gears at the back or when on the small ring and one of the 2 hardest gears.
#58
Advocatus Diaboli
Liked 1,533 Times
I've wondered a bit why they just don't make new 8,9,10 speed cassettes with 12-speed cogs and chain. How much narrower would those all be.. and the makers can just sell 1 chain and all the same individual cogs to make up the cassette. That should help with tooling and reducing production lines, no?
#59
Liked 2,512 Times
I suggested that back last year.....then Shimano came out with the CUES? line.
#60
Resident PIA
Bikes: Gunnar Roadie, Look 765 Optimum, Spesh Aethos
Quoted: 212 Post(s)
Liked 356 Times
Not entirely true, 12 Speed Ultegra Di2 doesn’t lock anything out, you can when using semi sync lock out small and smaller cogs, and big and bigger cogs it’s up to you though. Not sure about 105 though.
Shad
I knew where I was when I wrote this
I don't know where I am now...
05 Gunnar Roadie Chorus/Record
67'er
Shad
67'er
#61
Quoted: 4420 Post(s)
Liked 4,873 Times
Personally I do avoid using big/big as it doesn’t feel as smooth as the equivalent gear on the small ring. But I will use it occasionally to get over a short hill in the big ring. Otherwise I drop into the small ring for longer climbs and make full use of the wide cassette range.
#62
Quoted: 989 Post(s)
Liked 586 Times
I fail to understand why cross-chaining would be different on a 12sp versus an 11sp or 10sp. Care to elaborate?
#63
Liked 4,873 Times
In general, the newer, narrower chains are designed to tolerate cross chaining more. But there probably isn't much in it. It's one of those things that doesn't require over-thinking.
#64
Quoted: 9656 Post(s)
Liked 6,366 Times
Having watched today's pros climbing some big-ass hills in big/big, I've concluded that anything I do is likely to have little adverse consequence to my bike.
I do try to avoid cross-chaining due to the noise and friction, but if I'm about to crest a hill and want to be on the big ring once I do, I won't hesitate to shift to the biggest cogs to get there.
Likes For Mojo31:
#65
Quoted: 10238 Post(s)
Liked 5,187 Times
I always knew you were a cross chainer.
#Noshame
#66
Liked 6,366 Times
#67
Bikes: Trek Domane SL7 Disc, Cannondale F29
Quoted: 389 Post(s)
Liked 325 Times
At first glance I thought the post title was, "New Trek 'Madonna'" and I started feeling a little sick to my stomach.
#69
Liked 5,187 Times
#ThrustHole
