So..whaddyareckon? Can my 08 Komodo handle a 160mm travel front end?
Old 10-28-13, 03:58 AM
cyclops
Dismember
cyclops's Avatar
Bikes: Jamis 2008 Komodo, 40's Malvern Star 16" my 1st! , 58 Malvern Star 28", (gave it to the LBS for display), Voodoo Wanga SS, Voodoo Bokor commuter, Wilier Triestina Lavaredo, Kojima Condor 80's resto roadie.
Hi! to all those still here. Its like the thread said, can an 08 Komodo handle 160mm of travel or is it too much?
Mmmmmm, shiney.
cyclops is offline
Old 10-28-13, 05:38 AM
Zephyr11
Pint-Sized Gnar Shredder
Zephyr11's Avatar
Bikes: '09 Jamis Komodo, '09 Mirraco Blend One, '08 Cervelo P2C, '08 Specialized Ruby Elite, '07 Yeti AS-R SL, '07 DMR Drone
Yes.
I think this is an '09. '08 had a really similar frame, with...beefier stays, I think?
I think it might ride better with a 140mm though. Really not a great climber with that fork, though it descends great. If my phone's inclinometer is correct, it slackens the headtube angle out to 64 degrees (I think I measured 67 with a goniometer, but I don't have that on hand right now to re-check, so assume somewhere between those two...goniometer is accurate to within like 5 degrees, I think, not sure on phone). I have that one on it because I got it for $75, and I have little bike for climbing anyway. But yeah, it can handle it.
Zephyr11 is offline
Old 10-30-13, 12:47 AM
ed
ed's Avatar
Bikes: Hecklah
Dang straight it'll handle it!
Works well with 140 too.
115 works as well.
Heck...I even like it with 0mm travel.
Depends on your terrain as to what works best for you though. 150 is a good compromise. (Sektor / Pike)
If you're pedaling smooth terrain with occasional small drops less than 4 feet, the rigid Identity Rebate with a nice tall headset is magical. If you pedal choppy terrain more than descend, go 140-150. If you're descending quite a bit, monster trucking, freeride...160 all the way!
Alright, alright...mine's a 2005, but your 2008 is the best of them all. Its got my rear triangle and Zephyr's front triangle. So you've got the rifled top tube and internal headset. (not integrated, mind you) But you still have the big "D" shaped stays that are bridged.
This means you can be big and fat but not have frame flex from your rear brake that causes warbling noises from misaligned rotors/calipers from the flex. You can also run any fork steerer you want.
That's the Unicorn frame. Hope to run across a Large one day for myself.
ed is offline
Old 11-01-13, 02:43 AM
cyclops
Dismember
cyclops's Avatar
Thanks Ed, Zephyr.
Currently it has a 2012? Marzocchi DJ 1 on it. but for the last couple years I have'nt been able do uphill real well due to a deteriorating knee. So I thought I might put something on it that could do downhill instead.
Like this for instance.
File Type: jpg
File Type: jpg
Mmmmmm, shiney.
cyclops is offline
Old 11-03-13, 06:30 PM
ed
ed's Avatar
Bikes: Hecklah
Ooooooo...like!
That one will work well. Heck if you don't like it, you can always drop it. My experience though...more travel = more smile.
ed is offline
bloom87
Classic & Vintage
17
06-12-22 12:10 AM
twocicle
Tandem Cycling
43
04-09-13 08:10 PM
terrors
Classic & Vintage
12
02-19-12 11:48 AM
TheYoungBikeGuy
Mountain Biking
25
10-13-11 11:09 PM
Ultraspontane
Singlespeed & Fixed Gear
19
07-01-11 09:03 PM
