Removing V brake posts
Santana Couple
Can the V brake post on a Santana be removed? I recenty installed a rear disc brake and would like to remove the post to clean up the frame.
pan y agua
Quoted: 1459 Post(s)
Liked 735 Times
What material is the frame made of ? You could hacksaw them off, file them down smooth and use touch up paint.
I wouldn't do it, however.
1) it eliminates the option to go back to V brakes, or to run a V brake and a disc.
2) it will hurt resale value.
3) you could potentially mess up the frame in the process.
You could get lost and die.
You could hit a tree and die.
I took them off of my Team Scandium that came with Dura-Ace brakes. Just unscrew them. I found some plastic plugs at the hardware store and capped off the holes.
Bikes: Custom 650B tandem by Bob Brown, 650B tandem converted from Santana Arriva, Santana Noventa, Boulder Bicycle 700C, Gunnar Sport
Quoted: 23 Post(s)
I agree with merlinextraligh. I have seen new tandems with unused rear canti studs and a rear disk. Options are good.
Bikes: 1998 Co-Motion Co-Pilot, 2015 Calfee Tetra
Quoted: 177 Post(s)
Liked 6 Times
I think they just unscrew. I recall that there are little flats on the post that could be removed with an open end wrench.
Quoted: 23 Post(s)
Santana Couple
Which model of Santana do you have and how old is it.
Mine is a 2007 Team Scandium and the post DO unscrew.
Before I did it I called Santana and asked before I put a wrench on it.
Been post free for Five years now.
Santana Couple
2004 Arriva cromoly There are no flat spots to put a wrench on. I had thought about inserting a bolt with two nuts to lock the bolt in place and then trying to unscrew the post.
Mine had wrench flats.
