Fork swap -- worth the hassle / risk to do it myself?
Going full rando on my roadie -- dynamo lighting, front rack and Swift Industries bag, etc.
Swapping forks on from an old 15mm to a 12mm Roadeo Spork with internal dynamo routing. Part of me wants to do the whole thing myself as a project and to save some cash, but while I've swapped non-carbon forks with mechanical (caliper or disc) brakes in the past, I've never set up hydraulic brakes, and never messed with carbon steer tubes before.
I'm thinking maybe I should just have a shop swap the fork and set up the brakes, since it needs a tuneup anyway and I'd probably have to take it in to get the tube cut. Then I can set up the dynamo lighting myself because how much can I really mess that up?
Any thoughts from those of you who've done this a lot?
Super-duper Genius
Quoted: 768 Post(s)
Liked 984 Times
Whether it's worth the hassle is a question only you can answer.
Do you enjoy tinkering and learning new things? Then the answer is "probably."
If you're more interested in getting the bike done so you can ride it, the answer is "no."
Likes For Broctoon:
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times
Swapping and cutting a carbon fork isn't a big deal, but it will require a a race remover and setter, a carbon-specific blade, and a cutting guide. Hydro brakes are similarly straightforward, but they require a brand-specific bleed kit and a hose cutter. So weigh out whether buying these tools or rolling their expense into the pro install would make more sense, especially if the bike's in the shop anyway. I would offer that the steerer-cutting tools probably won't be used often enough to warrant the investment, but a bleed kit might come in handy down the line.
Likes For Rolla:
Clark W. Griswold
Quoted: 4361 Post(s)
Liked 4,002 Times
If you are needing a tune up and not wanting to do it yourself just have the shop do it. It isn't ridiculously hard but isn't something I want to bodge. If you are confident and want to do it and have the proper tools to do it as @Rolla listed go for it but I would probably rather just send it to the shop and get the bike back faster and go riding on it. It sounds like a sweet set up. Post pictures when finished (and don't forget drive side is the important side.)
Likes For veganbikes:
Likes For cormacf:
Quoted: 1248 Post(s)
Liked 1,323 Times
Cutting a carbon fork is not a big deal. Just use a very fine hacksaw blade 32 TPI would work well. Then assemble the bike and measure where you want your fork length. Then use a sacrificial aluminum spacer as a guide and cut. Wear a tight-fitting N95 mask to be safe.
Likes For Atlas Shrugged:
Bikes: Way too many
Quoted: 900 Post(s)
Liked 607 Times
If you're going to do more of it in the future then go for it, but you'll likely pay way more for the tools than a shop will charge you.
Professional amateur
Bikes: Does a Big Wheel count ?
Quoted: 302 Post(s)
Liked 136 Times
I've done 95% of my own wrenching, for years now. But, for what the OP is looking at, I would personally be inclined to pawn that off on the pros.
Quoted: 1110 Post(s)
Liked 1,204 Times
For cutting a hydraulic tube, a nice sharp, stiff razor blade, cut carefully and square, avoiding excessive force that might crush the tube, will work fine if a person needs to cut it and doesn't have ready access to a cutter. Carefully, clean and square is not that hard to do, which is all the cutter does without having to be so diligent - i.e. it would be more fool proof.
The bleed kit is necessary as far as I can tell.
None of these tools are all that expensive, and I'm not recommending avoiding them. But I found myself not having ready access to them when I was doing these projects and have had perfect results.
As for the installation of hydraulic brakes - I'd never done it and just understood and followed the manufacturer's (Sram) instructions carefully and thoroughly. Two bikes, two years with no brake issues or need for re-bleeding.
I wouldn't discourage the OP from having a shop do all this, but the installing of the fork and hydraulic brakes - including bleeding - is just a new bike building/maintenance skill that isn't that hard to learn. But time and aggravation may make having a shop do it the best path.
Update: LBS will swap forks, cut the tube, bleed the brakes, and give it a full tuneup including wheel true and bottom bracket for $200. No-brainer to say yes to that. Thanks!
Likes For cormacf:
Quoted: 6974 Post(s)
Liked 10,975 Times
I'm not sure why the brakes are a problem; presumably, your old fork and new fork take the same sort of brake caliper, so just swap it over. If it's hydraulic, I don't think you'd need to bleed it again, assuming it's working properly. Or is there something I'm missing?
Clark W. Griswold
Liked 4,002 Times
Could be internally routed on one or the other which is a pain and while sometimes yes you can successfully do it without needing a re-bleed it is not bad to have it on the ticket just in case. Could also be old fluid and could use some changing it may not be mineral oil it could be DOT fluid.
Liked 10,975 Times
Likes For Koyote:
Quoted: 5224 Post(s)
Liked 3,585 Times
did a fork swap once. spent as much on tools as I spent on the low end entry level fork. it was an OEM straight replacement but I still had to learn as I went along
https://www.bikeforums.net/bicycle-m...rk-swap-2.html
Liked 1,204 Times
Liked 3,585 Times
- SR SUNTOUR XCT Mountian Bike Bicycle Cycling Fork 29er Coil Travel 100mm 9mm QR
- Bike Bicycle Fork Star Nut Setting Installer Install Tool with 2 Free Star Nuts - Size 1-1/8”
- Bike Bicycle Headset Fork Crown Race Removal Tool
- Park Tool SG-6 Threadless Saw Guide
I already owned a bike stand, hack saw, screwdrivers, nut drivers, Allen wrenches & hammers including rubber & wooden mallets. if you read that other thread you'll see how more experienced mechanics suggested alternates methods not requiring all these tools. but I used them & was glad to have them.
Likes For rumrunn6:
Resident PIA
Bikes: Gunnar Roadie, Look 765 Optimum, Spesh Aethos
Quoted: 212 Post(s)
Liked 356 Times
Star nuts and cf steerer tubes are not a good combo.
Shad
I knew where I was when I wrote this
I don't know where I am now...
05 Gunnar Roadie Chorus/Record
67'er
Shad
67'er
Likes For Shadco:
Clark W. Griswold
Liked 4,002 Times
don't think these are suspension fork specific
For a metal steerer tube a star nut setting tool is very helpful to have but "bike bicycle" is not needed Park Tool makes a fine star nut setter but Unior or Pedro's makes quality stuff. If you have carbon fiber you do not use a star nut setter but a compression plug. Typically your star fangled nut comes with the headset again if you are buying a headset of quality from a known quantity.
A crown race removal tool is also handy if you are moving from one fork to another but you can also get a new crown race from your headset manufacturer generally. Again though "bike bicycle" is not a thing. Park, Unior, Pedros...all make fine quality tools for the job.
A saw guide is nice however you can also use a pipe cutter as well. I do prefer hand sawing with a guide myself and that was an actual part from an actual tool maker so no worries there.
Posting a guide is helpful but just posting titles from Alibaba or Jeff Bezos is silly especially if you actually read them.
Basically most forks are all the same basic install. Things change minutely depending on steerer tube material but really it is all the same. Measure twice cut once if you are cutting and consider especially for carbon leaving a 5mm spacer on top but maybe just on anything or if you are unsure don't cut it till you are. If you are planning on selling the bike, go ahead and sell it now and get the bike you want. Don't just buy a bike to sell buy a bike that you will ride and enjoy for a while and if down the road you end up selling it the other owner can get a new fork or cut it down to their length as needed that is not your concern.
Liked 3,585 Times
Sort of wrong-ish only because they are posts from alibaba (and one is misspelled) or similar site for some of it. I wouldn't recommend buying a coil fork unless it is a high end one most of the cheap stuff just is a downgrade or if you already have one a grade from one same thing to the other. Get a quality air fork from a known quantity.
those are the tool titles directly from Amazon. just copied/pasted them
that's not a guide that's a listing of tools I bought
I provided a link to my fork swap thread that disscussed some of the details of the job
the coil fork was an OEM swap of what I already had. I thought it would make the job easier. I wouldn't mind a better fork of course
Clark W. Griswold
Liked 4,002 Times
just for some clarity
Get yourself a better fork. Easy peasy, your local shop may have them or can easily order whatever you need.
Update: The LBS is actually only charging me $140 for the tuneup plus fork swap. BB swap (my parts), new chain (their parts, at additional cost--but within a couple bucks of online prices). Well, plus a new olive for the brake line. But damn. They just earned a ton of future business.
Likes For cormacf:
Clark W. Griswold
Liked 4,002 Times
With a mighty wind
Quoted: 1089 Post(s)
Liked 868 Times
I do all my wrenching myself. I actually chuckle when someone says they’re “due for a tuneup” because so many of us never get a tuneup.
We’ll adjust something nearly every ride and regularly inspect and replace stuff.
It’s great because my bike pretty much always runs perfectly and if it doesn’t, it’s my fault.
I’ve done a small handful of hydraulic brakes. Had to buy a new kit for each one, and have always lost track of some of the kit by the time the next service comes along. It’s become the one thing I will bring the bike into the shop for. It’s not a fun part of bike fixing and frankly, I’m not that good at it.
Likes For rosefarts:
