Mid-Drives (crank drives)
Utilizing the same gears which the riders uses to achieve efficiency, mid-drives or crank drives make use of the same gears. The benefits compare to that of hub motors = greater torque, less amperage (significant less motor heat) longer battery life.
New Bafang Crank- Drives
Postby d8veh » Tue May 14, 2013 4:40 am
Bafang were showing two versions of their new crank-drives at the Shanghai show last week. The 250w version is available on Aliexpress as a kit now. I think the "750w" one was more to gauge customer opinion, but I'm sure it'll be available soon. I tried both versions in the area outside the halls, which is totally flat, but I was able to gain some useful info.
Both versions are smooth and quiet. No gearbox noise - just the normal motor noise. The 250w version felt a bit less powerful than a 250w hub-motor, but that might be just an illusion because you get a different feel between the high and low gears.
The 750w version had about the same power as my 350w 36v GeNG Gen 2 with 22 amps, although it was much smoother and quieter. It had a 48v bottle battery, so it was probably running with 15 amps. The two versions looked the same, but they told me that the 750w one was a little wider and had thicker wire.
https://www.aliexpress.com/item/8fun-mid ... 97760.html
There were also two other crank-drive motors at the show. One was from Ananda, which was a bit noisier, and another similar one - I forget the name. Both of these required a much larger (ca. 100mm) bottom bracket tube, so OEM only.
It seems to me that the Chinese are not very clever in their development. All the motors had crank-speed sensors on them to detect pedalling. Basically, they had applied their hub-motor technology to a crank motor, but then you get a problem with the motor running on after you stop pedalling, which messes up gear-changing. I reckon some customers had told them that European ones have torque sensors, so one or two had torque sensor versions, but they didn't change the controller software. It feels like they use the torque sensor to switch the power on rather than give a proportional amount. You still get the motor running on. They have to go some way before being able to compete with Bosch, Kalkhoff and Panasonic, but I'm sure that they're working on it. ref: Endless-sphere.com ? View topic - New Bafang Crank-drives
Concerns: As a motor, they're nice - very smooth and quiet, but the problem is the control system. It's adequate, but flawed. Basically, they've used hub--motor technology (sensors and controllers) and applied it to a crank-drive. The worst characteristic is that the motor runs on a bit after you stop pedalling, which keeps tension on the chain. The tension makes gear--changing a bit traumatic, and probably impossible with Shimano hub-gears. I tried one with a Nuvinci hub, and it was a perfect match because you can change gear under load.
Just to clarify, the only motors in production do not have torque sensors. This is why there is a slight delay when you stop pedaling and when the motor stops when using the PAS mode. According to Bafang, they were not satisfied with any torque sensors on the market so they are developing their own for this motor, but it is still 6 months away from production.
This video shows better the custom drive mechanism. The large aluminum sprocket among other components were CNC machined. You will see 2 motors mounted on a frame, the mounting brackets are custom made.
HI!
I just got my new Off Road 29er Electric Bike 48V 750W 29er Mid-Drive+9-speed+48V 12Ah Li-ion , this is the bafang 8fun motor... bought it directly from China, very fast delivery...(7 days)... up to 9 PAS modes and 9 gears... this means many combination for the same speed... I would like to have an amp-volt-power indicator to find out what would be the best gear ration to PAS MOde to use... Can I get this information from the original controler??? or do I have to add something to it...
Congratulations on your new purchase. To answer your question about the an amp-volt-power indicator for optimum cadence. I would check with a reseller.
If you would keep us informed on the mid drive Bafang 8fun - this would be helpful. To obtain a Bafang motor alone is difficult because of the Chinese distribution.
Chain line is way over to the right if any thing like the install on a bike in the LBS..
so what kind of hills can it climb? few seem to have much torque, its more about flat land speed & battling headwinds,
Quoted: 14 Post(s)
The Bafang kits are available as BBS01 with 250W or 350W and as BBS02 with 500W or 750W. There is a BBS03 on the way which if I recall correctly is 1500W.
Lots of variables in how it will climb - depends on weight of bike and rider and gearing on the bike but the 750W version on a properly geared bike should get you up just about anything. How much the rider has to help depends on how long the ride is and how big of a battery you want to carry. The kits are not as sophisticated as some pricier options but for many seem to be worth considering.
Bikes: none yet
I have a 750w/48v unit on a hardrock 29er and all I can say about climbing, is the one time I used 1st/34tooth gear (a very steep narrow trail) it wanted to wheelie more than go... But really proper gear selection makes a bigger difference with the mid-drive than hub motors.
Bikes: Spot Ajax w 750watt Bafang BB motor
I am running the 750 thru an Alfine 8 IGH. I thought about getting a Rohloff 500/14... But the additional gear range is all in the Low end... And the 750 already climbs 20% grades in 1st, 2nd, and 3rd. A Rohloff with the 750'wpuld be a great combo for a serious cargo bike that needed to climb.
on standard 7-10% grades I can pedal at 18 mph, no sweat, so the Bafang 750 is pretty ideal as a road worthy hill climber. Off road mountain bikers might want more ( 1500 watt Bafang? )
the 750 BB drive with a low geared rear wheel effectively doubles a fit riders power... So be advised that you are better off with a longer wheelbase bike. Those short coupled city frames will really tend to wheelie out from under you on the uphill in low gear.
Bikes: Aurelia*Bianchi*Cannondale*Colnago*Dahon*Giant*Haro*Lynsky*Monkey Faction*Origin8*Panasonic*Paramont*Peugeot*Ross*Schwinn*SE*Specialized*Trek
Quoted: 58 Post(s)
Liked 26 Times
Congrats on your new bike.
