Lejeune project complete
Quoted: 495 Post(s)
Liked 215 Times
I took the newly built-up Lejeune out for a ride this afternoon. I obtained the frame from BF member big chainring, and the tubular rims from Andy_K. The rest of the components came out of my parts bin or off my Gitane TdF, which I partially cannibalized for the occasion. The frame is beautiful--full Reyolds 531 with willow-leaf caps on the seatstay ends. It also has what I regard as the perfect amount of patina--some evident wear on the waterslide decals, and a few tasteful paint scratches (including some evidence of long ago chain suck), but not a particle of rust. The chrome is about perfect, and the paint has a lovely shine to it.
It rides very nicely--corners well and has no tendency to wander off-line when going straight. The gratuitous drivetrain photo is to show that a Simplex SX610 shifts onto a 32 tooth cog with no issues, somewhat to my surprise. (This is the "T" model, with the pivot at one end of the cage.)
My only concern about this bike is that it's really too good for me, at least in terms of cosmetics. Most of my bikes came to me in substantially rougher-looking shape. This will have to be my good-weather rig, I guess.
www.redclovercomponents.com
--Ogden Nash
--Ogden Nash
Likes For jonwvara:
Is this a red or orange frame? Either, it’s sure is Purdy!
Hoping you beautiful days for a very long summer!
Quoted: 495 Post(s)
Liked 215 Times
It's clearly red, but toward the orange end of red. It's been nice here lately, but I haven't been able to ride much for a while as a result of a nasty cut on my shin (gardening accident, don't ask). But I'm back in action as of today.
--Ogden Nash
--Ogden Nash
Señor Member
Quoted: 1548 Post(s)
Liked 1,504 Times
Great looking frame and setting for the photo.
Is that a Motobécane logo on the rear mech? Pretty rare. I think I'd cross the stem with both brake cables, so the rear enters its nds housing stop from that side of the head tube.
If I own it, I ride it
Bikes: Lejeune, Raleigh, Raysport, Jan De Reus, Gazelle, Masi, B. Carré, Springfield, Motobecane, John Howard, Greg Lemond, Andre Bertin
Quoted: 460 Post(s)
Liked 269 Times
You're hooked now.
Quoted: 1577 Post(s)
Liked 461 Times
● 1971 Grandis SL ● 1972 Lambert Grand Prix frankenbike ● 1972 Raleigh Super Course fixie ● 1973 Nishiki Semi-Pro ● 1980 Apollo "Legnano" ● 1984 Peugeot Vagabond ● 1985 Shogun Prairie Breaker ● 1986 Merckx Super Corsa ● 1987 Schwinn Tempo ● 1988 Schwinn Voyageur ● 1989 Trek 400 ● 1989 Bottechia Team ADR replica ● 1990 Cannondale ST600 ● 1993 Technium RT600 ● 1996 Kona Lava Dome ●
Quoted: 495 Post(s)
Liked 215 Times
I'll take up your suggestion on the cable routing. It doesn't show up well in the photo, but I drilled the stem to serve as a cable stop instead of using the usual headset-mounted Mafac hanger. The French headset that came with the frame--and is about the right age to be original--had less than half a turn of engagement for the locknut with the hanger in place, so I removed it to create more space. Drilling the stem would have seemed iffy to me, but in Jan Heine's tutorial on doing so--in BQ #51--he notes that he showed the drilled stem to Mr. A. Yoshikawa, the president of Nitto, who deemed it safe. That's good enough for me. Eliminating the flex from the usual hanger gives the brake a much stiffer feel, which I like.
--Ogden Nash
--Ogden Nash
Quoted: 4836 Post(s)
Liked 1,293 Times
Great looking bike and I like the build. Those are Lyotard Berthet platform pedals? I have a Mercier 300 I need to build up and I plan on using those pedals. I have a Moto branded simplex rear derailleur as well.
Señor Member
Liked 1,504 Times
Bikes: Raleigh Mojave 4.0
Quoted: 7 Post(s)
Beautiful color on that bike. It makes me want to pick up a vintage for my first road bike.
Enjoy
Enjoy
Quoted: 460 Post(s)
Liked 269 Times
Good eye! Yes, it's the Motobecane logo, though the derailleur is still Simplex branded. Thanks for not pointing out that the tire labels are on the non-drive side. I was so hyped up over my first-ever mounting of a set of tubulars that I forgot all about label placement. I'm lucky they at least ended up on the same side.
Great job with the build. I coveted that frame when Big Chainring had it for sale. Enjoy that thing.
Quoted: 6762 Post(s)
Liked 1,364 Times
Damn, that's awfully nice. I remember admiring those bikes back when they were sold. I saw quite a few in Central Park.
Quoted: 495 Post(s)
Liked 215 Times
The key things, I thought, were starting the hole in the right place so it's centered from side to side in the stem extension, and along its length so the cable runs parallel to the headset between the stem and brake. Heine's directions about how to measure for that are useful. The only change I made was to the drill bit sizes. The author says to use a 1/16 or 2mm bit to make the through-hole for the cable. I found that a 1/16 was too small--the cable I had didn't quite fit--so I upped it to a 5/64, which is just a couple of thousandths (of an inch, sorry, mixing units) smaller that 2mm. I also found that a 5/32 was the right size for the shallow counterbore that accepts the stripped end of the housing--it gave a nice non-sloppy fit. The suggested bit size would have been a bit big for the cable I used. I would check the hole with a block of wood or whatever before drilling the actual stem--different brands of cable housing probably differ slightly in size.
When drilling the cable hole, it really helps to clamp the stem in a vise as suggested, so the quill is vertical. That way you just have to eyeball the drill bit so it's vertical, which is a lot easier than drilling at an angle.
It would not be hard to make a simple plywood fixture that would let you do all this with a drill press, but the cheap old Sears press in my shop didn't have the capacity for it. Attacking an expensive (by my standards) piece of hardware with a hand drill was a little unnerving, but it came out fine.
--Ogden Nash
--Ogden Nash
This tutorial is so damn timely I can’t believe my good fortune!! Beautiful build job.
