Cartridge BB installation, genius!
Quoted: 499 Post(s)
Liked 218 Times
I will now describe a stroke of towering genius that came to me recently while replacing a bottom bracket cartridge. I expect I will soon learn that it's a trick that everyone else here already knew, and is considered to be so obvious that it scarcely bears mentioning. Ah, well.
When removing an old cartridge bottom bracket, or installing a French- or Italian-threaded one--either of which has to be really tight to keep from working loose--I have always struggled, usually successfully, to keep the splined BB tool pressed tightly enough against the splines that it doesn't slip and damage them. I hate it when that happens.
The other day, it occurred to me to insert an M8 bolt in the square hole in the top of my Park BB2 bottom bracket tool--which ordinarily accepts a 3/8" drive ratchet--and thread the bolt into the spindle of the cartridge BB, making the dreaded slippage impossible. I used a 35 mm bolt, which was a good length for the long triple-crank cartridge I was removing. A 40mm might be better for a short double cartridge. It only has to be screwed in finger tight to keep the tool in place. Cranking the bolt down wouldn't hold it any better, but would probably damage the seals on the cartridge. I put a washer under the head of bolt before screwing it in, but I forgot to include it in the photos below.
Of course, you can't use a ratchet with the tool now, but that doesn't matter--you just grab onto the wrench flats with a big adjustable. I see from the Park catalog that my BB2 is apparently no longer in production, but the current model, the BB22, looks pretty similar. The same approach would work, I imagine, although it might require a longer or shorter bolt than the one I used.
That's it. I hope this is news to someone.
www.redclovercomponents.com
--Ogden Nash
--Ogden Nash
Likes For jonwvara:
Quoted: 715 Post(s)
Liked 474 Times
That’s a tip I did not know but will certainly use. Thanks!
Quoted: 6776 Post(s)
Liked 1,374 Times
Likes For noglider:
Bikes: 1973 Jack Taylor ToB, 1974 or '75 LeJeune Champ du Monde (possibly from the Carre Shop), 1971 Motobecane Le Champion, 1980s Rodriguez frame (future 650b conversion project)
Quoted: 37 Post(s)
Liked 6 Times
News to me, too. Thanks for the tip.
It does mirror the tip of using a quick release skewer to hold the freewheel remover tool on the freewheel without slipping, but despite knowing that trick I wouldn’t have thought of this BB installation tip.
best,
best,
Quoted: 2053 Post(s)
Liked 1,406 Times
I had a version of the tool that Tom shows, which consists of a long arm for torque, a splined tool, and then rotating in the center of that, a bolt for threading onto the BB spindle. Worked really well to keep the splined tool snug; unfortunately, I broke it trying to get off a particularly stubborn cup. I’d buy another if I could figure out who made it.
Likes For nlerner:
Bikes: 1964 Frejus Tour de France, 1964 Huffy Sportsman 3 speed, 1972 Schwinn Supersport, 1983 Trek 700, 1985 Centurion Ironman, 1989 Miyata 1000LT, 1991 Bianchi Boardwalk
Quoted: 164 Post(s)
Liked 92 Times
Nice
I’ve put in exactly 1 sealed BB. I was a bit disappointed as I bought the Park tool and the BB was a Shimano UN55. What the heck, the tool barely contacts the splines. Tapped a bit with a hammer and didn’t get too carried away.
I just figured my tool or the BB just didn’t match up well. I would think the beauty of the spline setup was the easy availability of lots of contact area even with some manufacturing slop built in. Oh well. I will remember that.
I got excited about this and felt stupid for not trying this myself.
Then I looked at my splined BB tool, branded Nashbar - sadly it doesn't have any wrench flats.
I always thought the design was rather silly, putting the ratchet so far outboard of the small engagement of the splines leads to a lot of force and torque that doesn't work towards the goal of tightening or loosening the BB cups. That and the drive socket is larger than normal, such that I have a wrench that I use only on that socket. I left a perfectly good Shimano BB with the plastic cup inside a trashed frame just because I couldn't get it out. I guess I'll just pony up for a better splined tool with wrench flats.
Liked 1,374 Times
Good point, @sd5782. They really missed that opportunity stupidly.
Ride, Wrench, Swap, Race
Quoted: 1026 Post(s)
Liked 442 Times
Diego Frogs made a good point about how the force on the wrench handle is not directed in the plane of the spline engagement, so the force is not just torqueing the cup, but also trying to rock the tool out of engagement!
Solutions are many:
If a long and fine-threaded M8 bolt isn't handy, use all=thread through the entire bb spindle and with large washers.
A longer wrench automatically improves the torque versus the unwanted rocking force, but any square-drive adapters make things worse.
I've used a swivel-headed ratchet to move the handle into the plane of the spline engagement, which helps keep the splines from rocking out of engagement.
And using my 18" adjustable wrench on the flats of the tool, I can tilt the wrench handle inward toward the plane of the splines.
Note also that Park's newer tool with the huge hole going through it is a lot shorter in height, so by itself this improves matters.
I am also recalling an aftermarket titanium socket-headed bolt with M8x1mm threads taken from the head of a Super-Record seatpost having enough threaded length to be useful here.
Solutions are many:
Used to be Conspiratemus
Quoted: 283 Post(s)
Liked 233 Times
Doesn’t matter if the trick was widely (or little) known. It was a novel innovation for the OP, he figured it out, and shared it. Full marks and thanks.
Bikes: 92 Colnago Master PIU, 85 Fuso, 92 Bridgestone RB-1, 83 Pinarello Record, 92 Tommaso, 92 Merckx MX Leader, 90 Serotta Colorado II, 99 Tommasini Sintesi, 90 Pinarello Montello, 89 Tommasini Super Prestige, 08 Look 585 and 8 more
Quoted: 271 Post(s)
Liked 219 Times
Been using that 'trick' for many years. Glad you mentioned it though in case others weren't aware of it.
Quoted: 2130 Post(s)
Liked 1,213 Times
You'd be surprised how often that happens in 25 years as an auto mech/tech, let alone a lifetime of wrenching.
Looks like you could still use a deep socket and ratchet on the tool with bolt in place.
SE Wis
Quoted: 1484 Post(s)
Liked 981 Times
I keep the bolt with the tool. I have a big socket that I can use even with the bolt installed on a BBT-22 tool. I've needed some serious torque to get some out.
Likes For dedhed:
Liked 1,213 Times
Mr. Anachronism
That beats my big C-clamp trick by a mile! Thanks for sharing!
Disraeli Gears
I wasn't aware that either threaded retainer needs to be all that tight with a cartridge bearing BB. I have some IRD French and Italian (and Swiss) threaded/splined retainers (sold as accessories) that are aluminum, though I haven't installed a BB with them yet. And the NDS retainer on many budget-level Shimano cartridge units is plastic, for Pete's sake! I only have one cartridge bearing BB installed, with steel retainers, but it's been fine for years, and I don't remember installing it really tight (like tight enough to use a torque wrench) -- in fact I think that the instructions even warned against over-tightening.
Of course if an existing unit has been installed using the overkill method, ya' gotta remove it!
Mother Nature's Son
Quoted: 443 Post(s)
Liked 434 Times
Great example of someone problem solving, wondering why it took so long to find the solution, realizing it is most likely not a novel idea, and then posting it anyway because it just may help someone else. Truly good solutions do not get old. Kudos to @jonwvara.
Brilliant!
Last new bike 1991
Last new bike 1991
In the wind
I've had to do that a couple of times. I thought I read about it on Sheldon's site.
Groupetto Dragon-Ass
Bikes: https://mcaf.ee/hsm2z
Quoted: 284 Post(s)
Liked 191 Times
Don't forget that after a bunch of force out at a long distance from the BB, the tool will start to get rounded ends.
You can always take it to the grinding wheel and trim some off the working edge to a place that's square again.
And like I said on the freewheel removal thread this week. IMPACT DRIVER!
Liked 442 Times
Good point Chuckk, about inspecting the working end of the tool for rounding.
I imagine that problems can be prevented by first cleaning the splines out so the tool goes in all the way. The way I do this is to simply tap the tool inward with a small hammer, which makes a different sound when the splines hit bottom.
