Excellent water bottle cages - cheap
I use the Cateye BC100 cages on most of my bikes. Inexpensive, functional and durable. Can usually find them for around $8.
Annoyed.
And I just paid extra for a Chris King titanium crown race, so I can see myself being crazy enough to eventually shell out the insane cost for a pair of these...
Quoted: 2219 Post(s)
Liked 2,838 Times
If I didn't already have all the cages I need, I would buy those King ti cages.
Likes For Koyote:
Annoyed.
The nice thing about King cages is that they come with a lifetime warranty, though you will likely never need it. So, if you are younger, it is easier to justify $60 each for water bottle cages. Bought my first King Cages while in my early forties, and they are now on their third bike and have been used for >40k miles - and I've never had to even tweak either of them back into shape.
Liked 2,838 Times
Annoyed.
Sniveling Weasel
Bikes: Rodriguez Racing Tandem, Fondriest Steelie, Bianchi Trofeo, Bianchi Infinito, Schwinn Varsity, Trek mtn
Quoted: 301 Post(s)
Liked 369 Times
The only criteria I see missing from above is the ability to easily reinsert the bottle when on the fly.
LBS talked me into a couple of new Specialized cages which do everything well other than remounting the bottles. Takes a bit more futzing which equals time with one hand off the bars. And when I used to go to a bar, I usually had one hand off it, so it’s not an unfamiliar feeling.
Rick Seattle-ish, Wa.
“He who fights with monsters might take care lest he thereby become a monster. And if you gaze for long into an abyss, the abyss gazes also into you.”- Fredrick Nietzsche
Bikes: '07 Specialized Roubaix Comp Triple, '12 Gravity Fixie, '21 Liv Rove 4, '06? Giant EB Spirit
Quoted: 90 Post(s)
Liked 40 Times
Likes For Symox:
Quoted: 12535 Post(s)
Liked 4,665 Times
Advocatus Diaboli
https://www.bikeforums.net/bicycle-m...-downtube.html
https://www.bikeforums.net/bicycle-m...ttle-cage.html
Sniveling Weasel
Quoted: 301 Post(s)
Liked 369 Times
Have never considered the rigidity of a bottle cage upon impact with the ground affecting the frame. When I have hit the ground, it’s usually the bars or my body, impacting the ground first. I assumed that since my cages were made of plastic or very thin aluminum they would flex or deform, but with carbon frames maybe those assumptions go out the window.
The dropped
Bikes: Pake C'Mute Touring/Commuter Build, 1989 Kona Cinder Cone, 1995 Trek 5200, 1973 Raleigh Super Course FG, 1966 Schwinn Deluxe Racer, 1960/61 Montgomery Ward Hawthorne "thrift" 3 speed, by Hercules
Quoted: 1390 Post(s)
Liked 690 Times
I've used 50Strong cages on a couple of bikes for two years. They work fine on the downtube -- just enough tension to hold the bottle but easy to use. Enough colors to suit most bikes.
However the 50Strong cages lacked sufficient tension to reliably hold my 24 oz bottles on the seat tube -- hard jolts on pavement or gravel would dislodge the bottles. So I switched both bikes to different cages with more tension on the seat tubes only. Those cages -- Tacx and some brand I don't recall -- had a little too much tension to easily grab and replace the bottle on the downtube.
So now I have mismatched bottle cages to go along with my mismatched bottles, and mismatched color accents in cables and bar wrap.
Likes For Unca_Sam:
Quoted: 1682 Post(s)
Liked 436 Times
My old Cannondale Six-13 was destroyed because the frame fell over and the weight of the full bottle pulled the rivets out and cracked the frame. Given the construction of the Six-13, which used carbon tubes pressed into aluminum lugs, it could not be repaired. But I was able to get a warranty replacement.
Quoted: 90 Post(s)
Liked 40 Times
One of my favorite features of these bottles is you squeeze and water comes out. When you don't squeeze the valve self seals - no need to pull out a button with your teeth and push it back in.
https://www.camelbak.com/recreation/...SABEgIe9fD_BwE
Comes in multiple colors. I find smoke helps me ride faster
Quoted: 90 Post(s)
Liked 40 Times
