Post Your Titaniums
#2976
The Yksion Elite Allroads are fine on tarmac, but the Gravel King SS/SK+ combo is better. When I'm doing more tarmac than gravel I do the Gravel Kings, when I know that's going to be flipped or know that it's loose fire roads & single track I go with the Yksions as they have more bite on the side wall. If I only had the Nox w/GP5K & Mavics I'd be content, but who wants LESS bike stuff??
Likes For Ramshackle:
#2978
Bikes: 2020 T-Lab X-3 w/GRX Di2, 2018 Trek FX-5S with GRX/Xt 1x drive train
Quoted: 29 Post(s)
Liked 21 Times
I've got about 1k on them so far and they look like new. Loaded up for touring will wear them a bit more, but consult the correct pressure for the load and surface 4-5k shouldn't be out of the question.
#2979
Stems?
I've got a Lynskey GR300 on the way and will have carbon Enve bars.
What do you folks think about stems? Ti or carbon would be nice but expensive. Basic aluminum would do the job but would it affect the ride quality? I had a Shockstop stem on my prior aluminum bike but think it might be too noodly on the Lynskey. Thoughts?
#2983
I have a Lynskey R300 and Shockstop stem. The combination results in an extremely smooth ride. Long rides are non fatiguing and the stress on my wrists has disappeared.
I have not noticed any "noodly" ride. Then again I am 145lb at 5'7" so your results may vary.
Likes For 1Lieutenant:
#2984
Quoted: 29 Post(s)
Liked 21 Times
#2985
Comparison Ti List
I have been a followed this thread for years...love Ti and just bought my 15 year old a new one. My question: with all the new companies out there making Ti bikes and all the changes in old Ti builders does anyone have a compare/contrast article to point to that details the differences, pros and cons from each? That would be a cool article.
#2986
Ride more, eat less
Quoted: 305 Post(s)
Liked 105 Times
Most people just want to know about the latest & greatest.. most titanium frames are built to last a lifetime, for 90% of performance needs of the masses.
The ultra-lightweight, super thin-walled ti frames may save a few ounces, but you really need a reputable frame builder with lots of experience to ensure the durability doesn't get compromised during the welding process.
Personally, after riding different ti frames for nearly 3 decades, I can't say that there are significant contrast to the overall ride quality between modern vs older (10+ y-o) ti frames.
If you can find a used ti frame at significant lower price than a new one, likely it's going to last you longer than you can pedal without accidents.
More importantly, to know for yourself what you're looking for in a frame, what is your intended purpose & how much is your budget for your next frame?
#2988
Mother Nature's Son
Quoted: 443 Post(s)
Liked 434 Times
I posted this Airborne Zeppelin back in 2018, but I just finished rebuilding it. It did have a mix of 9 speed Tiagra 4500, 105, Ultegra 6500, which I switched out to all 10 speed Ultegra 6700 components., except the 5700 STI levers. The crankset is 50/34 with a 12/28 cassette. I got a really good price on the group from a couple of different sellers. The whole group is in great shape with not much use. I also switched out the saddle, handlebar and tape, stem and bags, tires, and cables/housing. While I had it torn down to bare frame/fork, I used blue Scothbrite pads with Goo Gone, then soap and water, and then polished with wax and finally lubed all. The bike is looking really fine and everything is operating very well. Definitely going to put a lot of time and miles on this one in 2021.
#2989
My Merlin. I first posted images of this bike way back on page 5 of this thread I think, MANY years ago. Still going strong.
#2990
Bikes: Trek 970, Bianchi Volpe,Casati
Quoted: 256 Post(s)
Liked 33 Times
don't want to derail the thread, but with a budget of $2000 , what would be the best bike to get in titanium. I want an all day rider with some gravel capabilities. I never have had a titanium only steel bikes. used , new?? thanks in advance
#2991
Beyond Bogus
Quoted: 14172 Post(s)
Liked 2,608 Times
If you are comfortable building up a bike you could consider a used frame and get new components. BikesDirect also had some nice Ti Gravel bikes but they are out of stock and a higher price point.
Likes For datlas:
#2993
Thread Killer
Bikes: '15 Kinesis Racelight 4S, '76 Motebecane Gran Jubilée, '17 Dedacciai Gladiatore2, '12 Breezer Venturi, '09 Dahon Mariner, '05 Novara Big Buzz, '12 Mercier Nano, '95 DeKerf Team SL, '19 Tern Rally, ‘21 Breezer Doppler Cafe+, ‘19 T Lab X3
Quoted: 1304 Post(s)
Liked 288 Times
I have no titanium frame experience, but I’m very surprised to hear this, if only because I find a lot of evolution in steel and aluminum frames over the years, as well as changes and improvements in things like carbon forks. I mean, a 2002 Lemond Victoire just looks so different from an ‘18 Lynskey T2, with things like tube diameter and shape, larger headset bearings, and thru-axles being noticeable elements which have had profound impacts on ride quality in other frame materials.
#2994
Ride more, eat less
Quoted: 305 Post(s)
Liked 105 Times
Shaping & tubing manipulation in titanium is similar process that steel, but the tooling required are much more expensive and those tool fail at higher frequency than steel work tooling.
Cost to fabricate different shaped, tappered, non-uniformed diameter titanium tubes is significantly higher than steel or aluminum.
Seems to me the pinnacle of ti frame tube shaping & drawing had passed when large ti frame fabricator like Litespeed stopped making custom shaped & drawn 6/4 ti tubing.
Larger headset bearings, thru-axles, those impact that make frame stability under higher stress conditions do not apply to riders of ALL shapes & sizes.
If you're a lighter rider as myself, the "impact" of those improvements don't quite justify the cost increase, when compared to a used ti frame that can be found under $500.
#2995
Thread Killer
Liked 288 Times
Speaking of clarification, Litespeed still custom shapes 6/4 tubing for the T1SL bikes, and I’d see we’re seeing more Ti shaping going on now than ever before, I think. The Lynskey Helix frames are perfect examples of that, hosting not only the twisted 3/2.5 tubes, but some models diamond shaped 6/4 top tubes, forged chainstay segments, and ovalized tube ends. We’ve seen, upthread, pics of other makers at it, too, like the extreme shaping from T-Lab and the cool, one-piece, cast BB/chainstay yoke from J. Guillem.
#2996
Ride more, eat less
Quoted: 305 Post(s)
Liked 105 Times
Litespeed no long fabricate frames like Ultimate & Blade with full 6/4 tubing, rear wheel cut-out, tapered tubing from end to end.
For general population, non-sanctioned competitive cycling, recreational cycling, the benefits of ride character difference between a current ti frame vs used ti frame at fraction of the cost is something that should be considered.
Personally, I feel that ti frames (or cycling in general) are about value, since they are meant to last for a lifetime of riding, the least you spend to achieve your cycling goals, the better value you get in return.
If you can satisfy your cycling needs with a $500 used titanium frame that lasts you a lifetime, do you really need a $4k brand new ti frame with one-piece, cast B/B chainstays?
#2997
Thread Killer
Liked 288 Times
I don’t concern myself with other people’s needs or means, so most of the rest of your comments are neither here nor there for me, but certainly if someone wants to run wide tires and disc brakes on a Ti bike for gravel riding, yeah, they’ll “really need” to spend more than $500 for a 20 year old Ti frame and yeah, it might cost them $4k.
I guess an equally silly question might be to ask whether they really need a Ti frame at all when there are plenty of steel frames costing a lot less which will also last for a lifetime of riding.
#2998
Ride more, eat less
Quoted: 305 Post(s)
Liked 105 Times
I specified the Ultimate & Blade frames with rear wheel cut-out, no other frame in the current market offer the same feature on ti frames, due to the difficulty, tooling & man-hour required to fabricate such seat tube.
Carbon fiber frame may be easier to fabricate, but they certainly do not last a life time as ti.
Steel frame rust, they need paint to protect the frame & they do not cost a lot less, do not last a lifetime for most people living with rainy weather.
My Lynskey disc frame was purchased brand new under $500 from eBay back in 2018, posted many pages back in this thread, likely last longer than I can pedal.
#2999
Thread Killer
Liked 288 Times
Trolls are everywhere.
