How do you stop the SWAY?
Old 04-07-06, 07:32 PM
Patriot
Faith-Vigilance-Service
Patriot's Avatar
Bikes: Trinity, Paradisus, Centurion, Mongoose, Trek
When using a trunk rack on the back of your car, how do you all stop the bikes from swaying forward and backward when driving along, and you have to hit the brakes to stop, etc.
I figure, I can tie-wrap a stick to hold the two bikes apart, so they don't hit each other, but what do you use to keep the bikes from smacking into your rear bumper?
Just curious as to what you all do?
President, OCP
--"Will you have some tea... at the theatre with me?"--
Patriot is offline
Old 04-07-06, 07:38 PM
Dick Rhee
Shoebomber
Dick Rhee's Avatar
Bikes: 2008 Canyon CF Pro w/ Chorus, 2005 Moots Vamoots w/ Ultegra, 1988 Cannondale commuter
We used old tire tubes to tie the bikes down when we had a trunk rack. Suprisingly it works pretty well since it's somewhat stretchy.
Dick Rhee is offline
Old 04-07-06, 07:46 PM
Patriot
Patriot's Avatar
That's a good idea, but what I'm worried about is when I hit the brakes hard, if I need to. How do you keep the bikes from slamming into the car? I have a bottom brace on my hitch rack for my truck, but no bottom support for the car trunk rack.
President, OCP
Patriot is offline
Old 04-07-06, 07:49 PM
dekalbSTEEL
Well, duh, Mr Obvious.
dekalbSTEEL's Avatar
Bikes: see sig, and others
What type of trunk rack are you using? What type of straps securing the top tubes?
dekalbSTEEL is offline
Old 04-07-06, 07:56 PM
Nachoman
well hello there
Nachoman's Avatar
Quoted: 432 Post(s)
Liked 170 Times in 108 Posts
When I used a trunk rack I used to go for the theory of clamping them down at the top tube and bottom of each wheel, as tight as possible, to try and prevent any movement.
Nachoman is offline
Old 04-07-06, 08:23 PM
TrekDen
Double Naught Spy
TrekDen's Avatar
Bikes: 2010 Scott CR1 Comp, 2013 Scott Scale 960 MTB
The trunk rack I have has a mount that is shaped like a 7. The top of the seven sits under the top tube with a strap that goes over top, and the side of the seven goes down the seat tube with a similar strap. This keeps the bikes from touching, or swaying into anything. It's a Yakima rack, in case your wondering.
TrekDen is offline
Old 04-07-06, 09:07 PM
2manybikes
Bikes: 2 many
Quoted: 1174 Post(s)
Liked 215 Times in 101 Posts
To keep them from swaying,first get plenty of foam pipe insulation. Get a couple of sizes one that will fit on the smallest tubes on the bike and some for the big tubes. Put each bike so that only tire to metal contact, or foam to metal, (or foam to foam on your nicely painted bikes) is contacting. Carefully pad them and tie them so they are pinned against the bumper and cannot move. It takes a while to get used to it but I do on my four bike rack all the time. I'm the only one of my friends who never scratches a bike on the rack. I don't scratch the car either. HOWEVER I rarely put my best bike on a rack, you still may may mark the paint with the foam or just a rope rubbing on the bike. Tie them [B]solid and padded[B]
My suggetion is use the bike with the most expendable paint job on the bike rack. ? If you have one.
You may be able to tie to the lower part of the bike rack or go under the bumper to something solid. If there is a lot of space between the bikes or the bikes and the car, a couple of the old "boat cushion" type life savers can hang on the rack and make good bumpers. So can boat bumpers.
2manybikes is offline
Old 04-07-06, 10:29 PM
Comatose51
The Saris Bones ties down the seat tube to solve that problem.
Comatose51 is offline
Old 04-07-06, 10:32 PM
crackerjab
WTF is that smell?
+1
I bought this rack a few weeks ago and don't have a problem because of the seat tube strap.
crackerjab is offline
Old 04-08-06, 01:42 AM
62vette
Phat but not too fat
62vette's Avatar
Bikes: Kona Zing & Conder Cone
the plastic dog-bone thingies that velcro on between the rack tube and seat or down tube and then between the bikes does the job for me
62vette is offline
Old 04-09-06, 07:57 AM
andyandrews35
cinch em down
I lash them tightly to the rack. Cellulose sponges make cheap spacers. The bikes should not be dangling at all, they should be immobile. The rack has to have a bottom part. See https://www.stealthrack.com/home.htm
andyandrews35 is offline
Old 04-09-06, 08:53 AM
56/12 and 22/28
Stop it.
56/12 and 22/28's Avatar
Bikes: 2003 Specialized Hardrock Pro w/ slicks, flipped stem and HB, 2003 Colnago Dream with full Dura-Ace 7700 double, 2001 Bianchi XL Boron/Daytona, Mavic Open Pro/Campy Centaur/DT Champion built wheels.
I use a Saris Bones 3.
I don't worry about sway.
56/12 and 22/28 is offline
Old 04-09-06, 06:07 PM
Sooner Rider
Originally Posted by crackerjab
+1
+2. I also use a Saris Bones double. I bungee the front tire to keep it from spinning in the wind, put a sock under the pad that rests on the trunk, and rest the two lower pads against the license plate.
Sooner Rider is offline
Old 04-09-06, 06:13 PM
bbattle
bbattle's Avatar
Bikes: 2014 Trek Domane 5.2, 1985 Pinarello Trevisio, 1990 Gardin Shred, 2006 Bianchi San Jose
Quoted: 51 Post(s)
Liked 3 Times in 3 Posts
Well, there was no way I was going to let the Trek Fuel 80 touch the Orbea Dauphine so I bought one of these:
Bikes don't touch each other; they don't move, they don't sway. I can't accidentally crash them into the garage and I don't need a ladder to get them off the Element.
Bicycle Pictures
bbattle is offline
Old 04-09-06, 06:18 PM
Nachoman
well hello there
Nachoman's Avatar
Quoted: 432 Post(s)
But can you carry bikes for a family of five?
Nachoman is offline
Old 01-23-21, 07:39 PM
Encinitas Rider
62vette Hi, you mentioned this in an old post:
Talking about a product to keep bikes from swaying and hitting each other while hanging on a car rack.
What product is this? I can't find anything like it.
Thanks.
Encinitas Rider is offline
Old 01-23-21, 07:48 PM
datlas
Beyond Bogus
datlas's Avatar
Quoted: 14172 Post(s)
Liked 2,608 Times in 1,335 Posts
Thanks.
Thread is 15 years old, and 62vette has not been on the forum for 7 years. I hope someone else can answer your question but don’t get your hopes up.
Addiction is all about class.
datlas is offline
Likes For datlas:
