Apartment Dwellers - How do you clean bike?
Old 03-30-11, 05:47 PM
MooCow
For those of you living in an apartment w/no attached garage, how do you get your bike clean? Especially stuff like the cassette that requires degreaser. My current place has a good-sized balcony and I have been cleaning it outside, draining onto cardboard. The balcony at the new place is small. The inside is laminate, which is probably pretty easy to clean and I can put down something, but it's not ideal.
MooCow is offline
Old 03-30-11, 05:52 PM
ericm979
ericm979's Avatar
Clean the bike with paper towels and a mild spray cleaner (i.e. diluted 409).
Clean the cassette by removing it and wiping each cog off. If you use wd40 it'll take less effort but it will be a little stinky.
I did this when I lived in an apartment and didn't leave a single stain on the carpet when I moved out. But I am a very tidy mechanic. If you're not put down a drop cloth.
ericm979 is offline
Old 03-30-11, 06:03 PM
redtires
Extra Medium Member
redtires's Avatar
Bikes: Cannondal CAAD8; custom build carbon HT 29er.
Quoted: 9 Post(s)
I use rags and paper towels. The paper towels are simple to wipe down the frame with a little degreaser or similar cleaner. I do however use mineral spirits, a jar and bowl w/ a brush to clean parts like the chain, derailleurs, cogs, etc... I simply rinse and or wipe them down, the mineral spirits residue simply evaporate. Then re-lube and re-assemble...voila. I am quite careful about being clean and tidy as well...but I do this whether I'm at home, in a garage or in a shop.
Droping the hamer since '86
redtires is offline
Old 03-30-11, 06:08 PM
surgeonstone
surgeonstone's Avatar
Bikes: 1976 FRESCHI, 2004 Crumpton.
Quoted: 918 Post(s)
Liked 8 Times in 7 Posts
Back when I lived in an apartment I used to sit out in the sun and clean it outdoors. Nice way to cool down. A cloth, can of WD-40 ( I know, I know), and I was done.
surgeonstone is offline
Old 03-30-11, 06:22 PM
timeforheroes
Bikes: caad 9 5. pake track
I ride to the nearest car wash... pop in 5 dollars in quarters and clean the bike... then I detail the drivetrain on my porch
timeforheroes is offline
Old 03-30-11, 06:28 PM
DanMartin
DanMartin's Avatar
Liked 2 Times in 1 Post
Depending on if you plan on getting your security deposit back, some of us have been know to use the bathtub.
DanMartin is offline
Likes For DanMartin:
Old 03-30-11, 06:48 PM
pdxtex
Portland, OR, USA
pdxtex's Avatar
Bikes: kona paddywagon, trek 2.1, lemond nevada city, gt zrx
plastic tarp from camping store, check!
park repair stand, double check.
bag of latex gloves from my girlfriend's lab, you betcha.
simple green, rags, bike lube, yessiree.
the key for me is up keep. dont clean your bike once a winter or you will drive yourself nuts. once a week seems to keep the cassette and deraileur in check but i wipe down the chain and relube it every few wet commutes. i dont worry to much about chain maintenance though. i just replace them every 3 months or so.
pdxtex is offline
Old 03-30-11, 06:53 PM
veloboy971
Must Go Faster
veloboy971's Avatar
Bikes: Trek Madone 5.9, BMC Road Racer SL01, Orbea Aletta TT
Originally Posted by DanMartin View Post
Depending on if you plan in getting your security deposit back, some of us have been know to use the bathtub.
I live in the dorm and use the shower quite often. The awesome thing is that community bathrooms have cleaning staff
veloboy971 is offline
Old 03-30-11, 07:07 PM
DanMartin
DanMartin's Avatar
Nice!
Old 03-30-11, 07:17 PM
Inertianinja
Bikes: Felt AR1, Cervelo S2
Quoted: 14 Post(s)
lots of dirt - shower
less dirt - water/windex
chain and drivetrain: nylon brush + dish soap + sink
Inertianinja is offline
Old 03-30-11, 07:21 PM
dspaff088
Throttle
dspaff088's Avatar
Bikes: 2006 Tirreno Razza 3.0, 2007 Schwinn DH 2.0
+1
dspaff088 is offline
Old 03-30-11, 07:24 PM
Quel
Quel's Avatar
I've recently just been using Clorox wipes, then dry off the little remaining bit with paper towers. Seems to do a good job and doesn't drip.
Quel is offline
Old 03-30-11, 07:28 PM
pastoryusuk
Don't forget to be very careful around the walls if you are using sprays. Keep food and fishbowls covered too. Don't touch the walls if you have not wiped your hands clean. Keep the windows wide open if you can
I used a huge shipping box (cut it up, laid it flat) for a while, before that an old curtain. Just use something that seems like it will be too big (it won't...) and that oil/fluids won't leak through or roll off.
+1 to pdxtex's comment too.
pastoryusuk is offline
Old 03-30-11, 07:31 PM
alpha_bravo
Mr. Sparkle
alpha_bravo's Avatar
Bikes: 08 Specialized Allez Elite
I take mine to the local coin operated car wash.
alpha_bravo is offline
Carbon Unit
Live to ride ride to live
Carbon Unit's Avatar
Bikes: Calfee Tetra Pro
I don't live in an appartment but I could easily clean my bike in an appartment. I clean mine with rags and a spray bottle. I could clean the chain with one of those chain bath type cleaning gagets. As for the cassette, I would take the wheel off and clean it in the shower or bathtube and then wipe the wheel down with rags.
Carbon Unit is offline
Old 03-30-11, 07:36 PM
surgeonstone
Quoted: 918 Post(s)
I can not imagine the wrath I would face from my wife if I tried the shower/bath route. Papers would follow.
Old 03-30-11, 07:48 PM
v70cat
Bikes: S5 VWD & SL-7 S works Red.
Quoted: 52 Post(s)
Windex and paper towels
v70cat is offline
Old 03-30-11, 07:50 PM
Titmawz
Titmawz's Avatar
Bikes: Raleigh Record Ace, Windsor The Hour
Rags and a bucket with some water and degreaser
Titmawz is offline
Old 03-30-11, 08:02 PM
Machka
In Real Life
Machka's Avatar
Bikes: Lots
Quoted: 3160 Post(s)
Liked 419 Times in 252 Posts
When I lived in an apartment, I used the bathtub.
Simple Green, Avon Bubble Bath, and a tub cleaner ... and both the bicycle I was working on and the tub were gleaming.
Machka is offline
Old 03-30-11, 09:30 PM
adclark
What's a bike?
adclark's Avatar
Bikes: Bianchi Veloce
Just take it outside to do most of your cleaning. If you do work inside, be very careful and lay something down underneath your bike. Also, make sure not to touch anything before you wash your hands.
adclark is offline
Old 03-30-11, 11:08 PM
Mr. Fly
Mr. Fly's Avatar
Back when I lived in an apartment, the complex had two spaces in the common area parking lot (i.e., not assigned) that was designated as car washing stalls. These had a nearby faucet and a little more space around (like a handicap spot). I used those for washing my bikes. I also had a few friends who lived in houses, and they were kind enough to put up with me bumming water and space to wash my bikes when I need to.
Mr. Fly is offline
Old 03-31-11, 12:56 AM
K.Katso
Gold Member
K.Katso's Avatar
Bikes: Pinarello Dogma F8, Pinarello Bolide, Argon 18 E-118, Bianchi Oltre, Cervelo S1, Wilier Pista
Quoted: 33 Post(s)
On the balcony with one spray bottle full of cleaner/degreaser, one spray bottle full of water. I put an aluminum baking pan down on top of a piece of cardboard to catch the grease from the drivetrain, and the rest I just wipe with paper towels.
K.Katso is offline
Old 03-31-11, 05:02 AM
Nick Bain
Nick Bain's Avatar
Bikes: Caad8, Mukluk 3, Trek Superfly, Gary Fisher Irwin.
Quoted: 102 Post(s)
I use water bottles full of hot water to spray the dirt/sand off outside.
Nick Bain is offline
Old 03-31-11, 05:39 AM
banerjek
Portland Fred
banerjek's Avatar
Bikes: Custom Winter, Challenge Seiran SL, Fuji Team Pro, Cattrike Road/Velokit, РOS hybrid
Quoted: 232 Post(s)
Liked 51 Times in 33 Posts
This is a great way to blast all the lube out of your bearings and wreck components. Be careful with this.
banerjek is offline
Old 03-31-11, 07:12 AM
November Dave
November Dave's Avatar
Quoted: 40 Post(s)
Liked 24 Times in 9 Posts
Go to the hardware store and get a 5 gallon garden sprayer. They cost under $20. That solves your water source dilemma, it is a great substitute for a hose. Bonus - you can take it to cross races and use it for pit washes. The rest is just washing your bike like anyone else would.
For occasional light cleanups, use the wonderful Veloshine (www.veloshine.com) products. They are a sponsor of my team, and their wipes are great.
November Dave is offline
