Magnesium bike?
Old 10-30-14, 06:32 PM
Deontologist
Magnesium bike?
Paketa magnesium road bike 55cm
Is 1000 a lot for this bike?
Deontologist is offline
Old 10-30-14, 07:02 PM
KonAaron Snake
Fat Guy on a Little Bike
KonAaron Snake's Avatar
Bikes: Two wheeled ones
Quoted: 1217 Post(s)
Liked 198 Times in 113 Posts
I am not at all knowledgeable about magnesium or the brand, but $1,000 seems awfully high for a dinged 8 year old bike with 105.
KonAaron Snake is offline
Old 10-30-14, 07:07 PM
jwarner
Fahrradfahrer
jwarner's Avatar
Bikes: n+1
That baby is priceless.....
If you find yourself lost in the woods needing a good fire starter.
jwarner is offline
Old 10-30-14, 07:39 PM
krobinson103
Bikes: Nothing amazing... cheap old 21 speed mtb
Ever drop magnesium in water in chemistry class at school? I don't think a bike made of magnesium is a good idea.
krobinson103 is offline
Old 10-30-14, 07:49 PM
KonAaron Snake
I think they're mostly aluminum, but I'm not a materials expert by any means.
Old 10-30-14, 08:09 PM
Dave Cutter
Dave Cutter's Avatar
Bikes: '17 Access Old Turnpike Gravel bike, '14 Trek 1.1, '13 Cannondale CAAD 10, '98 CAD 2, R300
Quoted: 1571 Post(s)
Liked 10 Times in 7 Posts
Originally Posted by KonAaron Snake View Post
........ $1,000 seems awfully high for a dinged 8 year old bike with 105.
+1 My feelings exactly.
Dave Cutter is offline
Old 10-30-14, 09:05 PM
Scooper
Decrepit Member
Scooper's Avatar
Bikes: Waterford 953 RS-22, several Paramounts
Quoted: 621 Post(s)
Liked 38 Times in 33 Posts
The Paketa website says the material is "92% magnesium, alloyed with other metals to achieve optimal mechanical properties while facilitating the extrusion and welding processes."
In his series "Metallurgy for Cyclists" written in the 1990s, Scot Nicol (founder of Ibis) had this to say about magnesium as a frame material.
Originally Posted by Scot Nicol
Magnesium
Imagine a metal with half the density of aluminum, strength better than 6061, and elongation around 10 to 11 percent. I'm describing a magnesium alloy here, currently being tested by Easton. While magnesium is not normally known for its ductility, Easton says the material looks promising with those 10 to 11 percent elongation numbers. Although the modulus is low, in the range of 6MSI, that really shouldn't be an insurmountable problem. Aluminum has a relatively low modulus, but it doesn't mean an aluminum frame can't be built stiff. The same will hold true for magnesium, in fact a lower modulus would be welcome in the eyes of many.
One issue that needs to be addressed with this metal is the extreme problem with corrosion. Leave a magnesium part out in the rain and it will disappear faster than just about anything except unpainted steel. This problem can be overcome with proper surface treatment, like painting or anodization.
One of the intangible benefits of magnesium is that if you need to start a fire for some reason, just scrape some flakes off your dropouts, and light them up. They'll easily burn. For the mini- Hindenburg effect, just add water. The oxygen and hydrogen in the water disassociate, and party down with help from the magnesium. By the way, titanium does the same thing, but it's a little harder to get it started.
I think I'd pass.
- Stan
my bikes
Science doesn't care what you believe.
Scooper is offline
Old 10-31-14, 08:26 AM
Bianchigirll
Bianchi Goddess
Bianchigirll's Avatar
Quoted: 1933 Post(s)
Liked 712 Times in 448 Posts
This is likely the best known of the bikes marketed as a Magnesium frame, but I think lots of bikes were built with some kind of magnesium alloyed tubes. I always assumed Bianchis mangalloy stays had some percentage of magnesium in them. Wonder how many more times I can get magnesium in this reply to a post about magnesium?
I do agree the bike the OP links to is way over priced. It is likely only rare because that is the only one the seller has ever seen out in Hooterville.
Kirk Precision. These were a cast magnesium (one more) and were targeted at the TriGeek market in the late '80s.
Bianchigirll is offline
Old 10-31-14, 09:47 AM
repechage
Quoted: 1652 Post(s)
Liked 567 Times in 445 Posts
I am impressed that they found a way to weld even a magnesium alloy. It has been done, I know. Mercedes at LeMans comes to mind and the Porsche 917/30 allegedly had a magnesium sub frame which no one would admit to because of the LeMans Crash that had the Mercedes fly into the grand stand to horrific results.
repechage is offline
Old 10-31-14, 09:55 AM
Ex Pres
Cat 6
Ex Pres's Avatar
Quoted: 438 Post(s)
Liked 82 Times in 59 Posts
Pinarello Dogmas were magnesium up until the 2009 model year, except for the carbon seatstay and fork. In 2010 the Dogma went all carbon.
$5500 MSRP if you'd like to buy one NOS. Most distributors have marked them down to $4500 now.
Not saying a Paketa is a Dogma, but Magnesium is difficult & expensive to work with. That's why you don't see many of them, and [my guess] no more new production into the future.
72 Frejus, Holdsworth Record & special CNC / 74 Italvega NR / c80 ?French? / 82 Raleigh Intl MkII / 83 Trek 620 / 87 Centurion IM MV / 03 Casati Dardo / 08 BF IRO / 09 Dogma FPX / 10 Vassago Fisticuff
Ex Pres is offline
Old 10-31-14, 10:22 PM
Chombi
Chombi's Avatar
Bikes: 1986 Alan Record Carbonio, 1985 Vitus Plus Carbone 7, 1984 Peugeot PSV, 1972 Line Seeker, 1986(est.) Medici Aerodynamic (Project), 1985(est.) Peugeot PY10FC
Quoted: 142 Post(s)
Liked 10 Times in 10 Posts
Uhmmm.......I think it is sodium that explodes when dropped into H2O......
Chombi is offline
Old 10-31-14, 11:04 PM
ThermionicScott
7-speed cultist
ThermionicScott's Avatar
Quoted: 2791 Post(s)
Liked 731 Times in 514 Posts
Same here. I was all set to accuse them of just using "Magnesium" as a model name until I looked them up. I suppose if they can build millions of VW engine cases out of magnesium alloys, why not bicycle tubes?
Originally Posted by noglider
RUSA #7498
ThermionicScott is offline
Old 11-01-14, 05:35 AM
miamijim
miamijim's Avatar
Quoted: 373 Post(s)
Liked 29 Times in 25 Posts
+1. And for a no name bike it makes it even less the deal.
I owned one of the magnesium Pinarello Dogmas and it's an amazing bike. Crazy fast, very smooth riding, top notch in almost every way. Almost, it seemed to have premature BB shell corrosion from water/sweat collecting where the FD cable wrapped around the BB shell...it was heavy. When I bought it has already been ridden heavily by the previous owner, my guesstimate is that it had upwards of 50,000 miles on the clock.
For $1000-1200 there are a lot of nice name brand bikes out there....wait until the weeks before Christmas.
miamijim is offline
Old 11-03-14, 09:44 AM
Paramount1973
Paramount1973's Avatar
Bikes: Schwinn Continental, Schwinn Paramount, Schwinn High Plains, Schwinn World Sport, Trek 420, Trek 930,Trek 660, Novara X-R, Giant Iguana. Fuji Sagres mixte.
Quoted: 34 Post(s)
Liked 17 Times in 7 Posts
The 'mang' in mangalloy comes from manganese.
Paramount1973 is offline
Old 11-04-14, 10:33 AM
Bianchigirll
Bianchi Goddess
Not bad considering I am not 'smithy' nor trained in the arts of metallurgy!!
Old 11-04-14, 12:09 PM
Paramount1973
Quoted: 34 Post(s)
Not bad considering I am not 'smithy' not trained in the arts of metallurgy!!
You were close! It was certainly a logical deduction. I collect and use antique woodworking tools and one typically ends up reading some stuff about metallurgy in pursuit of this hobby.
Old 11-04-14, 12:37 PM
OldsCOOL
OldsCOOL's Avatar
Quoted: 627 Post(s)
Liked 427 Times in 234 Posts
Will never forget the moment. Such a spectacular mini fireworks display right in the science class sink. Mag wheels became aluminum for the hotrodders.
OldsCOOL is offline
Old 11-04-14, 01:21 PM
Bianchigirll
Bianchi Goddess
Well since no one else posted it. Personally I don't think the bike looks all that expensive, check out that seat post binder bolt.
Old 01-10-21, 06:31 PM
Mattdiano
Bikes: '83 Pinarello Super Record,'83 De Rosa Professional, '84 Guerciotti GLX7600, '91 Merckx Corsa Extra, 2004 Pinarello Dogma AK61 Magnesium, '13 Colnago World Cup, '14 Cinelli Experience, '16 DeRosa Planet
Quoted: 20 Post(s)
Liked 12 Times in 12 Posts
I have a magnesium Pinarello, AK61 and LOVE the ride it gives!!
Mattdiano is offline
Old 01-19-21, 03:05 PM
Frankgoose98
nice
Frankgoose98 is offline
Old 01-21-21, 03:09 PM
DMC707
DMC707's Avatar
Bikes: Too many to list
Quoted: 968 Post(s)
Liked 283 Times in 197 Posts
Cool stories bro's
DMC707 is offline
jdw777
Classic & Vintage
30
03-12-17 11:39 AM
jrickards
Classic & Vintage
29
10-15-12 02:43 PM
Jan Feetz
Classic & Vintage
36
12-10-11 07:13 PM
OGR8
Classic & Vintage
49
07-19-11 05:51 PM
dialdo
Road Cycling
3
07-06-10 01:39 PM
