fixing a drilled frame
Bikes: BMC SLR01; Cannondale Trail; Lot's of project and vintage bikes..
Quoted: 333 Post(s)
Liked 168 Times
This frame hit the first spot on the cringe-list.
someone drilled two holes for bottlecage, since im restoing it i need to fix.
They drill the upper part and the bottom part of the tube too...
As now i just can't braze soldering
Your English is better than my Italian, but I still don't understand what you're asking. You have a frame that someone drilled holes in and you want to fill in the holes?
I like cats.
Sounds fun! If you want to fill the holes with metal, you're going to need a repaint. If it's just cosmetic then I would think body filler or a plug would be the way to go, followed by some touch up.
Quoted: 2490 Post(s)
Liked 2,958 Times
If the idea is to return the frame to its original (hole-less) state, you might want to ask the moderators to move this thread to the Framebuilders section. (To do so, click the round red "Report" button at bottom left in any of your posts in this thread.)
If you're thinking of adding appropriate bottle cage frame fittings, do a search for, e.g., bicycle water bottle metric nutserts or metric rivnuts.
Likes For Trakhak:
Really Old Senior Member
A simple picture or 2 would make things much easier to know what you are talking about!
There's really no excuse other than to drag things out, although you seem to enjoy that.
You are capable of creating videos, as in the link below, so a couple simple stills should not be beyond your capability.
https://www.bikeforums.net/classic-v...g-process.html
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3890 Post(s)
Liked 6,491 Times
Likes For SurferRosa:
Happy With My Bikes
Quoted: 884 Post(s)
Liked 2,308 Times
It seems to me from the opening post, the OP is saying that whoever did the drilling, drilled through both sides of the tube. I agree with Tackhak that better answers will come from a frame builder. Filling four holes with metal is going to possibly heat the tubes in four spots and they may be better able to opine on what that heat will do to the temper of the steel.
The frame builder folks will appreciate pictures too.
Likes For Chuck M:
Henderson, NV
Bikes: Trek Alpha 3700, GT STS DH, Raleigh Grand Prix, Fisher Montare, Fisher CR-7, Fisher Aquila, Diamondback Sorrento, The Bike Beat Revolution, KHS XC 504R
Quoted: 322 Post(s)
Liked 596 Times
They drill the upper part and the bottom part of the tube too: I take that as they drilled through the upper part of the tube all the way through the bottom of the same tube = 4 holes total.
Likes For Desert Ryder:
Liked 2,958 Times
Or drilled from the underside of the down tube upward (at least for the lower of the bolt holes), because they couldn't fit a hand drill in the cramped space near the junction of the seat tube and the down tube. ("Yeah, drilling this upper hole was no problem. Now I'll drill the bottom hole----oops.")
Likes For Trakhak:
Quoted: 6198 Post(s)
Liked 4,814 Times
If the holes are in the proper place for a bottle cage to mount, then why not put some bottle cage bosses on it. Especially now if you are repainting it. You can get braze on threaded bosses for cheap or make them yourself.. Anyone that knows how to light a torch should be able to braze them on the bike. If it's an aluminum bike, then riv-nuts or something else will be needed.
But if you are bound and determined to fill them, then some sort of epoxy body filler or other type of filler that can be sanded. Be sure that the top hole isn't in the way of the seat post regardless of which way you decide to go.
Likes For Iride01:
Quoted: 332 Post(s)
Liked 747 Times
It’s anyone’s guess until pics are provided. While we wait, I’ll get the healthy debate started: how many holes does a drinking straw have?
Likes For bboy314:
Quoted: 333 Post(s)
Liked 168 Times
holes are not even simmetrical, and the holes are not round.
probably i'm going to use a rivnut if i'am able to find the correct size. Another solution is to fill with epoxy and glass dust and make a tread for some bolts.
The normal soldering is excluded and as i said before the braze soldering is excluded too since the local guy who usually can do now seems closed for a while... damn i definitely have to buy the stuff to make those kind of soldering.
if anyone has even done this job before please share any photos.
Quoted: 333 Post(s)
Liked 168 Times
the original owner must be very inteligent, spend lots of money for super record parts and then drill a hole instead buyng some bottlecage ties...
Happy With My Bikes
Quoted: 884 Post(s)
Liked 2,308 Times
Randomhead
Liked 3,700 Times
The first words that come to mind are "oh ... my ... god." At least I see why they drilled all the way through the tube.
Assuming the tube isn't cracked, I would probably braze a patch over all 4 holes. The patches on top would get bottle bosses.
Likes For unterhausen:
Friendship is Magic
Bikes: old ones
Quoted: 26427 Post(s)
Liked 10,382 Times
...what kind of frame tubing is it ? Is it butted, and light gauge steel, or some sort of thicker straight gauge steel ?
I have repaired both sorts of drilled holes, using bottle bosses in butted steel. But I have also just left the holes alone in an older 531 frame.
My previous owners only drilled two holes, though. I wish they hadn't, but they did.
OP is from Italy. My guess is the frame is a Legnano. Presumably named after the 1176 Battle of Legnano as the head badge depicts a solider in battle armor.
I run a bike coop that takes in over 500 bikes per year. I see several every year with owner drilled holes in them. Most get scrapped out or used for art projects. Some times a pair of holes is just 1 of many frame or part mods. Holes in stems or handlebars are never a good idea. One bike had some stickers (beer of course) over extra holes. Those extra holes are unlikely to affect the frame at that location. Down tube failures are typically at the bb or from the shifter mount area to the head tube. I've seen a few that cracked where the manufacturer drilled the frame for down tube lever mounts.
1970s-1980s Murray and Huffy bikes often had holes punched in the down tubes and the bottle mounts afixed with self-tapping screws. Crude for sure but at nearly no extra mfg cost.
One could put in 2 sets of rivnuts. There were plenty of touring bikes with a 3rd set of bottle mounts under the downtube. The holes should be plugged to keep water out of the frame.
Henderson, NV
Quoted: 322 Post(s)
Liked 596 Times
Generally bewildered
Quoted: 1152 Post(s)
Liked 341 Times
Agree that the down tube failure mode is not buckling in the middle - this part is generally in tension. Any crash sufficient to buckle that tube means you have more problems than water bottle holes. I'd remove the bottle hardware and inspect the holes, looking for cracks. If no cracks, the bike might be rideable as is.
For a more significant repair, evaluate the frame. Is it a hand-made lugged frame with high-end Columbus tubing, like a Specialissimo? Or a more unremarkable unspecified frame, like a Premio? (Assuming that the bike is indeed a Legnano).
If the frame is worth it, one could sand off paint, and silver braze small coupons of metal over each hole. But this would require a decent framebuilder and would be costly. And it would require paint touch up.
Quoted: 333 Post(s)
Liked 168 Times
But the owner want to fix it. As now I need to find the local prices and then let him do his choice.
Friendship is Magic
Bikes: old ones
Liked 10,382 Times
Riv-nuts usually require making the holes even larger than they are now. That's a disadvantage. But I don't know how big they are now.
