Chinabomb Disc Brake Road Bike Build
#251
I went for a bike ride today but didn't ride the Chinabomb. I needed some light exercise and having run 43 miles in the past 6 days, my knees needed a break. So I went for an easy spin on my Pedal Force stopping by my friend's workplace to grab a Bluetooth module (wife wants to try Rouvy/Zwift) then over to the bank. Winds were 18mph sustained with gusts in the 30s. The 40mm rims currently on the Chinabomb are not all that great in winds like that. The shallow aluminum rims on the PF felt virtually unaffected in comparison. I'm looking forward to having these new shallow rims built up even more now.
#252
Rims are in and weigh exactly what Farsports quoted! Once I get my hands on cleanly threaded nipples I'll be able to start build. The supplied nipples stink and won't fully thread onto a spoke by hand. Must have been anodized for too long or something. Hopefully Farsports can quickly sort this out for me or I'll just buy new aluminum nipples locally.
#253
To amend my post above, it turns out that I received Sapim Secure Lock nipples (Secure Lock nipples | Sapim). I can’t be the first person confused by these, or I might be but I think I have a reasonable excuse for it (didn’t ask for them so didn’t expect this feature). Onward with the build.
#254
Quoted: 7652 Post(s)
Liked 3,473 Times
The drama builds and builds ....
#255
Lest you become bored with my one-sided conversation I have going on, do know that the first production run of JJBP Tubestuffers (name subject to change) is in the works as well. And the third production run of HY/RD short pull conversion arms.
#256
Liked 3,473 Times
I actually appreciate the updates .... can't wait to hear what you design next.
#257
A lot going on at the joejack951 house lately (mainly finally finding a new house to move to that fits all four of us and our frequent visitors) which means my wheel build project has been put on hold.
But...I did receive a surprise on my doorstep today. Tubestuffers (real name TBD)! So...quick show of hands for some guinea pigs before I roll these out. I made 24mm and 23.5mm versions for now but plan to expand the line as deemed necessary. The insert will ship with everything needed to prep and (permanently!) install into your steerer tube plus a plug for the unused threads. Pics will follow soon.
#258
So who has:
1. a bike with a carbon fiber fork
2. a ruler
3. a Post-It note or similarly small square-cut piece of paper (~3" long x 1" wide (76mm x 25mm) works nicely)
4. the willingness to try a measurement method for me in exchange for a Tubestuffer
The 'method' is to form the small piece of paper into a tube, insert said tube into the steerer of the fork, mark the overlap, and then measure that distance with the paper laid flat using the ruler. The idea being that any change in diameter is multiplied by 3-ish (3.14159 etc.) so even without accurate calipers someone ought to be able to tell if their steerer tube measures 23.5mm or 23.75mm or 24mm, etc. by using that flat measurement divided by 3.14159.
Anyone?
2. a ruler
Anyone?
#259
Liked 3,473 Times
Ugh .... physics, math, mechanics ... don't we have people like that guy JoeJack to do this kind of work for us?
Interesting problem .... but I might attack it .... but since few of my bikes have non-proprietary forks ......
#260
Quoted: 4234 Post(s)
Liked 2,949 Times
So who has:
2. a ruler
Anyone?
2. a ruler
Anyone?
#261
I do have something else that might interest you, though. Any chance you have (with an adapter) or would like to use a modern 1 1/8" threadless stem on that bike with the threaded steel steerer?
#262
I wish I could somehow measure steerer tubes across the internet. Until then, get out your paper and ruler, please. If you don't want to fully install the insert, I get it. But maybe you'd humor me, measure your steerer then check with an insert to see how accurate that measurement was. You can keep it or send it back. It will give me some confidence moving forward at least. I know the part works. I am not sure that I can count on people to assess their own forks with basic measuring tools.
#263
staring at the mountains
Bikes: Obed GVR, Fairdale Goodship, Salsa Timberjack 29
Quoted: 394 Post(s)
Liked 197 Times
So who has:
2. a ruler
Anyone?
2. a ruler
Anyone?
I'll also just measure a few times with just paper and pencil and see how close it is (I have some calipers to verify)
#264
Liked 2,949 Times
1 1/8" threadless, carbon steerers only. Sorry for not being more specific.
#265
Awesome! I'd love to see the difference between your caliper and paper measurements. I was within 0.05mm which could have just been dumb luck but all I'm looking for is +/-0.25mm accuracy so I have hope. If you don't mind, measure first and report back that way I know which kit to send you. I have two sizes currently, hopefully one fits.
#266
Liked 3,473 Times
I will promise to probably do this .... and do you make an adapter for threaded/threadless?
#267
Thanks, probably.
I like to think of it more as a 'conversion' than an adapter. Still (slowly, make that glacially) rolling this one out but here's a preview (apologies for crappy pic):
This is the product (pic needs further cleanup and there is a silver version):
The product is a full cartridge bearing replacement headset, which after installation, leaves you with a 1 1/8" threadless tube for your modern stem. The tube can be easily trimmed, like a standard threadless steerer, to the desired height and used with or without spacers (yes, I have custom matching spacers, too, with o-rings on the ID to keep them from rattling as they don't see any preload like a traditional threadless system). The 'magic' of the conversion is all hidden from view but is really quite simple, just never done by anyone else as far as I can tell. Adjustment of bearing preload requires only hex keys. I can share details for anyone that deeply curious.
I have a -17° stem to put on the Trek and I did swap the black headset cap for a silver one (customers will be able to do this on an as-requested basis). I'll post better pics once it is all tidied up. I have yellow cable housing and want to put a silver crank on that bike, and maybe hard anodized gray rims, to make it more period-correct.
#268
Liked 2,949 Times
That is amazing. looks a lot classier than a lot of the ones out there.
That would probably look great with one of these: https://velo-orange.com/collections/...nt=53100153543
Assuming the clamp area is tall enough.
What is the required stack height on the threaded part? How does it engage the fork?
That looks like it'd be cool to play around with.
#269
Not sure what you mean by this. The whole headset gets replaced with this conversion. The lower part of the headset could remain stock if you really wanted. The main requirement is that the steerer on the fork needs to be 27-45mm longer than the headtube to accommodate both the stack height of this headset and to not interfere with the internal features (in the case of an overly long steerer). Note that the minimum length is much shorter than what is required to use a standard threaded headset so if you have a not-quite-long-enough-for-your-frame threaded fork laying around you may now be able to use it.
#270
Liked 2,949 Times
Study this cross-section image closely The upper threaded headset race is attached to the quill. Spinning the quill preloads the headset. Setting the lower wedge by tightening the top cap (with a hex key) locks the quill from turning and also from pulling straight out. No lock nut and big wrenches needed.
#271
I made 10 initial prototypes, one of which is on my Trek and a few others floating around on friends'/friends' of friends/trusted people's in the industry bikes. After a series of minor revisions, I went ahead and did a small production run of half black/half silver to the ISO standard. I'd like to expand and cover more oddball sizes eventually but this was enough money invested for now. I'm still working out packaging and marketing details but that doesn't mean they aren't for sale to interested parties
#272
Liked 2,949 Times
It's a really cool idea. The bike I would most likely use something like that on is JIS. If I used the bottom part of the headset that's there, I can't remember, would that fit on the top, or are the head tubes different size?
#273
Sheldon's claim, with which I can't really disagree, is that JIS frames will accept ISO cups basically without issue, given the small 0.2mm diameter difference. Given the loose tolerances of even good quality frames, this could be due to JIS frames typically having oversized headtubes, or it could come down to the ease with which a tube expands by 0.2mm under lots of pressure or both. I'll leave it up to you whether or not you want to use unmodified cups or JIS-specific cups which I can eventually provide (they'll likely just be ISO cups turned by 0.2mm if you want them any time in the next year). I can easily ream a crown race from 26.4mm to 27mm for you so that you can install a fully matching headset.
#274
Liked 2,949 Times
Fully matching headset sounds better. The one I have on there now is fairly low end (as are most JIS options at this point). How much are you planning on asking for your conversions?
#275
