Pump and gauge for fat tyres
I've got a Topeak Joe Blow pump that has served me well for years and is still going strong. However, the gauge on it is very approximate and more suited to high pressures. Plus, it'd probably take some effort to pump up large volume tyres.
Hence, I'm looking for a similar pump that's better suited for fat tyres, and a gauge to check the pressures more accurately. Any recommendations would be welcome.
Quoted: 6193 Post(s)
Liked 4,808 Times
Air compressor to put in the garage. If you want to take it with you, then high volume pumps might be a problem to carry on a bike.
Accurate gauge? Just don't compare any to another. But do look for one that max's out it's range not too far over what your desired pressure is.
Quoted: 1438 Post(s)
Liked 1,092 Times
Most air pump gauges use a common pipe thread and can be easily exchanged for another with a more-suitable pressure range. I took the small 160psi gauge off of my Air Hammer pump and replaced it with a large 60psi one, as I do not need pressures higher than 50psi. Much easier to read and better resolution. Easy to swap back if desired.
https://www.amazon.com/Topeak-Joe-Bl...s=joe+blow+fat
Quoted: 239 Post(s)
Liked 7 Times
I've been using the Topeak Joe Blow Dualie pump
https://www.amazon.com/Topeak-Blow-D.../dp/B0186OS7JW
it has dual pressure gauges, 0-30, and 30-80. So I can use it for both my Fat bike and Normal bike. Won't go high enough for a Road bike though.
Pretty happy with it.
I really wish someone would make a Fatbike Frame Pump.
Yeah, I realize it would take forever to inflate from empty, use the floor pump for that.
but the intent would be a portable frame pump who's gauge could accurately register 0-15 PSI ranges so I can make minor PSI adjustments based on the terrain....
My fat bike has Presta valves, so this limits getting a gauge with a low measuring range. I was considering using my existing pump to slightly over-inflate the tyres and then use a gauge with an air-bleed valve to reduce back to the desired pressure.
In fact, I have a very high quality tyre pressure gauge for my car but that is for Schrader valves so I cannot use that.
Perhaps a fat bike tyre pump with a 0-30PSI range that incorporates a bleed valve might be the best and simplest option?
@Wheever: I’ll check out the Topeak fat pump too.
@xenologer: I’ll look into that dualie.
I checked on the Topeak site and it does have an air-release valve for fine-tuning the pressure.
...I really wish someone would make a Fatbike Frame Pump.
https://www.amazon.com/Lezyne-Micro-...=AX1CXKBL37772
I have this 15 psi gauge and it shows the same value as my Joe blow dualie. so they seem accurate.
ultimately the actual number doesn't matter as long as you take the same gauge. it is a bit trial and error to determine the initial pressure that feels good. As kids we never had gauges and just pumped up to what felt good.... never had a problem.
Calamari Marionette Ph.D
https://www.ghmeiser.com/bicycle-gauges.htm
With a fatbike small changes can make a pretty big difference in how the bike handles. I can't tell the difference between 7 and 8psi by feeling the tire. On the trail that 1psi change is a world of difference.
I'll see how the Dualie pump works out. As others have said, some experimentation will be need to find a front and rear pressure that works for me. At that point I'll just note the values shown on the gauge and use those as the preferred values to set the pressures to.
That Meiser gauge is so difficult to get hold of in the UK! It is available on eBay UK but the price and postage costs are prohibitive at the moment.
I'll try to source a similar gauge that isn't so costly.
Bicyclerider4life
You can get a Presta to Schrader valve adapter at your LBS for a buck or two. That would let you use your good gauge, AND be able to use a gas station's or auto/tire repair shop's air hose if you wanted to.
"Whenever I see an adult riding a bicycle, I know there is hope for mankind." (H. G. Wells)
Meiser Presta Valve Dial Gauge Low Pressure Bicycle Tire Gauge 15psi PR15BX | eBay
Mostly harmless ™
Bikes: Heavy, with friction shifters
Quoted: 1107 Post(s)
Liked 216 Times
For the effort - how many tyres do you pump up each day? High pressure pumps are actually easier to pump with, you just make a few more strokes. If you need a pump for car tyres as well, then do get a higher volume one, but for bicycles - I see no need.
I've used the Topeak Dualie a few times now, both on my new fat bike and my cruiser. It works very well and has been great to use as I play around with the pressures on the fat tyres. The dual gauges really do work well, and is quite a clever idea.
Quoted: 340 Post(s)
Liked 275 Times
I treated myself to an all plastic Harbor Freight tire pump for $8.99 this year. Takes at least 30 strokes to get my fat tires up to 15 psi. It hasn't blown up yet getting to 80 PSI for my thinner tires. I like it.
Hope I never get a flat away from home on the fat bike. It's hard to break the bead on my tires. Had to get steel core tire levers.
