Penetrating oil
Bikes: 1977 Raleigh Record, 1987 Schwinn Prelude, 1971 Raleigh Record, 1988 Schwinn Traveler, 1967 (?) Carlton Super Course, 1959 Huffy Sportsman 3 speed, 1972 Raleigh Super Course, yet another 70-something Raleigh Record
Quoted: 50 Post(s)
Liked 18 Times
Penetrating oil
Liquid Wrench, PB Blaster, other penetrating oils -- for many years I have been using them with the assumption that they have some acidic, or otherwise corrosive component, that breaks down corrosion. Not sure how I arrived at this idea, no doubt someone else told me. And I've never thought they should be left as a final lubricant, or that not applying some other lube would leave ferrous metal in jeopardy of some long term damage from them. Is there any truth to this, or am I just wrong (again), and these penetrating oils work through some other action?
Quoted: 6191 Post(s)
Liked 4,807 Times
Never heard anything about acids. But your hands have acids on them and some claim that enough to damage bearings if you don't wash your hands before handling them. I don't keep up with it now, but when I was young, that was a common position in the aircraft mechanic conversations and racing circles. This was before the days of computer bulletin boards and forums.
Since you are asking about all, then I won't say for certain, but I doubt most use acids. They just have a particular formula of oils and modifiers that help the oil penetrate and spread instead of staying in a blob.
But since they are so light, obviously their lubricating properties may not be adequate for the part you put them on. Then the question becomes is there enough of the thinner penetrating oil left to dilute the other lubricant significantly or will the coating of penetrating oil prevent the grease from clinging to the bearing surface and doing what it is supposed to do.
Most of the website for those penetrating oils have a good write up about them. sometime you have to dig a little and even look at the MSDS data or such.
And don't forget about Kroil. Sometimes it works when the others fail.
Mad bike riding scientist
Quoted: 6218 Post(s)
Liked 4,214 Times
Iron oxidation (aka "rust") has a very porous nature so the oil can penetrate into it better than other kinds of oxidation. Rust is also softer than the metal it is formed from so it tends to break when force is put on it. If the iron parts can slide past each other, they can come apart easier.
Aluminum oxidation products, for example, are extremely hard and many even be nonporous. Think anodized aluminum. The aluminum oxide is also much harder than the underlying metal so it doesn't break and slide as easily. Penetration oils often don't work on aluminum parts for this reason.
You could leave the oil in place as it will still lubricate but the oil is so low a viscosity that it will eventually flow away or evaporate. Putting something like grease on the threads after you've gotten them apart will go a lot further towards keeping the parts from welding back together.
Stuart Black
Stuart Black
Quoted: 604 Post(s)
Liked 1,063 Times
I have a 70s British sports car with chrome and stainless wire wheels. Every year before winter storage, I coat the wheels liberally with WD-40, and leave it so all winter. I bought those wheels in 1995, they still look new. Never heard of any instance of WD-40 actually harming metal surfaces. Not sure on PB Blaster, my first choice on seized hardware.
Tim
Tim
Quoted: 2026 Post(s)
Liked 1,096 Times
There are "penetrating oils" that are more than low viscosity oil. "Ed's Red" was developed as a target rifle bore cleaner but has a great reputation as a penetrating oil. It's an equal volume mix of Kerosine (or OMS), Dexron ATF and Acetone. However, as noted above, no acids of any kind.
Quoted: 604 Post(s)
Liked 1,063 Times
Cyccommute's answer is way better then mine. I'd go with that. Tim
Likes For tkamd73:
Quoted: 50 Post(s)
Liked 18 Times
Sometimes I have come up with these ideas, and hold on to them forever, and have no idea how I got them. Sounds like this one is wrong. It's good to know -- I may have avoided using penetrating oil for this reason, and didn't need to. Thanks, folks.
Likes For Ol Danl:
Bikes: !982 Trek 930R Custom, Diamondback ascent with SERIOUS updates, Fuji Team Pro CF and a '09 Comencal Meta 5.5
Quoted: 1299 Post(s)
Liked 739 Times
i use a light coating of PB to remove/reduce Aluminum oxide on parts all the time... no ill effects, and the parts look MUCH BETTER!
Quoted: 50 Post(s)
Liked 18 Times
Thanks again -- looked up the MSDS for Liquid Wrench, PB Blaster, and Aero Kroil. Under ph, for each of them, it said N/A -- so, obviously not an issue.
Not exactly sure what you are asking, but from my experience, penetrating oil do nothing to "break free" seized bolts, seat posts, ... but once free, the oil helps lubricating the parts, for easier disassembly.
Liked 4,214 Times
In these cases, I sure that the NA means "not applicable" rather than "not available". They would have no pH since they are neither acidic nor basic nor can even ionize.
Stuart Black
Stuart Black
Likes For cyccommute:
Penetrating oils are just a low viscosity oils. Nothing corrosive in them. Most rust and corrosion has a lower density than the metal it forms from so the oil penetrates into the threads and lubricates them. This allows the parts to be separated because they can now slide past each other.
Likes For HerrKaLeun:
Likes For CycleryNorth81:
Generally bewildered
Quoted: 1152 Post(s)
Liked 341 Times
BTW, in at least one test (and I don't think its apochryfal), a 50:50 mix of ATF and acetone worked better than any pre-made product. But the acetone will strip your paint. I think a product called Kroil was the best commercial penetrating oil.
Bikes: 80's Schwinn High Plains, Motobecane Ti Cyclocross
Quoted: 108 Post(s)
Liked 30 Times
Tim
Tim
The WD in WD-40 stands for "water displacing formulation #40" It was specifically developed to get and keep moisture out of equipment. It's fairly ineffective as a penetrating oil except in relatively undemanding circumstances.
It's also great as a cutting lubricant /coolant when drilling, taping and machining aluminum. (just don't make the mistake of using it on steel particularly with a tap!)
BITD I ran a ceramics plant. We had lots of water around machinery so used a lot of it. I had to keep it locked up because it kept disappearing. Turned out some of the older women on the lines though it was good as an arthritis treatment.
They'd heard it fixed squeaking joints.
Best penetrating oil I ever got my hands on was some sort of aircraft hydraulic fluid that was repackaged and sold as penetrating oil. That stuff was like magic so of course you can't get it anymore.
Liquid wrench seems to be about as good as there is out there now. Also works as a tapping fluid for steel and stainless steel. Not as good as the old Carbon Tet based fluids though.
Location: Milwaukee-Chicago (Last stop on the North Shore Metra Line)
Bikes: 1975 Fuji 'The Finest', 1975 Fuji Super Road Racer S10-S,1980 SR 10-Speed, 1980 Fuji Newest, 1984 Araya 14-Speed, 1985 Bridgestone 500, 1986 Fuji 'Sekkei Series', 1995 Gary Fisher Kaitai MTB
Quoted: 131 Post(s)
Liked 12 Times
+1 for Kano's Kroil. The best there is. Is also the best gun bore solvent made. Lifts lead and copper residue off of a gun barrel in one swipe by breaking the bond from the metal of the gun barrel. It is not an acidic chemical.
Kroil also works well on spoke nipples that are stuck or cotter pins on cottered cranks, stuck nuts, etc.
Liked 739 Times
Patience, Dan... Patience...... and there's a point of no return for rusted stuff...
Bikes: CharlesraP
Steel is real
And of course, the VERY best penetrating oil by far, a mixture of 50% ATF & 50% Acetone.
https://www.youtube.com/watch?v=CESDxCloCoQ
I haven't had much joy with that far as seized stems go
Bikes: Too, too many....
Quoted: 125 Post(s)
Liked 130 Times
So far I have been lucky but on the rare occasion that penetrants have not worked, I have always had success with carefully thinning the wall of the stem with a drill and PATIENTLY using a hacksaw blade to further weaken the walls of the stem until it comes free.
Works with alloy stems and with alloy seat posts..... but i have never had to try it on steel.
Bink
Bink
