Stem Length
Old 12-17-06, 04:25 PM
Skullo
Master of the Universe
Skullo's Avatar
Quoted: 66 Post(s)
Liked 104 Times in 53 Posts
Stem Length
How does one determine stem length? Is it measured from center to center?
Skullo is offline
Old 12-17-06, 05:33 PM
seely
The Rabbi
seely's Avatar
Quoted: 16 Post(s)
Liked 3 Times in 3 Posts
Yes, center of the clamp to the center of the steerer tube.
seely is offline
Old 12-17-06, 06:34 PM
Retro Grouch
Retro Grouch's Avatar
Quoted: 1572 Post(s)
Liked 643 Times in 364 Posts
Well, there are a couple of different measurements in use.
I'd say that "extension" is by far the most common. It's the center-to-center measurement from the steerer tube clamp to the handlebar clamp along the length of the stem.
"Reach" is a little different. It's still a center-to-center measurement but it's on an imaginary line parallel with the ground.
Retro Grouch is offline
Old 12-17-06, 07:57 PM
Skullo
Skullo's Avatar
Quoted: 66 Post(s)
I bought a new (to me) road bike ) Fuji Roubaix Pro with a ritchey stem that is 100mm center to center. I want to replace with ritchey adjustable stem, They come in 80, 100 and 120 mm. I gave up the road bike a few years ago because of wrist and hand pain due to carpal tunnel. Should I stay with the 100 or make a change in stem length.I am not looking to put myself in an upright position as I realize that lower is better on a road bike. I got a great deal on this bike with 200 miles on it and really want it to work out. I have been riding a custom mountain bike that fits well and able to do long rides and centurys, but this geometry it way different in comparison.
Skullo is offline
Old 12-17-06, 10:28 PM
waterrockets
Making a kilometer blurry
waterrockets's Avatar
Bikes: rkwaki's porn collection
Quoted: 37 Post(s)
Liked 91 Times in 38 Posts
You should research bike fit as much as you can. Consider paying for a professional fit at a local shop.
Road bikes should be much more comfortable for your wrists than mountian bikes because you have so many hand positions available. The caveat is that if you're not producing enough power continuously, you will be bearing a lot more weight on your hands on a road bike. One trick some do to mitigate this is to leave the hoods further up on the bars so your "cruising" position is a little higher, then your drops still get you nice and low. (I tend not to like this setup because of brake lever reach in the drops but it's a really popular setup anyway)
waterrockets is offline
Old 12-18-06, 09:41 AM
onbike 1939
onbike 1939's Avatar
Bikes: Airnimal Chameleon; Ellis Briggs; Moulton TSR27 Moulton Esprit
Quoted: 3291 Post(s)
Liked 827 Times in 583 Posts
snip<One trick some do to mitigate this is to leave the hoods further up on the bars so your "cruising" position is a little higher, then your drops still get you nice and low. (I tend not to like this setup because of brake lever reach in the drops but it's a really popular setup anyway)>
I agree it can be difficult re reaching the brakes but there is a way.
Rotate the bars so that when sighting along the bottom flat, it is aligned with the rear dropouts. Bring up the brake levers so that they follow the level of the top of the bars. In this position the brakes should be easily reached using two or three fingers from the drops position. If you know this already, my apologies.
onbike 1939 is offline
Old 12-18-06, 10:14 AM
I_bRAD
Call me The Breeze
I_bRAD's Avatar
Bikes: 2004 Litespeed Siena, 1996 Litespeed Obed, 1992 Miele (unknown model), 1982 Meile Uno LS.
Liked 7 Times in 4 Posts
Parallel to the ground, or normal to the head tube?
I_bRAD is offline
Old 12-18-06, 10:38 AM
waterrockets
Quoted: 37 Post(s)
Well, the reach problem is related to the angle of approach for your forearm. With your wrists straight, elbows bent as normal, a pointed index finger should land up on the lever somewhere. Rotating the bars up isn't going to change the angle of your forearm and wrist when riding in the drops.
Old 12-22-06, 03:56 PM
onbike 1939
That may be true, but I was commenting on finding a position which allows you to ride comfortably on the hoods and the drops. I would have thought that both top tube length and bar height would have a bearing on reach.
Old 12-22-06, 04:39 PM
waterrockets
Quoted: 37 Post(s)
Sorry for the confusion, but I'm talking about reaching the brakes, not top-tube + stem reach! If you raise the hoods relative to the line your forearm draws past the bars, they are tougher to reach. You have to bend your wrist up to reach them. Your index and middle fingers should go straight to the lever if you extend them without bending your wrist.
Old 12-26-06, 03:20 PM
onbike 1939
+1
Old 12-26-06, 03:55 PM
Retro Grouch
Parallel to the ground. If you have a threadless stem that has a lot of rise angle it might have a lot of extension but very little reach. You have to be careful when ordering stems with big rise angles because, as you raise the handlebars, the handlebars keep coming closer to you on a horizontal line.
