Turning roadbike into a TT bike.
A friend/Teammate has an older (maybe 5yrs old) Specialized Tarmac Comp Carbon bike. He wants to make it a dedicated TT bike.
Any hints? What post do you guys recommend? Anything else he should be aware of?
Thanks in advance.
Thanks in advance.
Quoted: 2952 Post(s)
Liked 3,106 Times
Rear spoke cover
Forward seat post
Cowhorn/aerobars
Bar end shifters (nice but not necessary)
tri-specific saddle (nice but not necesary)
Forward seat post
Cowhorn/aerobars
In my experience, it is difficult to get the aero bars in the right spot on a road frame, specifically, it is difficult to get them low enough due to the high headtube. A TT frame has a much shorter seat tube/head tube compared to (effective) top tube. A road frame usually has a seat tube that is about the same length as the effective top tube.
Cat 2 Track, Cat 3 Road.
"If you’re new enough [to racing] that you would ask such question, then i would hazard a guess that if you just made up a workout that sounded hard to do, and did it, you’d probably get faster." --the tiniest sprinter
VeloSIRraptor
yes to both of those -
check the TT sticky for tips on cable routing and the TT bike picture thread for RX & DWJD's comments on aero-ness. A road bike can be plenty slippery, just takes some thinking and effort.
other than the FF post, I'd recommend the oval system for aerobars -
Being able to swap parts out each of the bars/stems/base/pads is really helpful as you figure out what do/don't like, does/doesn't fit, and most importantly - what used parts happen to be cheap on CL & the 'bay
Liked 3,106 Times
In retrospect, I should have done that. But a) I'm sentimental to the Old Gray Mare; and b) am running out of space/dollars/spousal tolerance to buy another new frame.
No matches
Bikes: two wheeled ones
Quoted: 1398 Post(s)
Liked 444 Times
Yeah. If you didn't like that bike, then the space/dollars comes out even I would think. Spousal tolerance I'm not sure.
AeroGut
11
09-17-19 08:57 PM
