What say you? New bike: Aero vs. Lightweight
Quoted: 3238 Post(s)
Liked 2,085 Times
Thats interesting. I had always read that being aero, which for many doing triathlons, was riding on the aero bars and being as aerodynamic as possible, didn’t matter unless you were up over 17-18 mph or so. I always had read and assumed that energy to gain speed is mostly an effort against the wind, thus it would make sense (to me) that aero tubing and wheels will have less effect at slower speeds and it’s only when you hit certain speeds do the frame and wheel design start to be beneficial. I’ve been know to be wrong though.
Likes For Steve B.:
Quoted: 1332 Post(s)
Liked 398 Times
climber has-been
Quoted: 3429 Post(s)
Liked 3,566 Times
A colleague’s Scott Foil is both light and aero. With carbon tubular wheels, it’s less than 14 lbs.
Quoted: 18883 Post(s)
Liked 10,646 Times
So if you do a 10 hour century, that's a lot of kJs that go into pushing through the air. If you go all in and cut your air resistance by 1/4, you've saved a lot of work, so if you're putting out the same power regardless, you'll finish faster. So far so good.
If you do a 3 hour century, being more aero is important, but at 3 hours you're not going to be able to shave much time. Impossible to shave more than 3 hours, right? If you were going to take 10, shaving 3 hours off your time is less than 1/3 the minutes, more doable. (I know the numbers are daft, I'm trying to make this easy to follow. You can math it out with real numbers.)
But it's really a matter of semantics. Below a certain speed, you don't care about speed, above a different threshold it's a drug and you want all you can get. 5 seconds is significant in a TT if it gets you on the podium. Saving 40 minutes on a long, slow recreational ride is numerically huge compared to those 5 seconds, but probably not significant to the rider.
Quoted: 741 Post(s)
Liked 412 Times
I was told that aero trumps weight at speeds down to about 12 miles an hour. That is why you see riders climbing with aero wheels, especially in the professional ranks.
Non omnino gravis
Quoted: 1528 Post(s)
Liked 718 Times
6-4 Titanium
Quoted: 92 Post(s)
Liked 36 Times
I’ve read an aero frame in reality gives you like a 1% advantage because the body negates most of that aero advantage. Aero wheels however give a bigger advantage...and of course body position and getting in the drops.
Quoted: 20810 Post(s)
Liked 9,456 Times
Which one is going to make you want to ride more?
Liked 10,646 Times
Liked 10,646 Times
But they probably had fake Stravas.
Likes For asgelle:
No matches
Bikes: two wheeled ones
Quoted: 1398 Post(s)
Liked 444 Times
Part of the diminishing returns at very high speeds has to do with the amount of energy required to go even a small amount faster. Their is a point where aero does not creat a big enough advantage to overcome the wattage required.
1) They're sponsored to ride certain brands (not super applicable in this case) whether they're best or not, and sometimes they'll take what they actually want to ride and make it look like something from the brand they're sponsored by.
2) They have a UCI minimum weight limit that is trivially easy to hit with high dollar frames and components, so they can either add literal weights to the bottom bracket area, or they can ride deep wheels that get them some aero advantage on the climbs and a significant advantage on the descents and flats.
I had this debate, ended up getting a lightweight frame and aero wheels (Emonda ALR disc frameset + Aeolus 5 wheelset). The wheels make a hell of a lot more difference than the frame.
Bikes: bikes
Quoted: 2622 Post(s)
Liked 1,429 Times
What's special about 18 mph? Do you feel any difference in a 10 mph headwind versus a 10 mph tailwind?
Bikes: Bianchi Oltre XR4 Celeste, De Rosa SK Pininfarina, Giant TCR SL, Giant Revolt Advanced Revolt 0 Gravel Bike, Trek Madone SLR, Cervelo R5 Disk
Quoted: 376 Post(s)
Liked 124 Times
My "Aero" Bianchi Oltre XR4 is 15.0-lbs with pedals, and bottle cages. In all fairness the brake calipers are lightweight Cane Creek EE brakes and saddle is raw carbon.
Likes For Noctilux.95:
Liked 6 Times
I've got a '15 Ridley Helium SL and a '19 Madone SLR both bought as frame sets and built with SRAM red22. Besides the proprietary parts, the only difference is shallow aluminum wheels vs 50mm carbon wheels on the two bikes. It is very hard for me to tell a difference between the two bikes except when I put them on a scale or lift them into the car. The Madone does feel like it goes downhill faster, but that is probably a placebo...
My advice, buy the bike that will make you want to ride it.
Likes For sour:
Liked 2,085 Times
