Stand when bicycle is folded
Hi my second folding bicycle doesnt have a stand under the seatpost at the base/bottom like my first foldie has and i dont know what that is called. I have been googling around and cant seem to see anything. My second bike is very small but when i fold it it hits the ground too much. The plastic around the crank set gets hit and since i am not very strong might break. This bike has some age to it so afraid it will crack at some point. Is there a proper name for this item. Oh also i think i saw somewhere there is a wheel that i can insert at the bottom where the seatpost comes through that once i have folded the bike i can use to push the bike along rather than carry. I think this is an either or situation. Maybe bromptons have this. I have only seen a brompton folded a couple of times so not sure
Stardust
hello my friend
i dont precisely know what you want.
maybe this?
NOVO Smart Scroll Pequeno Rolo de Rodas Para Bicicletas Dobráveis Assistor Reforço Rodas/rodas de Treinamento para SP8 BYA412 Bicicleta Dobrável
*https://s.click.aliexpress.com/e/RQbg10l
hello my friend
maybe this?
maybe this?
. Trying to sort out which is the best. I did see those on aliexpress after i posted this and yes could be a good solution. My tube is 33.9mm so trying to sort out if this item will be good for me. It seems to suggest in the listing it is minimum 34cm so that might not suit my bike. What do you think ...thanks
