Addiction 2021.1
#6101
Mostly Harmless
Bikes: Have two wheels
Quoted: 13694 Post(s)
Liked 4,520 Times
#6102
Mostly Harmless
Liked 4,520 Times
#6103
Mostly Harmless
Liked 4,520 Times
#6104
Quoted: 10234 Post(s)
Liked 5,178 Times
Breaking News***** 60 degrees on Tuesday, but more importantly no rain.
#6105
Quoted: 20808 Post(s)
Liked 9,450 Times
Likes For WhyFi:
#6106
Mostly Harmless
Liked 4,520 Times
#6107
Liked 9,450 Times
Today is one of those sunshiny winter days, with beautiful, clear blue skies, that tries to sucker you in to stepping outside... kind of like that one subway car that's empty of passengers, but full of hobostank, during rush hour. No - I will not be fooled.
#6108
Mostly Harmless
Liked 4,520 Times
Just put on a balaclava. You'll be fine.
#6109
VFL For Life
Bikes: Velo Volmobile
Quoted: 28577 Post(s)
Liked 1,849 Times
I have not been in AZ beyond four corners.
I should have been more specific. I have no public sidewalk.
The discussion got a little into fasting. On one hand it's good for the GI to rest, but on the other, if you go too long without feeding the gut bacteria, they start eating the mucus. So, it's complicated.
Not in the #QuasiNorth. The highs will be below normal all week. Also, no sun.
#6110
Klaatu..Verata..Necktie?
Quoted: 10397 Post(s)
Liked 11,855 Times
The Older Boy and I travelled 645 miles each way to see the 3985 Challenger, back during his "Obsessed With Trains" phase.
EDIT: Not just see, of course. We rode on the train it was pulling for a day, and they did a 'run by' for us railfans.
Likes For genejockey:
#6111
Liked 11,855 Times
#6112
Should Be More Popular
Quoted: 22572 Post(s)
Liked 8,918 Times
#6113
Liked 11,855 Times
In case I hadn't mentioned it here, I have 4 non-matching wheels for it. I just need to match ONE of them.
Fronts:
RX100 hub/Mavic 195 rim
105 hub/Mavic MA2 rim
Rears:
105 hub/192 rim
Ultegra hub/MA3 rim.
Probably the best match visually would be the RX100 front and the Ultegra rear, but the RX100 hub has crunchy bearings.
#6114
Liked 11,855 Times
Discretion is the better part of valor.
#6115
VFL For Life
Liked 1,849 Times
#6116
Quoted: 8261 Post(s)
Liked 8,996 Times
Funny you should mention that, because I was going through all the wheels I have for it when finally built up, and the one original wheel I have - the front - is the one that doesn't spin smoothly. So I looked online and found out how to take it apart. I can't see any problem with the cones, but now, in the absence of a cone wrench, I can't put it back together properly.
One of the cones was pitted in my Ultegra 6600 rear hub and finding a cone was tough until my LBS guy got a cone assortment from a shop he bought inventory from.
Likes For big john:
#6117
Liked 9,450 Times
While killing a little time this morning, I decided to set up a (non-studded) gravel tire on the front Assault wheel (the rear wheel currently has the trainer tire on it). I really should sell the Assaults, I won't get much use out of them, but I'm thinking about keeping them around to use on the Haanjo and to have them as spares for the Cervelo. Anyway, yeah - I mounted a gravel tire and... too much unbroken black makes the mid-depth rims and 38mm tires look too chunky (the censor doesn't like my alternative spelling ). Schwalbe does have these tires available in a tan wall, now, though...
#6118
Liked 11,855 Times
If it doesn't spin smoothly it could be that it was too tight or just dry. Sometimes the flaw in the cones is hard to see. You should be able to find cone wrenches pretty cheap, I think. If not, you could grind down a regular open end wrench of whatever size you need.
#6119
Bikes: Shmikes
Quoted: 10148 Post(s)
Liked 5,841 Times
I have had good luck finding bearing bits at randombikeparts.com. Cone wrenches are a must for the C&V crowd.
#6120
VFL For Life
Liked 1,849 Times
#6121
Bikes: Shmikes
Liked 5,841 Times
#6122
he said member
Bikes: yes please
Quoted: 2789 Post(s)
Liked 1,950 Times
Had a nice 9am group zwift with the goons. And then a 2 hour nap. Had to take a muscle relaxer for the last couple days for my back spasms. Makes me sleepy.
But even with that junk in my system I still managed 260 watts average.
looked at a house yesterday. Nice but too small, some weird stuff with the layout too.
I may have to up my sqr footage to 1200. 1000 seemed awfully small. All depends on what I can get for this place.
Agents coming by next weekend, to give me her opinion.
#6123
Quoted: 18397 Post(s)
Liked 15,492 Times
#6124
Liked 8,918 Times
#6125
VFL For Life
Liked 1,849 Times
