Anyone on a 29+ gravel bike?
There are a number of bike makers out there selling these. Gravel bikes built around 29x3" tires. I have a (possibly) irrational attraction to these. The look with the huge, large diameter tire is so great, but with my riding primarily on dirt/gravel roads, it's probably more rubber than I need to lug around so haven't made the plunge yet.
Just wondering if anyone out there has one of these 29+ gravel/adventure bikes and what your experience has been like?
Some links, because these bikes just look badass....
https://www.framedbikes.com/collecti...adventure-bike
https://www.wilier.com/en/products/u...el/jaroon-plus
Occam's Rotor
Quoted: 2366 Post(s)
Liked 2,331 Times
I have a 27.5+ (2.8") one.
Mine didn't come with a pogo-stick fork. Given that Lauf fork alone costs about $1K, that is quite a deal.
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
Both of those look like so much fun, especially that Framed Marquette.
Anyone knows how much the Marguette weighs?
-Tim-
-Tim-
Not really a bad weight given the spec.
What made you decide against it in the end?
Quoted: 18351 Post(s)
Liked 4,502 Times
Thanks for the links.
I'm hoping to build one soon, a bit different than those two, if I can ever get everything started.
Bikes: Schwinn Varsity
Quoted: 1931 Post(s)
Liked 742 Times
Not 29+
I am riding 29r with 2.25 inch tires on dirt roads, fire roads.... our gravel roads in So CA.
It's a XC bike.
Now we have skipped from the "should I go 40mm tires or stay with 38mm" to riding gravel on 3.0 inch plus tires.
The XC bikes are on their way out .. they are not in vogue at the moment, and God help you if you are running 2 or 3 plates with a front DR.
I am coining a new bike name. Not XC anymore, but "Overland" bike.... has 29r tires that will run good on pavement or dirt roads, mild single track.....
what a mountain bike was used for 30 years ago.
PS
That FRAMED bike looks hot, comes with 2.2 inch tires and boost (new terminology) hubs.
It's a XC bike.
PS
Occam's Rotor
Liked 2,331 Times
Advocate Seldom Seen.
I bought the (steel) frame and fork on clearance for $350 and built it up from there. It was the drop-bar version.
It can also take a suspension fork, but I haven't sprung for one yet.
https://advocatecycles.com/product/seldom-seen/
Liked 742 Times
Seldom Seen
Seldom Seen
FLIR Kitten to 0.05C
Quoted: 2349 Post(s)
Liked 406 Times
Several of my tent-circle use drop-bar 29er rigs....which is frequently needed as even 45mm tires is seldom "enough" to keep control and momentum on pea gravel, even when the ground is dry.
Wicked fun. Catch being, unless you're riding pea gravel surfaces or mud--it ends up being overkill...and you're not going to be moving very fast or setting speed records.
Occam's Rotor
Liked 2,331 Times
Quoted: 101 Post(s)
Liked 41 Times
That being said, I felt like when the tires spun up the bike could maintain speed pretty well, although it might be more noticeable if a lot of hills are involved. The best part is that not only can they go over about everything, the they can roll fast over a lot of stuff you wouldn’t normally. For example, when the county comes and dumps a thick layer of gravel for the next X miles, you can just barrel down that like it’s nothing.
I have thought a few times about going back to that 3” width, but no one stocks a wheelset with 29+ size rim on 135/170 qr hubs, and building up a set would be more than I’d want to spend for this low-end frame.
I think a bike like the Jaroon+ or a Fargo with 3” tires would be great fun. My dream bike would be something like a Ti 29+ Fargo, but with an inch or so less stack height in my size.
- Soli Deo Gloria -
Liked 736 Times
https://expeditionportal.com/
I've seen some bikepacking articles at that site. Most of the guys are into anything that gets people out to explore the land and would happily put a mountain or bikepacking bike on their gear list.
-Tim-
just keep riding
Quoted: 173 Post(s)
Liked 33 Times
I also have an Advocate Seldom Seen Drop Bar MTB. I''m running 27.5x3.0 WTB Ranger tires on mine and I use it mostly for buff singletrack riding and rougher dirt trails like Forest Service roads where more tire is needed than the 700c X 42 tires on my gravel bike. I want to try it out on some of the very sandy roads my friends in South Georgia and Florida ride when doing their bikepacking expeditions.
This bike is great fun on smooth and flowy singletrack trails, but the very few times I've taken the big tires out on mixed surface and more typical dirt/gravel roads, it felt incredibly slow and cumbersome. Gravel means different things to different people in different areas, but for what it means to me and around here, somewhere around 29 x 2.1" is the limit of what I'd consider fun. I'd sure like to try 29+ on the MTB trails, though.
sq025 by Benny Watson, on Flickr
Quoted: 101 Post(s)
Liked 41 Times
Just saw this posted over at the Riding Gravel forum.
Not 29+
It's a XC bike.
PS
It's a XC bike.
PS
raria
19
11-11-17 06:15 PM
thehammerdog
6
06-04-15 06:30 AM
Inpd
4
04-13-15 08:05 AM
Noonievut
15
07-15-14 02:52 PM
