View Poll Results: Shim it?
Yes
2
66.67%
No
1
33.33%
Voters: 3. You may not vote on this poll
Front derailleur shim, yay or nay.
Single-serving poster
Inner diameter, top pull normal, 34.9 to 31.8 i think.... Could this cause a problem for the small-ring on my triple? How about the chain-stay angle listing on the FD, could that cause an issue? We are talking $3 vs $30 and having another piece of equipment lying around!
Quoted: 5774 Post(s)
Liked 2,571 Times
your question is defective.
you ask shim yea or nay? so yes would mean it's OK to shim.
Then you ask whether shimming could cause a problem, so a yes would mean don't shim.
So what do you want yes to mean???
Meanwhile using a shimmed bigger clamp shouldn't cause a problem, after all if you had a bike with the larger seat tube and similar chainline it should work.
Chainstay angle relates to the swing-arm of a rear suspension, and deals with whether it could swing high enough to bump the FD cage. If it's unrelated to your bike feel free to ignore it.
FB
Chain-L site
FB
Chain-L site
Stop and think what a shim does. It allows you to install an oversize derailleur on a tube so that it keeps the same center line position as the correct size derailleur.
Apparently in some models Shimano is now selling only one oversize FD that comes with a set of shims to adapt it to smaller tubes. Obviously they could not do this if shims had any effect on the shifting.
cowboy, steel horse, etc
Bikes: everywhere
Quoted: 12762 Post(s)
Liked 7,674 Times
Last front derailer I got from the LBS required a shim. The shop guy found one (official Shimano FD shim) that supplied the necessary diameter increase and sent me on my way.
Quoted: 3375 Post(s)
Liked 5,512 Times
peugeot72
Bicycle Mechanics
8
06-01-15 08:09 PM
Lawrence08648
Bicycle Mechanics
3
05-20-12 04:32 AM
