700c Wheels fit my 27 inch Schwinns ?
I am looking to replace some old beat up rims and the market seems geared towards 700c if you want quality. Just for kicks I had the bike shop put a 700 C rim on my 86 Schwinn Prelude to see if it would fit without having to buy new brakes. It did. This was not the bike I wanted them for so I brought my 80 Voyageur in to see if it would match up as well. It did. So now I have so many options.
So my question is do both bikes come with long reach brakes stock or did Schwinn just set the brake mounts to work for both size rims?
My bikes: 1970`s Roberts - 1981 Miyata 912 - 1980`s Ocshner (Chrome) - 1987 Schwinn Circuit - 1987 Schwinn Prologue - 1992 Schwinn Crosspoint - 1999 Schwinn Circuit - 2014 Cannondale Super Six EVO
feros ferio
Quoted: 1390 Post(s)
Liked 1,322 Times
The simple test is to position the brake pads properly for 27" wheels (630mm rim diameter), then check to see whether the brake caliper slots are long enough to enable you to lower the pads by 4mm to accommodate 700C rims (622mm rim diameter).
Well I had been told or have seen it written so many times that you need to buy long reach brake calipers to make the switch that I was surprised that both Schwinn bikes worked with 700 c wheels. Just made me wonder if Schwinn just did something with the placement of the mounts or something?
Eyeballing my wife`s Le Tour and it looks like 700 will work on a 3rd 27 inch Schwinn as well.
Decrepit Member
There's really no hard and fast rule about which Schwinn models with stock 27" rims will work with stock brakes and which will need long reach brakes to work with 700c rims. Generally, 27" rim models that are designed to accommodate fenders have higher fork crown clearance and seat stay bridge clearance and therefore have higher caliper brake mounting holes (further from the wheel rims). These models are more likely to not have sufficient reach with stock brakes to accommodate 700c rims, but there are exceptions. The brake pad adjustment slots in most caliper arms are 15mm-20mm long, so 4mm additional reach is usually not a problem if the pad mounting bolt isn't lower than about the center of the slot when adjusted to work with 27" rims.
Cantilever brakes are different in that they're mounted on brazed-on studs, so fender clearance isn't going to affect where the studs are mounted relative to the wheel rim on the seat stays and fork blades.
Had no problems putting 700's on my 74 Schwinn Sports Tourer. From what I've read and seen the only Schwinn's that needed different brakes are the 87 - 89 Voyageur's that came with Dia Compe 983 Canti's. They only has a Min of 23mm to a max of 26mm of adjustments although there could be more.
Freewheel Medic
Quoted: 1452 Post(s)
Liked 2,184 Times
Just to be contrary, I mounted 27 X 1&1/4 wheels and tires on my '71 Schwinn Paramount P-13, which originally ran 700c tubular wheels and tires. But I also have 700c wheels on my '75 Sports Tourer and Voyageur II (which originally were equipped with 27 inch wheels). So it all depends on the frame and the reach of the brakes.
Glad it worked out for you on both the Prelude and the Voyageur.
Bob
Bob
Thanks for all the replies. So much knowledge in one place.
Well I must say it was very exciting to find out they would fit. Adding the cost of new brakes into the equation was a bit prohibitive. I have been going to different bike shops seeking old stock 27 inch wheels only to find the same old generic wheel sets. 3 bike shops told me I would need to buy new brakes including the shop In my neighborhood where they put the 700 wheel on to test it our for me. One shop in Chicago told me to try one on the bike to see if it would line up. He said sometimes it works. So when I was out for my ride I decided to stop into the shop and find out. The bike shop owner was a bit shocked that they fit without new brakes as well.
Quoted: 380 Post(s)
Liked 106 Times
Steve unless your Prelude is odd it should have come with 700c wheels when it was new. At least the Prelude I own does. Couple of my 1973 SS with 700 wheels. Roger
Must be an odd year. Mine came with 27 X 1 inch rims. The 1986 catalog confirms it.
Motorcycle RoadRacer
Quoted: 789 Post(s)
Liked 1,739 Times
Simple answer the majority of Schwinns 90%+ made with 27inch wheels will readily take 700c's stock brake wise. The reason for this is Schinn approved components where speced to potentially work with the majority of there bikes sold which included a lot of 26 inch models which ment they needed a large degree of variance on the brakes.
Here is my 1986 Schwinn Prelude that I caught for $50 off Craigslist. It had a bent rear wheel. I quickly threw some old 700cc wheels that I had laying around the garage.. It was supposed to be my #2 beater, but it rides too dam good.. I said all that to say, yes, 700c will will pop right in with and work with stock brakes..
Here is my Prelude.
Here is the bike that needs new wheels. 1980 Schwinn Voyageur.
This is a picture with a front wheel on the bike of a set that I am thinking of buying . A mix of new with old.
Quoted: 789 Post(s)
Liked 1,739 Times
This wheel is a fine fit and will work but it way beyend the frame your rocking. You need to get a better bike to start with.
1980 Voyageur 11.8 was the top of the line Schwinn bike just under a Paramount?
Quoted: 789 Post(s)
Liked 1,739 Times
Nothing
Those wheels are cool looking. Gives the bike a whole new personality.
Freewheel Medic
Liked 2,184 Times
In 1981 Schwinn introduced the Superior made from leftover Chicago Paramount Reynolds 531 tubing sets. They were equipped with Campy G.S. gear which was slightly below the NR gear. The Superior for the next three years was Schwinn's second to the top model, followed by the Panasonic made Voyageur.
So getting back to 1980, in many respects the Voyageur 11.8 was Schwinn's TOP OF THE LINE bike for all intents and purposes. The small handful of Paramount frames produced by the end of the year would be more like a "boutique" item. Maybe scooper could contact Richard Schwinn and ask him how many Paramounts were actually made that year. I'm guessing the number is very low. On the Waterford site they only show decals for the '81-82 "Elite" models. There might not have been any 1980 Paramounts made.
This is just me, but modern wheels on a 1980 Voyageur 11.8, are not very appealing. Velo Orange and Harris Cycle offer more traditional looking wheel sets if that would be of interest.
Bob
Bob
