An infrastructure proposal that just might work!
I think the study completed here in Kalamazoo Mi deserves to be shared with the rest of the community.
Marc
Marc
Quoted: 663 Post(s)
Liked 496 Times
Cycling infrastructure in many communities is coming to pass, not as rapidly as we might hope, but it is happening. We just need to keep the pressure on by our support of advocacy efforts.
Quoted: 1182 Post(s)
Liked 833 Times
Marc
Marc
Minneapolis, MN
Quoted: 509 Post(s)
Liked 9 Times
I've seen a similar plan locally. The net result has been that since the inception of the plan, we have lost 43% of our cyclists and 30% of our walkers (US Census American Community Survey, looks only at longest mode used to commute to work).
Bottom line for me: Will there be real and meaningful follow-up to measure success/failure and will the plan be modified if it does not achieve its desired outcome? Mostly these things just gather dust on a shelf when it's found that the cycling numbers are largely independent of them.
I'd sure love to see a city do what Davis did in the 1970s and implement zero-tolerance traffic law enforcement. It worked wonders until it was halted in the '80s (which was followed by a cycling collapse).
Also, the notion that there should be discreet cycling routes but that cars have the entire grid seems doomed to failure. What we should be doing is corralling the cars and giving cyclists, walkers and buses unfettered access. I've always said, only partly in jest, that if motorists had to deal with the inconveniences that cyclists do then no one would drive.
Marc
I think bike boulevards are great, in cities with a good cycling culture and good cycling-driving relations. Otherwise, warring the road can be disastrous.
I personally didn't know what sharrows mean until I started cycling to work, and I'm sure most of my non-cyclist friends don't know hat they mean.
Liked 833 Times
Quoted: 1591 Post(s)
Liked 1,018 Times
Why do you think this plan dramatically decreased cycling? What were the changes in infrastructure and why was it better before?
Bikes: 2010 Trek 7100
Quoted: 697 Post(s)
The plan is currently, by the end of the year, to extend it another ~2 miles, which will provide access from a new apartment complex and an older neighborhood to downtown and the city park, as well as the college's farm on the outskirts of town. That will at least make it useful to ~3-4x as many people as it is now.
Over the next 3-5 years, they plan to extend it about another 2 miles to include a couple of other neighborhoods likely to generate a lot more traffic, but I have to say I'm not impressed with the planning that makes it sound like pulling teeth to pour a simple 10' wide sidewalk: they're not doing major reinforcements to the river bank it follows, as evidenced by the panicked rush to put in the reinforcements when an existing section was undercut by at least the fourth "500 year flood" I've seen in my lifetime.
