Bushings for Tektro R200A
Quoted: 753 Post(s)
Liked 735 Times
I have an original set of Retroshifts, that are shift levers mounted on the arms of what i think are Tektro R200A levers. The plastic pivot bushings are worn out and there is a lot of side to side play in the levers. I was wondering if there was a source for parts for this generation Tektro lever, or would it be possible to buy one of the newer versions and canibilize the parts I need? Thanks
Quoted: 1438 Post(s)
Liked 1,092 Times
Retroshift now call themselves Gevenalle. Why don't you contact them? https://www.gevenalle.com/support/ "Most of our products are serviceable and if destroyed can even be replaced at discounted fees (because we love you!)."
Quoted: 2026 Post(s)
Liked 1,095 Times
+1 on contacting Gevenalle for the maintenance parts. Their customer service is very good.
They are indeed Tekrto R200 (aka Cane Creek SCR-5) levers but Gevenalle claims they tighten up the tolerances for their application. You could buy a replacement set of the levers and swap the bushings over to your levers or buy a pack of thin shim washers and add them to the pivots to take up the slack.
I have these shifter, old enough to be labeled Retroshift, on two bikes and love them. So far the levers are still relatively free of play after 27,000+ miles on each bike.
Quoted: 4194 Post(s)
Liked 3,837 Times
I run a self made mirror on my LH Ergo lever, since the mid 1990s. That side's lever bushings will have greater ware due to the weight of the mirror (not much but it does stick out 4"). In the beginning I sought out replacement lever pivot bushings and installed some after a few years on the various bikes I had. These days I don't bother and if the slight bump induced rattle (of the lever) gets to me I just place a finget on it and it's silent.
Some day I will make some brass bushings on my lathe... Andy
AndrewRStewart
AndrewRStewart
Quoted: 753 Post(s)
Liked 735 Times
Bumping to catch the weekend crowd. I sent Gevenalle an email and it's only been a couple days, but I'm pretty sure I sent them an email about this 6 months ago and never heard back. Being that I've taken 6 months to follow up during a pandemic, I aint judging...
So any one know?
So any one know?
Quoted: 836 Post(s)
Liked 1,058 Times
^^^^^Give them a call. Probably quicker response. 503-512-9378
Quoted: 753 Post(s)
Liked 735 Times
Tried to call enough times to figure out their not takeing calls. Tommorow I'll leave a voice mail to reinforce the email from last week. But thats not the only screen door for this bumble bee to bang his head on.....
aka: Dr. Cannondale
Quoted: 2152 Post(s)
Liked 3,401 Times
Recently saw some replacement lever bodies with new hoods on eBay. Would new bodies fix the problem?
Quoted: 336 Post(s)
Liked 309 Times
The only thing that is modified are the lever blades. You could buy replacement levers and just move the blades and the proprietary bit over to the new levers.
Keep the springs from your old levers before you toss them.
Quoted: 753 Post(s)
Liked 735 Times
There are 4 small bushings that are worn out. Swaping parts is the hope. The question is whether the old and new versions are actualy compatable. If I can't get an answer from the retroshift folks, it won't be that traumatic to order the newer generation levers to find out if I can use them as organ donors.
Quoted: 753 Post(s)
Liked 735 Times
Bikes: '04 LeMond Buenos Aires, '82 Bianchi Nuova Racing, De Rosa SLX, Bridgestone MB-1, Guerciotti TSX, Torpado Aelle, LeMond Tourmalet 853, Bridgestone Radac
Quoted: 101 Post(s)
Liked 46 Times
Check directly with Tektro - a few years ago one of the quick release tabs/pins fell out on one of my levers and I was able to find them on Tektro's site.
Quoted: 753 Post(s)
Liked 735 Times
So I got a hold of the Gevenalle folks and their sending me out a set of their "up speced" bushings. They are dealing with logistical fall out from Covid, as suspected, so I will concur that they have great customer service. I also confirmed that the OEM bushings are swap-able, so I can go that route if the slow boat from China is delayed.
