FS: Grand Bois Cerf Green Label EL* 28-622/700C Tires - Extra Light
Grand Bois Cerf Green Label Extra Leger* 28-622/700c - 2pr: $65/pr shipped conti USA; paypal g&s
I'm trying to move out some tires, maybe clear space in my tire drawers for tubes, then have more shelf space?
Two pair of GB Cerf/Greens EL&. All are low use, low mileage, minor tread wear. No cuts, slashes, gouges, etc. These are pretty close to at-spec width on narrower vintage rims, with plump out to 29-30mm on wider 23-25mm outer-width rims.
I'm putting an asterik on the Extra Leger* (Extra Light) because I'm pretty sure I got these direct from I-Cycles in Kyoto as slightly out-of-spec, at maybe 20% off new? They have the EL casings, but EL spec is 210g +/- 5%, which should be 200-221g, and 3/4 are at 230/232g. The one at 224g might be a legit EL, just a couple grams over spec, but since there's no way to differentiate these by looks/label/etc, I'll partner this one with one of the heavier ones.
Both pair have one tire with essetially no wear and one with a little center wear, likely each pair installed front/rear. The wear band on the 224g tire is a little wider. Note that the tiny knobs on the tread are very, very tiny/low, so that's not much tread wear at all. However, also please note that these are lightweight tires, with pretty thin tread, so don't think you're getting Paselas that went on a little diet. You probably don't want to use these commuting on glass-strewn streets.
Current US distributor retail pricing for new is $138/pr for in-spec ELs.
Flickr album:
https://www.flickr.com/photos/263834...57648060578763
Flickr album:
Fuggedaboutit!
Fuggedaboutit!
The dropped
Bikes: Pake C'Mute Touring/Commuter Build, 1989 Kona Cinder Cone, 1995 Trek 5200, 1973 Raleigh Super Course FG, 1960/61 Montgomery Ward Hawthorne "thrift" 3 speed, by Hercules (sold) : 1966 Schwinn Deluxe Racer (sold)
Quoted: 1739 Post(s)
Liked 1,014 Times
Ok, I'll ask.
A total of 4 tires for $68?
Quoted: 3810 Post(s)
Liked 6,689 Times
"Grand Bois Cerf Green Label Extra Leger* 28-622/700c - 2pr: $65/PR shipped conti USA; paypal g&s"
I believe that's $65 per pair, but pcb will need to confirm.
That's an excellent deal, btw.
The dropped
Liked 1,014 Times
@$65 (or 68) for the whole kit-n-kaboodle this is a very hearty yes. I'll have to measure the 5200, which was designed around 23's, I think. These should be an upgrade from the ultra sport II's.
Golly gee willikers, folks, I'm sorry I missed these comments/questions. Just after posting these my ISP went dark, meaning the email provider I'd been using for like 25yrs. Panic ensued.
So, yeah, I had 2 pair available, priced at $65 per pair, so it'd be $130 for all four. One pair already sold, however, the 230/232g set.
The other pair is still available, but I do have them up on ebay right now. If someone wants to snag the last pair, I can take it off ebay before a bid is placed. After a bid is placed, they'll stay there till the auction ends.
Thanks, I was in my afternoon "stay home to work and homeschool 3 kids" fog.
Fuggedaboutit!
Fuggedaboutit!
The dropped
Liked 1,014 Times
Thanks for the update pcb. I measured the bike I'd install them on and determined that the extra 3-5mm around won't allow enough clearance at the brake bridge for that bike, or the other 'light' bike. GLWTS!
Thanks for checking! I had a 5200 way back, very nice machine.
If I might make a kinda boring suggestion, maybe snag a pair of Conti GP5000 in 25mm, or maybe even scope out if 28mm will fit. They're great all-around tires, one of the bestest, and the sizing is more consistent than the GP4K they replaced. They'll be 28mm on wider rims, a little undersized on narrower rims----narrower and lower all-around than my listed Grand Bois 28s. They're not as light as the Gran Bois, but a little more rugged and flat-resistant, while being a lot more supple and faster than the Ultra II.
Pair 'em up with latex tubes and you'll be flying! And inflating the tires every 2-3 day, but, you know, worth it.
Fuggedaboutit!
Fuggedaboutit!
The dropped
Liked 1,014 Times
car dodger
I bought the first pair, and they barely wouldn't fit my merckx (rear brake)...so I took the same size (28mm) turbo cottons off my McLean and put them on the merckx, and they fit. Put the grand bois tires on the Mclean, and they fit!
1989 Schwinn Paramount OS
1980 Mclean/Silk Hope Sport Touring
1983 Bianchi pista
1976 Fuji Feather track
1979 raleigh track
"I've consulted my sources and I'm pretty sure your derailleur does not exist"
1983 Bianchi pista
1979 raleigh track
tantum vehi
Quoted: 1167 Post(s)
Liked 992 Times
I think this may be why some people put their rear brakes forward of the seat stays... but I could be just making that up.
1970 Gitane TdF; 1973 Gitane TdF
1979 Trek 710; 1981 Trek 412; 1981 Trek 710
1984 Specialized Stumpjumper Sport; 1985 Specialized Allez SE; 1988 Specialized Sirrus; 1989 Specialized Rock Combo
1984 Ross Mt. Hood
1988 Centurion Ironman Expert
1991 Bridgestone RB-1
1992 Serotta Colorado TG
2015 Elephant NFE
1984 Ross Mt. Hood
2015 Elephant NFE
The dropped
Liked 1,014 Times
One time I had the same issue and I beveled a brake washer (placed between the brake and bridge) so that it ever so slightly angled the brake up. Worked on a tire that just kissed the rear brake otherwise.
tantum vehi
Liked 992 Times
Yeah, not much one can do there without a torch. But at least you got the correct tires on each bike now!
1984 Ross Mt. Hood
2015 Elephant NFE
1984 Ross Mt. Hood
2015 Elephant NFE
I'm glad the ol' switcheroo worked! The Merckx looks sweet. Creep the rear wheel any further forward and you'll need to indent the seat tube! She's tight!
As for seatstay fore/aft caliper mounting and clearance, I tried to play with high school geometry, but it doesn't work any more. I was drawing tangential lines and measuring stuff with a ruler, and all I got was a headache.
Mounting the caliper forward of the seatstays _decreases_ reach/clearance in my experience, at least it did on my Hetchins. I did a reverso mount on the Hetchins because the Campy caliper didn't have enough reach aft of the seatstays. Now the shoes at slot-bottom just reach the rim. Plus the bike was originally built for centerpulls, and a sidepull mounted aft got fouled by the rack mounts.
Fuggedaboutit!
Fuggedaboutit!
car dodger
I moved the rear wheel back a bit after I took the pic, there's about 1cm gap now, way more than up at the rear brake caliper! Took it for a ride and all was well!
1983 Bianchi pista
1979 raleigh track
1983 Bianchi pista
1979 raleigh track
Bikes: Numerous
Quoted: 1677 Post(s)
Liked 3,091 Times
Thanks for the nice tires pcb (got em on another forum!). While we're all here, anyone care to comment on gravel durability of these tires? As best I can tell these are precursors to the Compass then Rene Here brand which are marketed for gravel use. I couldn't really find too much in the way of gravel success/failure stories on line. Mine are the standard, not the extra light BTW.
Quoted: 7348 Post(s)
Liked 2,464 Times
@pcb, how do you shoot with a perfect white background?
If you promise to keep it a secret, this is the super-secret basement skunkworks/studio/bunker/man-cave. Remember that it's about what you show, not what you don't show. If it ain't in the frame, it don't exist.
So a big seamless white background, lotsa light, and some rudimentary photoshop. Lightroom would be better, but I'm a reluctant student. The hard part is getting the background white without blowing out detail on the bike, and the Hetchins shots kinda fail there. Lots of blown highlights on the silver componentry, but I was in a "can't be bothered" mood at the time. Ideally you've got more room between the bike and background, and you can position lights to just hit the background. So no shadows, and all the white you want. Also ideally you have enough room to change out the paper, so you can shoot with gray or black or even chroma key if you want, depending on the color of the frame. I'm squeezed in pretty tight wall-wall; the background paper isn't more than a few inches longer than your average big frame wheel-wheel distance. Lighting the background is hard, and camera position and lens choice matters.
Fuggedaboutit!
Fuggedaboutit!
Likes For pcb:
Liked 2,464 Times
Wow, you're a photographer! I can now give up the idea that I can (or am willing) to do the same.
Quoted: 500 Post(s)
Liked 466 Times
Are those Crank Brothers pedals holding up OK?
Impressive work for your photos, pcb But I always enjoy your shots taken out “in the wild”.
car dodger
I'm just thankful the grand bois tires weren't "tubeless ready" like the current rene herse tires are (I run clinchers)... the grand bois went right on, but I had to take some rene herse tires to a bike shop to get them mounted on another bike, a first for me. And they managed to ding a rim while mounting them!
1983 Bianchi pista
1979 raleigh track
1983 Bianchi pista
1979 raleigh track
Bikes: Numerous
Liked 3,091 Times
They're great. I still think about your ride to the rescue when I use 'em. They're on my Ciōcc all-rounder bike now and been getting a lot of use out of them. Thanks for the tire info. It's kind of the sense I've been getting - fine for missing in gravel sections on routine rides, but maybe stay with something beefier for heavy duty rides.
Anybody can do the same by following Ray Dobbins' guide. He did it all with stuff bought on the cheap from Home Depot & such. It's much easier to do if you have plenty of space to work with, but the principles are the same regardless of space: seamless background and lotsa light. The tricky part in tight quarters is getting enough light on the background.
MY PHOTO SETUP
MY PHOTO SETUP
Fuggedaboutit!
Fuggedaboutit!
Likes For pcb:
Quoted: 634 Post(s)
Liked 444 Times
tantum vehi
Liked 992 Times
...I fought the tires for an hour and couldn't get one of them seated but with this tire bead jack I was able to get it done in 10 minutes. https://www.biketiresdirect.com/prod...tire-bead-jack
1984 Ross Mt. Hood
2015 Elephant NFE
1984 Ross Mt. Hood
2015 Elephant NFE
Likes For mountaindave:
