BEST Grease Cleaner for Wheel Hubs?
Old 08-18-19, 10:45 AM
yungkie
Hi friends!
I am attempting a first time repair on a front wheel hub and have already went through the process of taking everything out, the rods and the ball bearings.
And now I'm curious to know what the best method is to clear up and prep the wheel hub for installation?
Also, can I get a suggestions on which ball bearing are great? (Decent priced)
Thanks
yungkie is offline
Old 08-18-19, 10:51 AM
riverdrifter
riverdrifter's Avatar
Bikes: Trek 620, Jamis Satellite Sport, Raleigh Sport
Quoted: 142 Post(s)
Liked 125 Times in 59 Posts
WD40 works very good as a cleaner and degreaser for bike hubs. Another surprising chemical that works great for this is charcoal lighter fluid. I've used both effectively.
riverdrifter is offline
Old 08-18-19, 11:20 AM
JohnDThompson
Old fart
JohnDThompson's Avatar
Quoted: 1894 Post(s)
Liked 228 Times in 163 Posts
I like to use "odorless mineral spirits" aka OMS, available as a paint thinner at many hardware stores. But apparently not in California.
"Grade 25" balls are what the top-end hubs use. You can get cheaper, lower grade balls, but you really don't save much by doing so.
JohnDThompson is online now
Old 08-19-19, 06:16 AM
Koyote
Quoted: 549 Post(s)
Liked 247 Times in 146 Posts
+1 on the grade 25 bearings, which are the highest tolerance (most spherical) you can get. Buy from a reliable supplier like Wheels Manufacturing; there are some no-name suppliers, and I sometimes wonder if they are really grade 25. I think you can probably find them on Amazon in bulk, and for reasonable costs.
As for a degreaser: maybe I'm doing it wrong, but when I overhaul old style cup & cone hubs, I just clean everything out thoroughly with a clean rag (an old cotton t-shirt works well) and also use Q-tips, as well. That way, I don't have to wait for liquid degreaser to dry/evaporate before putting in the fresh grease and bearings. I may leave a trace amount of old grease behind, but I don't worry about it, as I repack with a lot of fresh Phil Wood grease.
Koyote is offline
Old 08-19-19, 08:24 AM
kcblair
Old Legs
kcblair's Avatar
Bikes: '80 Strayvaigin, '84 Ciocc Aelle-Shimano 105, '90 Concorde Astore /Campy Triple ,85 Bridgestone 500/Suntour, 2005 Jamis Quest, 2017 Raleigh Merit 1, Raleigh Carbon Clubman
Quoted: 288 Post(s)
Liked 12 Times in 10 Posts
Yep , Grade 25, is what I've always used. As for cleaning, I keep a large supply of rags around, and just wipe all the old crap out of races, cones and axles . KB
kcblair is offline
Likes For kcblair:
Old 08-19-19, 11:10 AM
Rick53
Bikes: Verve, Dual Sport 2 and FX3
Quoted: 52 Post(s)
Liked 8 Times in 6 Posts
Originally Posted by yungkie View Post
Hi friends!
Thanks
Kerosene : Smells a tad but it's the best of the best :
Rick53 is offline
Old 08-19-19, 03:22 PM
Homebrew01
Super Moderator
Homebrew01's Avatar
Quoted: 907 Post(s)
Liked 133 Times in 111 Posts
I don't usually use a degreaser. Just wipe out the old grease & replace with new.
I have used a quick squirt of WD-40 if there's a lot of gunky stuff that is hard to remove.
FYI: http://www.bikeforums.net/forum-sugg...ad-please.html
Homebrew01 is offline
Old 08-19-19, 05:00 PM
yungkie
Thanks everyone for the response and feedback!
I am looking up some Grade 25s now and will be cleaning up the grease with either WD40 or some kerosene.
You all are great!
yungkie is offline
Milton Keynes
Bicycle Mechanics
14
05-16-16 12:15 PM
djb
Bicycle Mechanics
23
10-07-15 04:09 PM
bizarro302
Bicycle Mechanics
13
05-28-15 11:45 AM
Gege-Bubu
Bicycle Mechanics
2
04-30-11 04:42 PM
DVC45
Bicycle Mechanics
8
10-03-10 07:38 PM
