Dura Ace 7400 brake pads?
With a mighty wind
Quoted: 1087 Post(s)
Liked 862 Times
I'm cleaning up and getting road worthy a bike that's probably 1985 to 1987, full Dura Ace 7400.
I wanted to replace the brake pads and they're a different size than modern standard road brakes.
It's cheap enough to get all new pads and carriers for the calipers that will be the new standard size. I was going to do this until I realized that the carriers and pads all say Dura Ace.
I'd be fine if the pads didn't say it since that is a consumable. I don't want to change the carriers now though. Can I find replacement pads in this size?
Pics to show the old pads next to a modern one.
aka: Dr. Cannondale
Quoted: 2155 Post(s)
Liked 3,404 Times
Easiest to go to modern pads and carriers. Then save those old pads and carriers for whoever buys the bike from you in the future.
Likes For rccardr:
Kool Stop says these will fit your holders:
Kool Stop International - High Performance Bicycle Brake Pads Since 1977
Likes For Salamandrine:
Ride, Wrench, Swap, Race
Quoted: 1565 Post(s)
Liked 1,295 Times
I don't believe that any modern Shimano pads will fit in those brake pad holders, and mine are newer than yours as they are blue-grey painted.
I just went through trying to replace the pads in my ~1992 7402 pad holders, and those were a no-go. I had to use bench-vise force to even remove the old pads, and the new replacements did not seem willing.
I gave up and fitted basic Jagwire pads with their basic steel holders, these work great on the finicky CTL-370 rim surfaces. I tried several different pads before the Jagwires, and all but the Jagwire pads would quickly glaze and squeal loudly on the CTL-370 anodized sidewalls.
Actually the Shimano pads didn't squeal at all, but hardly stopped the bike, either.
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3886 Post(s)
Liked 6,482 Times
You can get KS refills on the cheap -- I just bought four "dura" style pads for $14 on ebay.
But, man, the holders are expensive. Sometimes it's actually cheaper to buy used calipers that have holders rather than new holders.
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
Rubber doesn't just age on the outside. These pads are not only old enough to drink, they're nearly old enough to be President.
With a mighty wind
Liked 862 Times
If I have a pair of climbing shoes in the garage for 2 years, sure, I'll wire brush them before heading out. 35 year pads though, I'm not sure.
FWIW, the bike was stored inside and rarely ridden according to my dad (a friend of his owned the bike). No bolts we seized. The seatpost wasn't stuck. Even the housing looked OK. It had a thick layer of dust and nicotine I've had to clean. Not even a crack on the seat (other than an obvious wreck).
I've gone ahead and ordered new modern pads on modern carriers. Some generic brand. If they act funny on the MA40's, I have a ton of road pads that will fit I can use.
Quoted: 1949 Post(s)
Liked 2,010 Times
I'll ask here since folks are paying attention.
Is there any significant difference in the performance of these brakes when we install thinner, modern, Dura-style holders and pads? Of course the new pads improve performance, but engineering wise, would anyone back in the day replace stock the holders and pads with replacements that had less reach?
aka: Dr. Cannondale
Liked 3,404 Times
Not sure what you mean by less reach...the newer pads are thinner but seem to last a long time. All the rest is adjustment.
I would have been inclined to replace the pads only and use the original holders for these 7400 brakes, for that reason. Clearly this is a minority position these days. Changing pads happens much more often with modern brakes, and it is kind of annoying. They are however easier to replace than old school pads. Those often had to be unbolted from the caliper and the inserts removed with a vise.
WRT swapping in aftermarket brake pads - it was done sometimes but not often with high end brakes. Some people used those silly finned Mathauser super pads. Mostly they just squealed more if you did that.
Quoted: 767 Post(s)
Liked 1,898 Times
Those calipers with the thinner, modern holders and pads provide outstanding stopping power. Braking from the hoods with the original levers is easy.
I've had great results with other bikes in the past. It works.
Liked 2,010 Times
When compared to 25-35 year old pads that cannot be replaced with new, more supple and better gripping ones, then, yes, there is a significant difference. Back in the day this wasn't an issue- pads weren't 25-35 years old and replacements were readily available.
The issue is where the pivots are on the calipers themselves. The ends of dual pivot calipers arc upward as they go in. Single pivots for all practical purposes do not. If you put thick pads on dual pivots, the contact point at the rim will creep upward as they wear out, eventually hitting the tire.
Center pull brakes also have this issue, to a lesser degree.
Quoted: 1163 Post(s)
Liked 442 Times
One slight advantage of some modern holders is that the bolts (and mating washers) are sometimes spherical allowing for better accuracy with setting them up for tight tolerance rim sidewall parallel or toed in set-ups.
aged to perfection
Quoted: 837 Post(s)
Liked 1,258 Times
these Kool Stop pads (and holders) are excellent and have the "orbital" mounting washers that as Masi says above, allow very free adjustment of angle, toe, etc.
https://www.ebay.com/itm/KS-CXT-Kool...-/401914890076
this is an excellent part and I have them on several bikes.
Mark Petry
Bainbridge Island, WA USA
Mark Petry
señor miembro
Liked 6,482 Times
https://www.ebay.com/itm/Kool-Stop-S...kAAOSwxQJbGC7o
https://www.ebay.com/itm/Kool-Stop-D...AAAOSwry1aQWFP
aged to perfection
Quoted: 837 Post(s)
Liked 1,258 Times
thanks for that Surfer, I had not seen that "road" config, the ones I've used are the "cross" ones.
Kool Stop products are pretty good, they have 100s of configurations, but I think these integrated pads and holders with the spherical washers are the best out there, better than OEM and reasonably priced.
the search for the BEST price is always left as an exercise for the reader
Mark Petry
Mark Petry
Quoted: 767 Post(s)
Liked 1,898 Times
To be clear, that is not what I was saying at all. The pads do not change the leverage significantly. New pads will be fine on old brakes. The only thing is that they will not last as long.
The conical washers on modern pads really do make adjustment a lot simpler, and the set screw mechanism for holding the inserts is a big improvement. I currently the Kool Stop dura pads/holders with my GC610 centerpulls, and they are great.
I've run Dura-Ace 7400 brakes; I probably have a few sets sitting in a big bin 'o brakes.
The problems with these vintage pads is not just they were too small, and the rubber is hardened after 30 years - the main issue is that for a multi-decade span, including the 7400 era, Shimano's brake pads were pure crap. They had a unique ability to pick up small rocks and metal shards, which when embedded, proceeded to grind away at your rims. In the rain, in addition to the scary inadequate braking, the pad material turned to a black goo that coated your rims, and with centrifugal force, flung it out onto your person.
Shimano pads are now much better.
For even more improvement, I recommend ditching the 7400 single-pivots for the 7403 dual-pivots. Much better braking and they self-center. The 7400s were the best single-pivot brakes ever made: superior mechanical advantage, excellent materials, hardware and finish. The 7400's are in every respect better than hopeless vintage floatsam such as Gipiemme, Ofmega, Modolo, and the worst: Dia-Compe. When I receive these at our local bike Co-op, they go deep into the trash. Flexy, thin arms, overly stiff springs, and cheap awkward hardware. Life is too short to be riding on poor brakes - unless you want your life to be short!
Nevertheless, the braking power of the 7403's are far superior to the 7400s. Option: the 6403 dual pivots are just as powerful, and can be bought on Ebay cheap cheap.
With a mighty wind
Liked 862 Times
Good info on the Shimano pads.
They're off the bike and will be put into a bag and saved for perpetuity for some reason.
I have 10 speed Campy Chorus on my favorite bike. I'm pretty sure they're single pivot and stop very very well. That is the only single pivot I can compare to. We'll see.
Quoted: 1324 Post(s)
Liked 927 Times
One thing about the old school brake pad holders with the open end to slide the replacement pad into was that you had to be careful when putting them back on the brake calipers that you didn't inadvertently have that open end of the holder facing forward. Because if you did there was a great chance of a brake shoe leaving the holder if you braked hard.
Cheers
Cheers
With a mighty wind
Liked 862 Times
They're back on the bike and adjusted now since last post. The only thing I noticed is that I need to use more strength to overcome the spring.
This isn't my gravel bike or my serious road bike, so it's ok. I could certainly envision some seriously pumped hands after a wild descent.
Currently have a granny of 42-24 and with Uniglide, probably won't change much, so it's probably going to be spared the steep stuff.
Liked 1,295 Times
When I set my '65 Varsity up with long-reaching(!) Weinmann sidepull calipers and with the very basic old model Matthauser blocks with crimped alloy holders, the thicker pads resulted in too much squish at the lever despite the pad's surfaces being perfectly mated at the rim sidewall.
This was with mis-matched Record/Veloce 10s Ergolevers.
As a last-ditch fix that might allow me to retain the stock calipers, I changed to longer, newer-style Kool-Stop dual-compound MTB pads, and lo and behold I got a solid feel at the lever with plenty of braking power at least for my 150# self on more-spirited (i.e. training) rides.
Moral of this story is that if one perseveres with those flimsy old calipers that some good braking power can be found, with a good balance of leverage/travel and actual stopping performance.
Note also that today's thinner pads are for the most part backed up by thicker mounting hardware, including a plain spacer plus one matched set orbital swivel washer. So not too much if any total thickness is lost in most cases.
Using pads of different thickness does not change the pad-dive (or pad-rise) trajectory of the pad surface at the rim at all. But as I think Salamandrine mentioned, the thicker pad will have greater thickness variation over it's life and so will over time result in greater pad contact position change on the rim sidewall (toward the tire).
Plenty of leverage and brake power as shown (using Kool-Stop BMX pads):
Likes For dddd:
