What to wear @ 20+ mph?
Quoted: 451 Post(s)
Liked 364 Times
Another way I have heard aero people/researchers discuss this is that, the slower you go, the greater the gains aero improvement can actually make as a percentage of your overall speed over time. Faster folks have lower percentage gains due to aero wheels, say, than a slower rider will.
Quoted: 2494 Post(s)
Liked 738 Times
I'm just hoping that the o.p. doesn't ride the Raleigh Redux with the saddle slammed like in the photo. I have found running clothes to be a bit cheaper than cycling clothes and just as aerodynamic. Pearl Izumi shorts with chamois and some kind of running tight over that is fine for Oregon winters. I don't think I would need more than that blue fleece in San Jose. But if I did it would be a Gore Path jacket with zip off sleeves.
Quoted: 426 Post(s)
Liked 274 Times
Quoted: 426 Post(s)
Liked 274 Times
On a bike on the same day/weather/etc I get cold doing 20+. I guess I am wind chill wimp.
Bikes: 70's frame, newer parts
Quoted: 92 Post(s)
Liked 38 Times
Another example is easy to test. Try drafting another bike at 8 MPH. There is no noticeable effect but at 3X that speed it is like being sucked forward and the effect is obvious.
The air drag force is proportional to the cube of the speed. If the speed doubles the drag is 8X more.
Back on-topic. It never gets below low 50s here so I don't know much about riding is rralycold weather except to say dress in layers that can be removed and stored in the jersey's back pockets. Arm warmers are small and easy to store and so is a thin merino wool base layer under the jersey. If over heated, stop and swap. Use a jersey with solid from to break the wind, then on the uphill climbs unzip it. Dress so you can remove and unzip as you heat up.
Even name brands are cheap on eBay, lots of good like-new stuff for 25% or less of new price.
Likes For ChrisAlbertson:
Quoted: 451 Post(s)
Liked 364 Times
No. That can't work. Try putting working in some numbers and you will see. If I am riding at 8 MPH and I drop down so that my upper body is completely horizontal and I put on skin tight clothing i will NOT pick up even 1 MPH. At that low speed all the rage is just rolling resistance. But at 20+ it is easy to pick up 1 MPH with no effort. I can get this by looking on the bike computer.
Quoted: 451 Post(s)
Liked 364 Times
Quoted: 426 Post(s)
Liked 274 Times
yeah thats true, That's my commuter bike I ride to and from work at night before this whole work from home thing. They are highly reflective for my rides home after work.
Maybe I should switch to reflective time on the rims instead? Or just reflective tape on the bike ? I have a front and rear light.
Quoted: 1814 Post(s)
Liked 923 Times
3 or 4 per wheel might give pretty much the same effect...
Quoted: 4559 Post(s)
Liked 2,802 Times
Snug clothing isn't just faster on the bike. It also reduces buffeting from crosswinds. I finally switched to more aero jerseys and jacket for my road bike rides this winter and immediately noticed a difference. Yeah, I was a little faster when I put some effort into it. But the main difference was reduced buffeting from crosswinds. On days with 15-30 mph wind whipping around erratically, that lends a little more confidence, especially riding in traffic where I don't want to wobble unpredictably.
Quoted: 6193 Post(s)
Liked 4,808 Times
Actually I don't think about increased speed with cycling specific clothing. Other than just not having a shirt or jacket act like a parachute when opened. For me it's about having clothing that fits close enough to act as a outer skin. That way, if it's moving with you, then all the chaffing will be fabric on fabric, not fabric to skin. Also, the close fit maximizes getting sweat away from your body and to the outer part of the fabric were evaporative cooling from airflow can take place.
Likes For Iride01:
Quoted: 3352 Post(s)
Liked 1,056 Times
You have no bike specific clothes? Start with Lycra shorts and bike jerseys. Cooler weather I wear a base layer and a warmer jersey and add a wind vest for warmth. A skull cap or some head covering will help with chilly weather. I almost never wear a jacket.
Check out Nashbar or Performance Bike for clothes or look for sales. I also have 2 jerseys from Voler for cool/cold conditions. Warm weather almost any wicking material will work.
Quoted: 8278 Post(s)
Liked 9,033 Times
The shorts also provide moisture management and some decent ones can be had for $45 in the link.
The fast recumbent riders I know wear bike specific clothing for the same reasons the rest of us do except I have seen recumbent jerseys with pockets on the front. Don't know about the chamois they do or don't use.
I'm sure you can ride your 'bent in anything just as an upright rider can. It's more rider preference than bike type.
I know you couldn't resist getting a shot in against upright bikes. You've been slacking off lately.
Liked 4,808 Times
Interesting that riding a recumbent doesn't require clothing that doesn't chafe or remove heat and sweat away from a persons body.
Likes For Iride01:
just another gosling
Quoted: 3886 Post(s)
Liked 1,938 Times
It's actually not surprising. We're a 144 y.o. tandem team and my stoker has an FTP of 75w. We've zoomed by every recumbent we've seen on our side of the road. Not saying that there aren't fast recumbents, we've just never seen one. So for the most part he's right, no need for any of that.
Results matter
Results matter
Liked 9,033 Times
Another friend rode a custom carbon fiber 'bent which he said was about 17 pounds. He went very fast on the flats and descents. He even raced the velodrome with it when they had a special event.
In 2008 John Schlitter became the first recumbent rider to finish Race Across America. He also wears bike clothes.
I don't claim to be in the same league as John Schlitter, but I've been known to pass a few bikes. For the most part I wear regular bike-specific stuff, including the padded shorts. I may not need the pad as a pad but it's still useful for chafe- and sweat-control.
Likes For BlazingPedals:
Liked 9,033 Times
Quoted: 1948 Post(s)
Liked 2,010 Times
This is old news but if your serious about going as fast as your new bike wants to go...
https://www.cyclingweekly.com/news/p...ng-buck-221256
I don't have a power meter so I know nothing about this stuff, but 46 watts saved for wearing a skin suit seems like a great deal of additonal speed for no additional effort. 18 watts for shoe covers?
Likes For Classtime:
Quoted: 92 Post(s)
Liked 38 Times
So at our speed, 20 MPH, the clothing saves about 10 Watts. I think this perfectly answers the question about what to wear at 20+ MPH
10 Watts is a reasonable amount of energy. It is art twice as much as a iPhone charger can deliver and converted to food -- if you do a two hour ride 10W uses about 17 Kilocalories. So keep the baggy clothing and you can eat 1/2 teaspoon more sugar.
Liked 1,056 Times
As to cost, on my bents I wear rugby shorts I get from Sheels sports stores that I get for $15 on sale. I wear T-shirts that I mainly get from the bike club for free for riding or running sag stops. The main point here is the shorts DF riders need to protect them from their seat. With my "lawn chair" seat no such protection is needed.
Liked 1,056 Times
What chafing? On a bent there are no high pressure points to cause chafing, because we are sitting on top of a web seat. Sweating so what. Take a shower when you get home.
