Go Back  Bike Forums > Bike Forums > Beach Cruisers
Bicycle Bearing casing disintegrating
Beach Cruisers Do you love balloon tires and fenders? Do you love riding the simplicity of a single gear and coaster brakes or a single gear cluster? Do you love the classic curves in the tubing of a cruiser that takes you back to the 1950's and 1960's, stylistically? Here's your home! Welcome to the Beach Cruisers and Cruisers forum!
Old 04-09-20, 08:44 AM
JosephDCW
Angry Bicycle Bearing casing disintegrating
Recently, last week I applied coating of MAG1 lithium grease to my Mom's beach cruiser and now today the casing of the ball bearings has disintegrated into shards of metal pieces. Why on earth would this lithium grease do this when it states it is a "Break-in lubrication for bearings".
JosephDCW is offline
Old 04-09-20, 09:12 AM
100bikes
Industry guy
Bikes: To many to name - I ride a custom built steel frame.
Quoted: 115 Post(s)
Liked 80 Times in 48 Posts
No judgement intendended, but Are you certain that you put the retainers in the correct way?
There is no evidence that a lubricant has any breakdown ability on metal parts. Breakdown after a week is also a bit weird without some type of mechanical influence.
100bikes is offline
Old 04-09-20, 09:33 AM
Unapomer
Quoted: 27 Post(s)
Liked 17 Times in 12 Posts
Sounds like you put the bearing cage in backwards..........
Unapomer is offline
Old 04-09-20, 07:46 PM
JosephDCW
Thank you gentlemen. I was working on another bicycle and thought the orientation of the bearing cage would be the same. I was wrong, thanks for pointing this out.
Old 06-14-20, 12:49 PM
rollagain
Lopsided biped
rollagain's Avatar
Bikes: 2017 Day 6 Cyclone (the Buick); 2015 Simcoe Deluxe (the Xebec); Street Strider 3i (the not-a-bike); GreenSpeed Anura (the Black Swan)
Quoted: 316 Post(s)
Liked 160 Times in 97 Posts
Also note that greases are often not compatible with each other. Mixing them can result in lubrication failure. If you intend to regrease anything, the only safe way is to thoroughly clean out all of the old grease before putting new grease in.
rollagain is offline
