Recovery drink: Whey, Glutamine, Creatine "dose" questions
Has a magic bike
Quoted: 4456 Post(s)
Liked 425 Times
I drink a recovery drink after any workout or ride that has a "hard" element to it, which basically for me means almost every ride since I rarely do recovery rides. I am not 100% convinced its necessary but I'm a 52 yo woman and recovery is something I really need to maximize.
The big con to the recovery drinks is the calories.
I originally made my own drinks from a base of 12oz skim milk (12.5 gm protein, whey and casein) plus 10 gm of whey protein isolate to yield 22.5 gm, which is a dose of 0.5 gm/kg for me. I add other ingredients such that the end result if 50-60 gm carbs, shooting for 2-3x gm carbs per gm protein.
A while back, I started adding 5gm of glutamine. I wasn't sure if the glutamine, being an amino acid, was supposed to some out of the total protein allotment or not. But for lack of knowing for sure what to do, I cut the whey protein by 5gm when I added the glutamine,
Today I ordered some more whey protein isolate and glutamine and I earned a bonus 0.5 lb package of creatine. Read up on that, sounds reasonable to try since its free and it looks like they're sending me enough to last me a decent amount to time to see if it makes a difference.
So now my question becomes: do I cut the whey protein isolate out entirely to go with 12.5 gm protein from the skim milk + 5 gm glutamine + 4-5 gm creatine to give me a total dose of 22ish gm "protein"? I'm just not sure if these partial proteins/amino acids "count" when you read that the optimal post workout protein dose is 0.5 gm/kg.
Killing Rabbits
Quoted: 278 Post(s)
Liked 217 Times
Creatine is not a proteinogenic amino acid; it's pretty much unrelated to typical proteins / AA other than that it can be made endogenously from amino acids when intake is low. Don't add it to daily protein totals.
Has a magic bike
Liked 425 Times
Cutting the whey and replacing it with glutamine isn't doing you any favors (replacing a complete and high-BCAA protein with a non-essential amino acid). Just add the glutamine on top of the whey. A lot of the glutamine doesn't even make it into circulation - it is consumed by the intestines directly.
It turns out that as a result of miscommunication, my husband (who makes my recovery drinks while I'm uploading data etc), never actually decreased the whey in the drinks when I added the glutamine around a year ago even though I thought he had. He has been doing 12.5 mg protein in the skim milk + 17 gm whey protein isolate + 5 gm glutamine all along. The subject came up once I found out about the creatine freebie and we just got out wires uncrossed. Looks like we were inadvertently doing it right all along.
fuggitivo solitario
if anything, i'd add BCAA in lieu of glutamine after hard workouts. hard defined as anything requiring me to spend a lot of time above threshold. back when i was racing, 16 fluid ounce of kefir was what I took
the other thing is, that's a lot of protein in one go. someone probably knows this a lot better than I do, but can you be sure that all of it will be utilized as amino acid for muscle repair (cf. metabolized)?
Has a magic bike
Liked 425 Times
fuggitivo solitario
but on a more serious note, how many grams of protein/amino acid could the body handle after a serious cycling workout? I'll go just a little bit over, but anything more would be a bit wasteful (and expensive)
Bikes: Trek Madone, Blue Triad SL, Dixie Flyer BTB
Quoted: 160 Post(s)
From what I've read, about 20-30g of protein at a time can be used for muscle protein synthesis, so more than that in a meal is somewhat wasted (at least, from the standpoint of repairing or building muscle). That seems to be the recommended post-workout dosage for strength athletes, I would think endurance athletes might not need as much but I don't think there would be any real downside to consuming that much.
The idea behind glutamine intake is that of muscle sparing: if its readily available in circulation it would spare your body's use of this most abundant amino acid. Creatine, on the other hand, draws water into the cell which theoretically should aid with protein synthesis and add a bit more energy for one or two more reps in the weight room. It works well for some, while others (me included) report just getting bloated.
For the record, no one knows what the limit is for protein absorption, but if you're currently taking protein isolates, you're already getting the very best of everything you need.
Quoted: 1851 Post(s)
Liked 678 Times
Following up on Krane's point about creatine, be sure you are drinking plenty of water. It can leave you dehydrated. Also, some people report muscle mass and weight gain due to water being pulled in to the cells. If that's a problem, stop taking it and it will go away in a few days.
Has a magic bike
Liked 425 Times
But interesting to know about the hydration. I’m a minimalist with drinking on the bike. I get away with it because my weekday morning workouts are before dawn, so it’s cool. My weekend rides are often in heat but lower intensity. As we transition into race season though, I’ll get more real “work” on my schedule on the weekends when I’m riding in daylight so it could become an issue.
Thankfully Coach is a bit of a camel himself so I’m not continually hassled to drink more. And I definitely understand the importance of it in heat, on long rides, etc. Mostly though I drink way less than most recommendations I see (in Bicycling mag and the like) so understanding the Creatine effect on that will be useful.
Killing Rabbits
Quoted: 278 Post(s)
Liked 217 Times
It's true that you should drink a little extra water while taking creatine - because that's how it exerts its beneficial effects - but the dehydration thing is a persistent myth. Creatine causes water retention and water weight gain.
https://www.ncbi.nlm.nih.gov/pubmed/19295968
https://www.ncbi.nlm.nih.gov/pubmed/18184753
https://www.ncbi.nlm.nih.gov/pubmed/17460334
Exercise trials were conducted pre- and postsupplementation at 30 degrees C and 70% relative humidity. In the Pl group, total body water (TBW) increased by 0.50 +/- 0.28 L after Gly and in the Cr group by 0.63 +/- 0.33 L after Pl and by 0.87 +/- 0.21 L after Gly.
¯\_(ツ)_/¯
Bikes: aggressive agreement is what I ride.
Quoted: 967 Post(s)
studies I've read/seen showed 40g protein to be about the limit of uptake gains after a workout. Diminishing returns from 20g-40g, though. This was irrespective of bodyweight in the study I saw. They just used the raw protein values, not g/kg or anything.
Has a magic bike
Liked 425 Times
??? This article does not address my question at all.
fuggitivo solitario
gotcha; thanks for the info
DXchulo
21
06-05-17 03:33 AM
