Bike maintenance/ Zefal Extra Dry chain wax
1. Has anyone tried the Zefal Extra Dry chain wax? I know dry lubes are for dry conditions but it says in the description and in the bottle itself that it is for all conditions. Is this true?
2. I use oil-based lube for my chains and use a rag to wipe the chain clean when reapplying. When using a new and different lube, from oil to water-and-wax based (Zefal Extra Dry) or teflon (Zefal Extra Wet), do i need to thoroughly clean and degrease the chain first? My chain is usually clean as i always wipe it after each ride.
Bikes: 2017 Colnago C-RS, 2012 Colnago Ace, 2010 Giant Cypress hybrid
Quoted: 408 Post(s)
Liked 122 Times
I prefer Squirt over Zefal. You do have to soak the chain to get all the old oil/wax out before applying. About an hour in mineral spirits while occasionally swishing the chain around does the trick.
HCFR Cycling Team
Ride Safe ... Ride Hard ... Ride Daily
2017 Colnago C-RS
2012 Colnago Ace
2010 Giant Cypress
HCFR Cycling Team
2017 Colnago C-RS
2012 Colnago Ace
2010 Giant Cypress
I’ll go check that out. Is this for dry conditions only? It’s the beginning of the rainy season here, and i was on the lookout for a wet lube. What drew me to the Zefal Extra Dry is it’s good for all conditions, that’s what they say. If true, then great coz i want a clean drivetrain.
Quoted: 408 Post(s)
Liked 122 Times
Wet and dry conditions. I live in Florida and it's the start of our rainy season. Got soaked on a ride on Tuesday and it didn't have any affect on the chain on Wednesday's ride. I did reapply some on Thursday's ride.
HCFR Cycling Team
2017 Colnago C-RS
2012 Colnago Ace
2010 Giant Cypress
HCFR Cycling Team
2017 Colnago C-RS
2012 Colnago Ace
2010 Giant Cypress
Non omnino gravis
Quoted: 408 Post(s)
Liked 122 Times
You can get Squirt on Amazon. I just ordered a 4oz bottle since I'm running low on my current one. I don't know what they charge for shipping because I'm a Prime Member and we have a local distribution center. I get it delivered the next day.
Squirt recommends that the chain be completely free of other lubricants, even on a new chain. I soak my new chains in mineral spirits, for about an hour, when I buy them and put them back in the box until I put them on the bike.
HCFR Cycling Team
2017 Colnago C-RS
2012 Colnago Ace
2010 Giant Cypress
HCFR Cycling Team
2017 Colnago C-RS
2012 Colnago Ace
2010 Giant Cypress
And i thought of just getting a new chain when i buy Squirt. Thanks for the heads up. Where i’m from, buying on amazon or ebay means i spend double or more with the shipping, etc. That’s why i only order locally. For now i guess i’ll just stick with what i currently use. But i’ll wait until Squirt becomes available again coz i really wanted to switch to dry lubes. Thanks again for recommending it. I’ve read good reviews about it and will try it for sure.
Bikes: '04 LeMond Buenos Aires, '82 Bianchi Nuova Racing, De Rosa SLX, Bridgestone MB-1, Guerciotti TSX, Torpado Aelle, LeMond Tourmalet 853, Bridgestone Radac
Quoted: 101 Post(s)
Liked 46 Times
I've been using DuPont Teflon Chain Saver for quite a few years, about $7 at Walmart in the aisle with motorcycle stuff. I've been caught in the rain many times in the desert and it's not a "darn, now I have to re-do my lube" thing. Still lasts.
Is teflon oil-based? Can you put it on top of an oil-based lube with just a simple degreasing, or do you also need to remove and soak chains and get it totally clean like with Squirt?
Quoted: 101 Post(s)
Liked 46 Times
When I started using it in 2012 I think I gave my chains a thorough cleaning. For new chains, I ride the factory lube and then clean & apply.
