Show me your hacks
Show me your hacks
What bike related hack, bodge, or modification have you made this year? I discovered that my Abus 685 lock (6mm links, 76cm length) just barely fits in my Zefal bottle cage container. It’s been a great solution for me. The whole rig is under two pounds, it’s easy to move from bike to bike, and it looks clean on the frame.
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,102 Times
I guess all I've got right now is that I keep bike stuff (tools, flat stuff) on the bike, because it tends to be specific to the bike; and personal stuff (clothes, water, food, first aid) in the backpack.
Genesis 49:16-17
Genesis 49:16-17
Likes For alan s:
@blackieoneshot - that cable lock looks pretty short. You must not lock the front tire?
As others mentioned, I leave my lock at work too. And a few different clothing items that I switch out once in a while.
I started storing my spare tube, patch kit, tire levers, and multi-tool in an old water bottle. Cleaner than leaving them loose in the pannier and easy to swap between bikes.
Quoted: 5219 Post(s)
Liked 3,564 Times
I rarely yank it off so I'm on the fence about adding more secure fasteners. I kinda like the quick release feature
Keepin it Wheel
Quoted: 26 Post(s)
Liked 3,399 Times
Here's a double hack, or maybe a triple, depending on what counts
1. use a cheap led flashlight instead of a spendy bike-branded light
2. affix the flashlight to the handlebars with interlocked hose clamps, instead of plastic bike-designed light mounts
3. use your stem to display motivational artwork
Likes For RubeRad:
Bikes: 2017 Co-op ADV 1.1; ~1991 Novara Arriba; 1990 Fuji Palisade; mid-90's Moots Tandem; 1985 Performance Superbe
Quoted: 385 Post(s)
Liked 562 Times
Rubber Bike Rack Bumper
I use hose clamps quite a bit also.
The wave-style bike rack at my work was rubbing the paint. I found a used serpentine belt and attached it with hose clamps.
Viola! Rubber bike rack bumper!
Soft place to lean the bike.
Serpentine belt held in place with hose clamps.
Likes For flangehead:
Quoted: 1359 Post(s)
Liked 1,658 Times
I've been carrying my backpack to work like this for almost 20 years...
Likes For BobbyG:
Disco Infiltrator
Liked 2,102 Times
I might have gone the glue route
Genesis 49:16-17
Genesis 49:16-17
Bikes: too many of all kinds
Quoted: 1147 Post(s)
Liked 415 Times
I put a small 350 watt motor on my commuter 6 years ago. Does that count? Its drop bar and doesn't look anything like an ebike, so it rather surprises people with its speed (avg, ~25mph). Its a nice option when I don't feel like doing the 25mile round trip without a little boost, or when I'm just feeling lazy.
Likes For chas58:
Bikes: ...a few.
Quoted: 2009 Post(s)
Liked 405 Times
Likes For mcours2006:
Bikes: ...a few.
Liked 405 Times
I should also mention that my mouse pad mudguard was a necessary hack because of this one commute:
This is without the mudflaps.
This is with the mudflaps.
Still lots of accumulation on the BB, but non from the front wheel spray.
Keepin it Wheel
Quoted: 26 Post(s)
Liked 3,399 Times
BTW I like that half-triangle frame bag, which still allows use of your water bottle cage
Quoted: 1062 Post(s)
Liked 665 Times
My hacks:
Electrical fittings (p clamps, conduit hangers) for attaching racks and chain guards on bikes that don't have eyelets.
Innertube rubber for bungee's and shims.
Keepin it Wheel
Quoted: 26 Post(s)
Liked 3,399 Times
Liked 415 Times
https://www.rei.com/product/877047/r...sku=8770470001
In the winter, it allows me to run studded tires (which normally are horribly slow) but still maintain my summer pace.
Likes For chas58:
Likes For devianb:
Quoted: 2577 Post(s)
Liked 1,900 Times
+1
The plastic cover of my previous armored cable lock cracked and started coming off. I stopped by my LBS and asked if they had any MTB tubes they'd replaced recently. Cut off the appropriate length, slid it over the cable, and it lasted three years. Repeat lasted two more years until the lock got flaky and I replaced it.
Another hack is on my 12 or 13 year old Shimano brifters. Can't find replacement hoods that fit, so I've wrapped them with self fusing silicone tape. Took a couple tries to get the self-fusing to work (hint: you have to stretch it more than I thought), but it's working adequately.
Keepin it Wheel
Quoted: 26 Post(s)
Liked 3,399 Times
