tire pressure
tire pressure
Old 01-22-09, 10:47 AM
rumrunn6
rumrunn6's Avatar
Quoted: 5224 Post(s)
Liked 3,581 Times in 2,342 Posts
tire pressure
How big a difference has anyone seen in changing tires to a higher pressure. Will this so an obvious improvement in speed?
rumrunn6 is offline
Old 01-22-09, 10:51 AM
aMull
aMull's Avatar
Bikes: Leader 735TR 09 58cm 46/17
The ride will be rougher but you get used to it. And yes you do notice a difference.
aMull is offline
Old 01-22-09, 11:05 AM
bcarter6
bcarter6's Avatar
I notice a difference, the ride is rougher and I mostly feel it in my hands and arms, my butt not so much. However, as was said above, I have gotten used to it, especially since it also comes with a little bit quicker feel. Low pressure tires, while a bit more comfortable, seem a little sluggish to me.
bcarter6 is offline
Old 01-22-09, 11:18 AM
ItsJustMe
Señior Member
ItsJustMe's Avatar
Bikes: Windsor Fens, Giant Seek 0 (2014, Alfine 8 + discs)
Quoted: 446 Post(s)
Liked 8 Times in 7 Posts
I have a friend who rides an electric bike to work. He installed a pretty fancy motor control computer on it that reads out how many watts of power the motor is drawing. He says just letting the tires get even 10 pounds down can run his power consumption up by 20 or 30 percent.
Work: the 8 hours that separates bike rides.
ItsJustMe is offline
Old 01-22-09, 11:21 AM
GV27
Light Makes Right
GV27's Avatar
Bikes: Gianni Motta Criterium, Dean Hardtail
On the other hand, at some point its a diminishing rate of return. There have been studies showing that absolutely rock hard isn't always the best when not on a perfectly smooth surface. Most people run too soft anyway so it's probably not an issue, but depending on the tire pumping it all the way to max pressure might be counter-productive.
GV27 is offline
Old 01-22-09, 04:23 PM
Bill Kapaun
Really Old Senior Member
Bill Kapaun's Avatar
Bikes: 87 RockHopper,2008 Specialized Globe. Both upgraded to 9 speeds. 2019 Giant Explore E+3
Quoted: 1795 Post(s)
Liked 1,269 Times in 876 Posts
My 26x1.50" street tires seemed to give me an extra .5 MPH for the same effort when going from 5 PSI under max (65) to 5 PSI over.
I "cruise" about 13 MPH, so that's about 4%.
Bill Kapaun is offline
Old 01-22-09, 04:49 PM
amit_shah25
Drunken Master
amit_shah25's Avatar
Bikes: Jamis Ranger 1.0 (Mutilated !!), Trek Portland
Keeping that pressure up to max will probably reduce chances of getting flats I think ..
EDIT -
It is unrelated to OP question because OP intends to find its impact on speed, but just my 2 cents ..
Nothing to say !
amit_shah25 is offline
Old 01-22-09, 04:58 PM
Hot Potato
Hot Potato's Avatar
Do you mean taking your current tire and pumping it to a higher pressure? Or putting on a new tire rated for a higher pressure? Width, tread, weight, and pressure will be factors when changing to different tires, and they all can effect speed.
Hot Potato is offline
Old 01-22-09, 05:11 PM
CB HI
Cycle Year Round
CB HI's Avatar
Quoted: 1316 Post(s)
Liked 92 Times in 59 Posts
I keep my tires at 100 psi. Faster and fewer flats. I can definitely tell when the tires drop down to 80 psi.
Many of the new road tires can handle 120 psi.
CB HI is offline
Old 01-22-09, 08:55 PM
unixpro
Laid back bent rider
unixpro's Avatar
Bikes: Bacchetta Giro 20
I do notice that I ride faster and with less effort when I have the tires pumped up. For me the proof is in my HRM. Over the same distance, if the tires are low I can spend up to 25% more energy than if they're up to or over pressure.
I also think I corner better when the tires are up to pressure.
unixpro is offline
Old 01-22-09, 09:04 PM
Roody
Sophomoric Member
Roody's Avatar
Quoted: 711 Post(s)
Liked 13 Times in 13 Posts
The more you weigh the harder your tires should be. The rubber should be slightly deformed where it meets the pavement (contact patch), but definitely not flattened.
The rear tire on the bike in this photo is too soft:
"Think Outside the Cage"
Roody is offline
Old 01-22-09, 09:28 PM
aMull
aMull's Avatar
They do, i keep 120-140 psi on both tires of my road bike.
aMull is offline
Old 01-23-09, 04:36 AM
rumrunn6
rumrunn6's Avatar
EMPIRICAL EVIDENCE! Thanks guys!
BTW: I checked the tires in question, they are 26x2.0 with max pressure 45-65 lbs
Anybody know a big fat slick that pumps to 90 lbs?
rumrunn6 is offline
Old 01-23-09, 07:25 AM
mjw16
Bikes: IRO Model 19, Surly Crosscheck, 1989 Arnie Nashbar, Cannondale CAADX, Niner Air 9
I recently changed from 100+ psi tires to 80 psi max tires. They're the same size (700x28) however, I've lost 4 to 5 mph off my commuting average. There are other factors: tread, weight, rubber compound, etc but, I feel, the biggest factor is the pressure difference. Even at max. pressure they're: spongy and slow, I really struggle to maintain a 16 mph avg. on my daily commute, and my thoughts were exactly this: I'm just not getting a good enough return on the energy I'm putting into it. I was recently told that I could, safely, increase the pressure 5 to 10 pounds, however, I'm reluctant to do it. I usually run all my road tires at max. or, slightly above. I think that ride quality is improved too as I feel less squishiness or tendency for the sidewall to fold in hard cornering.
mjw16 is offline
Old 01-23-09, 07:29 AM
mjw16
One question that I forgot to ask is: why isn't "hard" "hard"? That is, whether a tire has a max. pressure of 65 or 110 psi., won't max. pressure yield a similar "hardness" or fullness? I thought that the pressure would compensate for diff. tire volumes, material, design, etc, but would yield an equally full tire. Why would two diff. tires from the same manufacturer, in the same size, have vastly different max. capacities? Is it for ride quality and tires that are designed for diff. riding situations/styles? I guess I always assumed that whether max. was 65 or 100 I would get similar rolling resistance from both wheels, I've recently found that's not the case.
mjw16 is offline
Old 01-23-09, 07:41 AM
Bezier
Sorry, going from 100 psi to 80 psi will not take 4-5 mph off your speed, I doubt it would even take 1. I normally start my tires at 100 and by the time I reinflate they're usually down to 70, but I barely notice a difference the next ride. I also don't think even the worst tires would have such a high rolling resistance as to drop your speed like that (21 mph takes twice as many watts as 16 mph), me thinks this is more of a perceived speed difference than actual speed difference.
Bezier is offline
Old 01-23-09, 07:52 AM
mjw16
Bezier, I'm surprised as well, however, my actual speed is measured by my computer, not guesswork. Unless it became suddenly un-calibrated when I switched tires, same size mind you, it's an accurate estimate. I also judge speed using the clock: it's taking me longer to get to work/home, other riders, and perceived feel of input and output of energy. I'm definitly slower however, it's not entirely related to tire pressure. I know the other factors are: tire weight, compound, tread, punture resistant layers, etc. It's just that the tires are incredibly squishy and poor handling, the bike is slower rolling even when coasting downhill or under consistent pedalling on flat terrain, the hills are especially tough. I've used many types of tires, however, these have the lowest max. pressure of any I've used, thus my conclusion is that tire pressure is probably the biggest culprit in this case.
mjw16 is offline
Old 01-23-09, 08:27 AM
rumrunn6
rumrunn6's Avatar
Still ... I think changing my hybrid tires to a similar width but high pressure slick may make that thing ridable again ...?
rumrunn6 is offline
Old 01-23-09, 08:38 AM
harleyfrog
An Army of Fred
harleyfrog's Avatar
Location: Lost South of Nowhere East of Edan On the Waterfront Far from the Madding Crowd (Biloxi, MS)
Bikes: 1992 Specialized Crossroads Trail
Liked 3 Times in 1 Post
I notice a difference between 100psi (which is where I like to keep it) and 85-90psi on my 700x38c Specialized Nimbi (plural of Nimbus). The lower tire pressure makes me feel like I'm slogging compared to the higher pressure.
harleyfrog is offline
Old 01-23-09, 08:43 AM
mjw16
All things being equal (size, tread, compound,etc), higher pressure will yield higher speed. That said, there are ride quality, wear, and handling issues. It's the first thing everyone does when converting a hybrid/mountain bike to a road or commuter machine is install higher pressure slicks. You'll likely have a slightly harsher ride but the return is improved speed and handling. There are times you'll want to run lower pressure: snow, off road, etc, you may only have to drop the pressure a few pounds to notice the difference. Mountain biking demands more attention to tire pressure and I'm always adjusting for the conditions, road/commuting, I nearly always run at max. pressure.
mjw16 is offline
Old 01-23-09, 09:10 AM
mickey85
perpetually frazzled
mickey85's Avatar
Bikes: 1977 Bridgestone Kabuki Super Speed; 1979 Raleigh Professional; 1983 Raleigh Rapide mixte; 1974 Peugeot UO-8; 1993 Univega Activa Trail; 1972 Raleigh Sports; 1967 Phillips; 1981 Schwinn World Tourist; 1976 Schwinn LeTour mixte; 1964 Western Flyer
Quoted: 5 Post(s)
Liked 6 Times in 6 Posts
The thing that kinda confuses me though, is that right now I'm riding a hybrid with 700X38's with a max of 65 psi. I keep my tires at 62-65 psi (I check them weekly), and they barely sag, but I still feel like I'm slogging. Is this because the tire is wider, or because it has a lower pressure, even though the tire holds it's "roundness?"
mickey85 is offline
Old 01-23-09, 09:39 AM
chipcom
Infamous Member
chipcom's Avatar
Bikes: Surly Big Dummy, Fuji World, 80ish Bianchi
Liked 4 Times in 3 Posts
+1 When riding my 28lb touring bike with 700x32 TT2000s inflated to 80 psi, my average speeds are maybe 1-2mph slower, tops, than when riding my 20lb road bike with 700x23 GP4000s's inflated to 120psi.
"Let us hope our weapons are never needed --but do not forget what the common people knew when they demanded the Bill of Rights: An armed citizenry is the first defense, the best defense, and the final defense against tyranny. If guns are outlawed, only the government will have guns. Only the police, the secret police, the military, the hired servants of our rulers. Only the government -- and a few outlaws. I intend to be among the outlaws" - Edward Abbey
chipcom is offline
Old 01-23-09, 11:11 AM
Roody
Sophomoric Member
Roody's Avatar
Quoted: 711 Post(s)
If you put more air in the same tire, you make the diameter larger. Will this make your computer show a higher speed or a lower speed?
Roody is offline
Old 01-23-09, 11:14 AM
Roody
Sophomoric Member
Roody's Avatar
Quoted: 711 Post(s)
I think this is about right.
The same holds on a mountain bike. When I change from a knobby at 45 psi to a slick at 65 psi, I only pick up a couple mph--on the same bike.
Roody is offline
Old 01-23-09, 11:18 AM
toThinkistoBe
Cheese
toThinkistoBe's Avatar
Bikes: Trek 520 & an old huffy mtb
I keep my front tire at 100psi and back at 120psi (different tires, same size). I can definitely notice a difference if I forget to top them off one day (5-10psi or so), especially in the back. Not so much in speed, but quality of the ride in general. That slight bounce going over small bumps when the tires are a little under inflated is really annoying.
toThinkistoBe is offline
