Garmin heart rate monitor belt too loose
My wife wanted to try my 305 and then buy one but we found the belt too loose even at the tightest setting. Seeing how thin/lean cyclists often are, I'm sure others would also have faced this issue? - any suggestions other than cutting and re-stitching the elastic band?
Bikes: Pedal Force QS3
The Polar belts come in different sizes; I'm 250 lbs and wear a XXL. Check for the Garmin.
15% Hammer Nutrition Discount Code
Bikes: 08 Seven Alaris, 07 Jamis Quest, 08 Swobo Dixon, 91 Specialized Rockhopper
big clothespin? Not pretty but should work
Hot glue (fabric glue stick).
Holds through washing, yet can be pulled apart with no damage to the fabric. I use it on helmet straps and on my Camelbak shoulder straps.
Bikes: Colnago Master XL, Bianchi Via Nirone 7, Marinoni Fango
The safety pin did not work - did not hold it tight enough and signal was lost. I think I'll just cut and shorten the elastic band.
Thanks for the suggestions though.
How very witty
Ingenuity...a dying trait.
late member
The 705 strap, when fully tightened, leaves about 15cm of buckle-to-buckle length ... too short for anybody. So how can it be too loose?
The 305 strap looks similar on the Garmin website, though might be totally different. If so, then use zip-ties and a piece of plastic as en expander.
Bikes: Panasonic 500
Quoted: 16 Post(s)
If you look closely at bangkok's picture it looks like he has re-routed the strap at the connecting ends somehow, or it came that way on the 705. Either way, I don't see how the 305's strap can be routed that way and not slip during use.
Certified Train Wreck
Bikes: '07 Orbea Orca "06 Bianchi Castro Valley
See below, small strap available from Garmin:
https://buy.garmin.com/shop/shop.do?pID=13869
www.websterhenry.com
exrunner,
tried that re-routing but its just not possible.
