Pocket tool for a $1?
This looks like it might be of some use. not a lot invested. any thoughts?
https://www.amazon.com/dp/B000Q06LI4?...P4EQ2Y9NQNEBE8
Quoted: 574 Post(s)
Liked 611 Times
I suspect it is one of those things that does a lot of things but nothing well, but as you say not a lot invested.
Quoted: 1572 Post(s)
Liked 644 Times
There's a lot of wisdom in knowing what you need to carry around with you. This doesn't make my list.
Bikes: 2011 Lynskey Sportive, 1988 Cannondale SM400
Quoted: 20 Post(s)
Well, pretty much every fastener on modern bikes needs a hex to adjust, so this is really not a good answer for bicycle use.
Quoted: 2026 Post(s)
Liked 1,097 Times
As noted it's pretty useless as a bike tool and the sharp top edge will get it confiscated by TSA if you forget and try to take it through an airport.
Quoted: 5955 Post(s)
Liked 2,862 Times
You'll note that is said "a must for every camper or backpacker" though I have no idea what a backpack would ever use it for. OTOH- if the seller thought it had any use for bicycles, he would have said so, since bicyclists can be counted to buy just about any tool.
Simple rule for tool buying. If you don't know in advance when and how you'll use a tool or gadget, odds are you won't find a use for it afterward.
FB
Chain-L site
FB
Chain-L site
What is the hole in the lower left and the jagged, key-like hold near it for?
M.
M.
Liked 2,862 Times
Probably key ring, and the other is a 2 size wrench similar to the multiple one above it.
FB
Chain-L site
FB
Chain-L site
Oops, I am all jacked up - I meant the hole on the lower right, with the notches.
Good call on the key-like thing being a wrench, though.
Neat tool, maybe I'd get one for kicks, but I don't think it would be very useful.
M.
M.
Liked 2,862 Times
Based on the markings, I believe that's intended to be a protractor of some kind.
FB
Chain-L site
FB
Chain-L site
Weird protractor. Not sure what'd it would be useful for.
By the by, did you get any of my PM's?
M.
Liked 2,862 Times
referencing the left/right dislexia
I only said it was a protractor, I didn't say it was a good or useful one.
No, not any recently?
Proves that people will buy anything if it's cheap enough (sorry, couldn't resist)
FB
Chain-L site
FB
Chain-L site
M.
