How much does tread direction affect riding?
Ok, I put my rear tire on backwards, was kind of a rushed job, has slime in tube and am wondering is this a big deal? I've always been a stickler for having them on the right way, but for the time being I don't feel like messing with it; it's not my primary rider, so just wondering, would I be doing any damage to the tire riding it this way, or significantly affect my resistance etc?
Quoted: 6203 Post(s)
Liked 4,816 Times
Not much if you aren't operating near the edge of the envelope.
But if the tires have rotational markings on them to show you which way to mount them, then I'll go by their recommendation.
Not a tire expert, but my guess is the direction of the chevrons mostly comes into play when the riding gets slick or mucky. The idea I believe is that the leading point of the chevron pushes crud away from the center of the tire. And that affect might even be minimal.
Doesn't look like these particular tires are meant to set any speed records, so the affect of their direction on your speed is probably undetectable, if anything at all.
But if you're gonna fret about it every time you go for a ride, just bite the bullet and change it. It's something you can do while eating chips and watching March Madness.
Likes For joeruge:
Likes For HTupolev:
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
That tire? No difference.
Likes For cxwrench:
Quoted: 896 Post(s)
Liked 2,065 Times
Chevrons on road bike tire treads are 99.998% marketing, with the remaining 0.002% being incorrect thinking.
Likes For downtube42:
Quoted: 1110 Post(s)
Liked 1,204 Times
You'd have to look at the depth of the tread. They're designed to shed water outwards. The contact patch on a car tire is rectangular, so a tread on a regular highway tire (as opposed to snow or mud tire) is designed to move water off to the side to avoid hydroplaning. On a bike tire (as opposed to a car tire), the surface that is on the road is oval shaped and naturally sheds water outwards and minimizes hydroplaning. So the tread is probably not important. But, if the tread is backwards, any effect it would have, little as it may be, would be to push the water inward, possibly causing a little hydroplane effect.
I don't have any tubeless tires and have never dealt with slime in a tire. If I ever put a tire on backwards I take it off and do it the other way. I think the only directional tire I've dealt with recently is Continental Gatorskin. Frankly, I believe that tread pattern is too superficial to be meaningful, but the OCD part of me puts it on "correctly".
Liked 2,982 Times
the rear tire might smooth it's center before it might become an unwanted experience with it rotating unidirectionally.
-Oh Hey!
-Oh Hey!
Bikes: 2021 Salsa Fargo 1x12, 2019 Jamis Renegade Exploit 1x11. Motobacne NX Fat Tire
Quoted: 198 Post(s)
Liked 332 Times
You won’t earn any points with the bike bunnies, unless they don’t notice. Just distract them with the bulge in your shorts.
Likes For Toadmeister:
Quoted: 696 Post(s)
Liked 910 Times
I think I’ve put hundreds of miles on backwards tires.
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3891 Post(s)
Liked 6,491 Times
Always put aesthetics first. So, whichever looks better.
Likes For SurferRosa:
Liked 2,982 Times
On Your Left
Quoted: 3004 Post(s)
Liked 2,434 Times
It can unexpectedly assplode causing a catastrophic chain reaction which can lead to the end of the world.
Please correct this before it's too late.
Likes For GlennR:
SE Wis
Quoted: 2747 Post(s)
Liked 3,401 Times
Bikes: ...a few.
Quoted: 2012 Post(s)
Liked 409 Times
The contact patch on your bike tire is but a very thin line, so the treads on your tires are superfluous. They do nothing to sipe away water on wet pavement. It's just aesthetics. The tires I have on my commuter have 'city' tires have a 4-mm wide slick strip down the middle. This is all that makes contact with the ground most of the time, especially if I'm running higher pressure. The 'treads' outside of this strip provide no function.
On automobile tires where the contact patch is a much, much wider strip, the treads on uni-directional tires work to sipe away water toward the the front/side of the tire to reduce the possibility of hydroplaning, which is dangerous.
But having the treads pointing the rear, especially on the front tire, is an eyesore. Yours is at the rear, so no biggie. And if you have fenders on the back, even better.
Quoted: 20810 Post(s)
Liked 9,456 Times
Tread direction itself doesn't matter in the least bit for a pavement tire like this. There are one or two high performance road tires that supposedly have directional casings, which promise to have lower resistance when rolling in the proper direction, but this is not one of those tires.
Quoted: 2604 Post(s)
Liked 1,934 Times
Liked 2,982 Times
-Oh Hey!
-Oh Hey!
Quoted: 581 Post(s)
Liked 921 Times
On hard surfaces it makes very little, if any, difference.
You might notice some difference if riding on soft surfaces like dirt or sand, when accelerating or braking. On directional off-road knobby tires you can tell a bit of a difference, but not so it makes the bike unsafe or bad to ride.
Chevron patterns on car tires are to squeeze water out of the way to prevent hydroplaning. Bike tires have too high pressure and travel at too low a speed to suffer from hydroplaning so it will make little or no difference on a wet hard surface.
Likes For ClydeClydeson:
Liked 9,456 Times
Quoted: 4806 Post(s)
Liked 3,933 Times
On the road? My experience - as long as the tread rotates the same direction as the rim (and other wheel and in the direction of bike travel) it works for me. )
Real life - I ride both Paselas with directional patterns and Vittoria Gs with little on flip-flop hubs and flip the wheel frequently. Pay zero attention to how my tire is flipped and never noticed. On my wither fix gear with its regular track hub, I've run Paselas for years "backwards" to have the labels to the left as I look at my bikes fomr the left, not the right. They are always leaning right side to a rack or wall. If backwards tread was an issue, you'd think it wold show after the first 20 tires or so.
Very Senior Member
Bikes: Giant Quasar & Fuji Roubaix
Quoted: 413 Post(s)
Liked 343 Times
So, after reading through this thread, if I understand the experts correctly, and since this is on the internet it must be true, when my tires are down to nothing, I can flip them around and run them backwards until the treads are back? WOW! I wish someone had told me that years ago. How much money I could have saved on tires...
Randomhead
Liked 3,702 Times
You can't convince me that tire manufacturers do any analysis or testing to determine proper tread direction.
Quoted: 2952 Post(s)
Liked 3,106 Times
In my experience it makes absolutely zero difference on the road. I do think it makes a difference in mud, so I actually pay attention to those directional arrows on my CX bike.
